987 1st Gear October 30, 2010 Share October 30, 2010 Gen 2 SB is selectable. OFF, Stage 1 and Stage 2. Not sure anyone selling these locally though. Does anyone know? Gen 2 SB are going for usd$329 http://www.sprintboosterusa.com/download/catalog.pdf ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Tohto Hypersonic October 30, 2010 Share October 30, 2010 bro.. how much and where you install your pivot? can share? thanks Mcw*ll at ubi. Link to post Share on other sites More sharing options...
Cerano 1st Gear October 30, 2010 Share October 30, 2010 Gen 2 SB is selectable. OFF, Stage 1 and Stage 2. Not sure anyone selling these locally though. Does anyone know? Gen 2 SB are going for usd$329 http://www.sprintboosterusa.com/download/catalog.pdf MBM is selling these bro 1 Link to post Share on other sites More sharing options...
Pokyman 1st Gear November 1, 2010 Share November 1, 2010 Is it confirmed that cable throttle cannot use 3drive? Coz the mech needed to cut wires to sort of connect the device leh ... and when i just depressed lightly, my car did rev much more as compared to before i installed the 3drive. Link to post Share on other sites More sharing options...
Itsec 2nd Gear November 1, 2010 Share November 1, 2010 Is it confirmed that cable throttle cannot use 3drive? Coz the mech needed to cut wires to sort of connect the device leh ... and when i just depressed lightly, my car did rev much more as compared to before i installed the 3drive. can but y... cabled throttled is good mah... unless u wan to save fuel... its just another way to fool the sensor... there are 3 modes.. eco, normal, power ?? (cant recall the terms) when u press to a certain position... if set to eco mode, the butterfly open lesser, in power mode, the butterfly open more.. normal means normal lor... why u wan to do that.. use ur leg to control lor.. Link to post Share on other sites More sharing options...
Tohto Hypersonic November 1, 2010 Share November 1, 2010 can but y... cabled throttled is good mah... unless u wan to save fuel... its just another way to fool the sensor... there are 3 modes.. eco, normal, power ?? (cant recall the terms) when u press to a certain position... if set to eco mode, the butterfly open lesser, in power mode, the butterfly open more.. normal means normal lor... why u wan to do that.. use ur leg to control lor.. Your leg can't do that fast, believe me. Even I stomp on the accelerator hard at normal mode, it is still slower on the response when set in sport mode. It is like now many conti performace car, they have from factory normal mode or sport mode. The sport mode will improve the responsiveod the right paddle. Link to post Share on other sites More sharing options...
Itsec 2nd Gear November 1, 2010 Share November 1, 2010 Your leg can't do that fast, believe me. Even I stomp on the accelerator hard at normal mode, it is still slower on the response when set in sport mode. It is like now many conti performace car, they have from factory normal mode or sport mode. The sport mode will improve the responsiveod the right paddle. yah lah.. u fool the sensor mah... if u are those into 0-100.. then if works on your ride go ahead.. for me.. i prefer to keep in simple.. wan to do 0-100 sprint.. shift to sports mode, set to manual control.. i will drive it like a manual... Link to post Share on other sites More sharing options...
Ferus Neutral Newbie November 11, 2010 Share November 11, 2010 if u have good setting on your tps it will give more respond on your throttle load i just use apexi afc 5button to add the fuel/air it make more advantage Link to post Share on other sites More sharing options...
Echo2zero Neutral Newbie November 15, 2010 Share November 15, 2010 tks for the info! 1 Link to post Share on other sites More sharing options...
VellfireS 4th Gear February 15, 2011 Share February 15, 2011 stock e-throttle cannot be adjusted, there are after market e-throttle booster/controller which can improve over stock setup. Wow.. Bro , your avatar seriously makes my eye go up and down.. Link to post Share on other sites More sharing options...
Kzy Neutral Newbie February 27, 2011 Share February 27, 2011 anyone know wad proton persona throttle controller hardness use? i mean the hardness size of it? (e.g 4A,7A) Your help will be appriciated! 1 Link to post Share on other sites More sharing options...
Vtim 3rd Gear April 5, 2011 Share April 5, 2011 Wow.. Bro , your avatar seriously makes my eye go up and down.. you are not the only one that mention that Link to post Share on other sites More sharing options...
VellfireS 4th Gear April 5, 2011 Share April 5, 2011 you are not the only one that mention that What to do.. [:p] Seems now you have changed to another eye-catching Avatar... Haizz.. wish can see this @ ECP.. Link to post Share on other sites More sharing options...
Sp3cialist Neutral Newbie April 23, 2011 Share April 23, 2011 Hi I recently tuned my car at OBD tuning. Its a Lancer EX GT. Very responsive, wondering if Trottle Controller or sprint booster will help it further? 1 Link to post Share on other sites More sharing options...
Nis Neutral Newbie May 19, 2011 Share May 19, 2011 Good stuff 1 Link to post Share on other sites More sharing options...
Goobii Neutral Newbie December 2, 2011 Share December 2, 2011 My Review: Pivot FLAT throttle control Installed & Tested. As recommended by Bro Troy.... Even though I had been going against it for almost 1yr due to reading other forum and feedback by others. ECON 5 ... Super lag.... Turtle retarded Feels like stock car + lousy open pod... + fully loaded with 7pax. SP1... . ... 10% open throttle SP2... F ... 20% throttle SP3... Fa ... 30% throttle SP4... Fas... 40% throttle SP5... Fast... 60% throttle SP6... Faster... 80% throttle SP7... Fastest... 100% full throttle . * SP1 to SP3 : Responsive, but not much diff yet. * SP4 to SP6 : Very responsive, cheong forward like nobody business but drink fuel like water. - Still testing only ECON 5 ... Don't want to get addicted till I drive up NORTH to try SP4toSP6 again.. SP7 should be super responsive, dare not try yet.. Doesn't gain any BHP or horse at all, just allow throttle valve to open bigger when you step the pedal.. That's it... GB anyone? Got another lobang for it... Just PM me... Warrenty 1yr with installation. 1 Link to post Share on other sites More sharing options...
Raytham Neutral Newbie December 2, 2011 Share December 2, 2011 i'm curious to know... ahhaa... my kaki tighten for me.. mention not to do it too tight.... maybe it will snap if u floor from stationary... Er snap or not i not too sure. But if its tighten too tight once you start yr engine yr RPM will shoot higher than normal. For sure FC sure kana affected. 1 Link to post Share on other sites More sharing options...
Goobii Neutral Newbie December 2, 2011 Share December 2, 2011 Re: If you want Pivot 3drive... Made in Japan Install / calibration / 1yr warranty If interested, just PM me... I only need your name / hp / vehicle number to add into GB list. I will SMS to all the location and date for installation if Interested once minimum 3 pax confirm... ↡ Advertisement Link to post Share on other sites More sharing options...
DIY cleaning throttle body
Throttle body cleaning
DIY: Porting & Polishing a Throttle Body (Video Tutorial)
Throttle Body
Throttle Body
Sony Reveals New DualSense Controller for PlayStation 5
DTE pedalbox throttle controller
Any shops to buy throttle body cleaner?
