ER-3682 Twincharged March 29, 2019 Share March 29, 2019 How old is your car? Good luck man, hope it won't be pricey. From my experience, Mazda 6's suspension is quite soft. Going over a typical hump at HDB estate without braking to 10-15km/hr is quite scary (I'm quite gentle to my car heh). When my car is filled with 5 passenger (including 1 driver), very likely will hear knocking (not sure is suspension going full out or literally scraping the hump) when going over humps at anything above that range so I'm extra careful. Mazda 6 Suspension are the hardest among the same class of Japanese car...Maybe You & your Passengers are all Heavy weight... ↡ Advertisement Link to post Share on other sites More sharing options...
huuami 1st Gear March 29, 2019 Share March 29, 2019 My 5k servicing took about 3 hours. I took the first slot at 8am Leng Kee centre. It was completed at 1130. I found it to be quite slow. Additionally, the service engineer did not explain or tell me more about the work that was done. They just get me to the cashier right away. Waiting that long is kind of expected la. I did my servicing at Ubi's and they aren't as bad as you mentioned hmm... Link to post Share on other sites More sharing options...
ppanamera 1st Gear March 29, 2019 Share March 29, 2019 Waiting that long is kind of expected la. I did my servicing at Ubi's and they aren't as bad as you mentioned hmm... Borneo motor takes about an hour for non major servicing. Thus that was my basis of comparison Link to post Share on other sites More sharing options...
Laiwh 1st Gear March 29, 2019 Share March 29, 2019 if you benchmark against Borneo Motor, you will most probably feel disappointed with the efficiency of other AD's servicing. Kah Motor is another slow one. At least 3 hours for normal servicing. Major Servicing takes at least half a day. Link to post Share on other sites More sharing options...
clarkkent 1st Gear March 29, 2019 Share March 29, 2019 Just changed from Mazda 3 (2014) to a 2nd hand mazda 6 (2017 model). Notice a few things different. 1) Reverse camera. There is this red line when you are reversing. For mazda 3, when the red line touches the carpark lot white line, my car is perfectly in the lot. For Mazda 6, the red line needs to cross the white lite then my car is in the lot. If the red line just touches the white line, my car is sticking out too much. I asked AD to align or check but they told me this is normal. Is this normal? 2) I seems to clock more mileage on the odometer with mazda 6 than mazda 3. Not sure if this is because Mazda 6 has a bigger rim but in theory mileage should not be affected by rim size. Not sure if this is just my bias. 2 Link to post Share on other sites More sharing options...
Patwong 3rd Gear March 30, 2019 Share March 30, 2019 Been drving the mz6 2.0L over a year now and sudden interest in trying the "sport" mode recently. When picking up speed or during overtaking on expressway, just flip the switch and the engine/gearbox will react promptly without me adding extra pressure on the accelerator pedal. After that, just flip the switch to off sport mode. Some might already know this, info for those new to the car especially those finding 2.0L engine slight sluggish. 2 Link to post Share on other sites More sharing options...
SZ_ford 5th Gear March 31, 2019 Share March 31, 2019 Been drving the mz6 2.0L over a year now and sudden interest in trying the "sport" mode recently. When picking up speed or during overtaking on expressway, just flip the switch and the engine/gearbox will react promptly without me adding extra pressure on the accelerator pedal. After that, just flip the switch to off sport mode. Some might already know this, info for those new to the car especially those finding 2.0L engine slight sluggish. Does mz6 come with paddle shift? Sorry i dont drive a mz6. Sometimes i wonder which is better between downshift 1 gear and sports mode. Both have immediate engine response 2 Link to post Share on other sites More sharing options...
ER-3682 Twincharged March 31, 2019 Share March 31, 2019 Does mz6 come with paddle shift? Sorry i dont drive a mz6. Sometimes i wonder which is better between downshift 1 gear and sports mode. Both have immediate engine response Paddle Shift only 2.5 have. 1 Link to post Share on other sites More sharing options...
