Camus Neutral Newbie November 1, 2010 Share November 1, 2010 Saw this interesting product call easycolor scratch removal pen. live demo video of someone using it to fix a scratch. Its actually a pen cum spray, but can only spray if you attach it to a special air brush can. http://js.tudouui.com/bin/taobaoisv/TaoBao...wf?iid=54476471 From what I heard, the pen the product covers a range of popular cars like honda, toyata, mitsubishi, nissan, bmw, benz, vw etc. Some color like black, white, gray matched nicely if you buy the correct pen for your car model and make but some color has a slight different, need to use another coating shine pen to blend the colors further. Here pictures of the pens but I don't think they are available in Singapore yet, the cost of the pen is cheap but due to no availability in Singapore, the shipping price can be quite steep when add up. Or maybe its already available but I do not know of? ↡ Advertisement Link to post Share on other sites More sharing options...
Kish1313 Neutral Newbie November 1, 2010 Share November 1, 2010 seen more less same kind @ Autobacs Link to post Share on other sites More sharing options...
Khrz Neutral Newbie November 1, 2010 Share November 1, 2010 bought a white colour for my car last time from autobac.. not sure the brand but the colour code same as stated after comparing to car.. after putting on, like liquid paper sia.. 1 lump of hardened line over the scratch, uneven and also colour not same maybe car old.. Link to post Share on other sites More sharing options...
Nzy Twincharged November 1, 2010 Share November 1, 2010 bought a white colour for my car last time from autobac.. not sure the brand but the colour code same as stated after comparing to car.. after putting on, like liquid paper sia.. 1 lump of hardened line over the scratch, uneven and also colour not same maybe car old.. Unless u know how to wetsand and polish if not touchup paint usually make the scratch worse. Link to post Share on other sites More sharing options...
Merciwash Neutral Newbie November 1, 2010 Share November 1, 2010 (edited) Tried that last time. Give you more detail if you think it's easy. Step1: Apply primer wait 2 hrs (repeat if needed) ( as in the video singapore can get at workshop the pale white ones ) Step2: Sand with grit 800 sandpaper Step3: Sand with grit 1500 Sandpaper Step4: Apply paint ( Spray Can or paint brush ) Step5: Apply Lacquer ( May not be needed as some brush comes with lacquer ) Step6: Sand with grit 2500 sandpaper till level and blend with the surrounding Step7: Polish till no scratch Roughly 4hrs of work http://www.ehow.com/how_6758644_patch-car-paint.html Edited November 1, 2010 by Merciwash Link to post Share on other sites More sharing options...
Zuoom 1st Gear November 1, 2010 Share November 1, 2010 for these sort of touch up pen/brush. the general idea is to use as little of the touch up paint as possible. the end result will cover up the small chip, scratch. (usually got those under 10mm). anything bigger will remain obvious. will require a more pro job. Link to post Share on other sites More sharing options...
Ez_rider Neutral Newbie November 1, 2010 Share November 1, 2010 Very interesting!Thanks for the info Link to post Share on other sites More sharing options...
Nzy Twincharged November 1, 2010 Share November 1, 2010 Tried that last time. Give you more detail if you think it's easy. Step1: Apply primer wait 2 hrs (repeat if needed) ( as in the video singapore can get at workshop the pale white ones ) Step2: Sand with grit 800 sandpaper Step3: Sand with grit 1500 Sandpaper Step4: Apply paint ( Spray Can or paint brush ) Step5: Apply Lacquer ( May not be needed as some brush comes with lacquer ) Step6: Sand with grit 2500 sandpaper till level and blend with the surrounding Step7: Polish till no scratch Roughly 4hrs of work http://www.ehow.com/how_6758644_patch-car-paint.html I usually do it differently. Normally just use a toothpick to apply the paint to cover the scratch, let it dry then sand with 1500grit till level and then 2000grit then polish. This way takes around 1hr if u dont count in the drying time. Link to post Share on other sites More sharing options...
Camus Neutral Newbie November 14, 2010 Author Share November 14, 2010 usually when it comes to sanding and painting, owner of a 2nd hand car usually have more guts feeling when working at it hehe Link to post Share on other sites More sharing options...
Sktan10 5th Gear November 14, 2010 Share November 14, 2010 Ever seen the spray-can in autobac before. Nearly brought the can as it is the last one. If i rem correctly is around $20. ↡ Advertisement Link to post Share on other sites More sharing options...
Exercising and losing weight
Bird pest removal
Bird pest removal
Car scratched by vandal
Getting your car refreshed for CNY: paint / polish / ceramic
Water marks removal on the windscreen glasses.
Car scratch
Car scratch
Yew Lip vs. Advanced Scratch Master