Peppa75 Clutched March 31, 2019 Share March 31, 2019 Does anyone faces the walk away auto door lock sometimes doesn't work? Mine does. Once a while when off engine get out n close door and walk away it does not auto lock. Most of the time it does. 2 Link to post Share on other sites More sharing options...
makeanewcall 3rd Gear March 31, 2019 Share March 31, 2019 Just changed from Mazda 3 (2014) to a 2nd hand mazda 6 (2017 model). Notice a few things different. 1) Reverse camera. There is this red line when you are reversing. For mazda 3, when the red line touches the carpark lot white line, my car is perfectly in the lot. For Mazda 6, the red line needs to cross the white lite then my car is in the lot. If the red line just touches the white line, my car is sticking out too much. I asked AD to align or check but they told me this is normal. Is this normal? 2) I seems to clock more mileage on the odometer with mazda 6 than mazda 3. Not sure if this is because Mazda 6 has a bigger rim but in theory mileage should not be affected by rim size. Not sure if this is just my bias. Mileage as in km/l or overall distance? No matter what, the fuel tank of Mazda 6 is way bigger so naturally you can travel more unless you floor the accelerator everytime. 1 Link to post Share on other sites More sharing options...
ER-3682 Twincharged March 31, 2019 Share March 31, 2019 Does anyone faces the walk away auto door lock sometimes doesn't work? Mine does. Once a while when off engine get out n close door and walk away it does not auto lock. Most of the time it does. Yes,sometime it won't work,make sure you hear the 'Beep' Sound before moving away. 1 Link to post Share on other sites More sharing options...
sgsmith 1st Gear March 31, 2019 Share March 31, 2019 (edited) Does anyone faces the walk away auto door lock sometimes doesn't work? Mine does. Once a while when off engine get out n close door and walk away it does not auto lock. Most of the time it does. From an online manual: (Walk-away auto lock function) A beep sound is heard when all doors and the liftgate are closed while the advanced key is being carried. All doors and the liftgate/boot lid are locked automatically after about 3 seconds when the advanced key is out of the operational range. Also, the hazard warning lights flash once. (Even if the driver is in the operational range, all doors and the liftgate/boot lid are locked automatically after about 30 seconds.) If you are out of the operational range before the doors and the liftgate/boot lid are completely closed or another key is left in the vehicle, the walk-away auto lock function will not work. Always make sure that all doors and the liftgate/ boot lid are closed and locked before leaving the vehicle. The walk-away auto lock function does not close the power windows. Based on the manual, i guess if you close driver door first, then open and close rear passenger door, it will not work. Edited March 31, 2019 by sgsmith 3 Link to post Share on other sites More sharing options...
DK3410 4th Gear March 31, 2019 Share March 31, 2019 Hi fellow Mz6 owners. Just got inundated by a bunch of error messages on my Mazda 6. Indicating malfunction of almost all the active safety systems on the car (Smart City Brake Support, Forward Sensing Camera, Driver Attention Alert, Lane-keep Assist, Lane-departure Warning System). Kind of disappointed given the car is barely 6 months old... 1 Link to post Share on other sites More sharing options...
Kenomi 2nd Gear March 31, 2019 Share March 31, 2019 One off? I get it when i parked under the sun and more than 40deg temperatures. 2 Link to post Share on other sites More sharing options...
Patwong 3rd Gear April 1, 2019 Share April 1, 2019 Does mz6 come with paddle shift? Sorry i dont drive a mz6. Sometimes i wonder which is better between downshift 1 gear and sports mode. Both have immediate engine response Hi ford, 2L no paddle shift. Mazda sport mode only hold gear at certain low ranges, if required to adjust gear manually, there is +/- mode at gear lever. Cheers. 1 Link to post Share on other sites More sharing options...
SZ_ford 5th Gear April 1, 2019 Share April 1, 2019 Hi ford, 2L no paddle shift. Mazda sport mode only hold gear at certain low ranges, if required to adjust gear manually, there is +/- mode at gear lever. Cheers. thanks side track a bit, sometimes i wonder whats the best way to overtake. Do i drop a gear or engage sport mode? Dropping a gear is more intuitive and quicker with paddle shift Link to post Share on other sites More sharing options...
makeanewcall 3rd Gear April 1, 2019 Share April 1, 2019 (edited) thanks side track a bit, sometimes i wonder whats the best way to overtake. Do i drop a gear or engage sport mode? Dropping a gear is more intuitive and quicker with paddle shift How about simply flooring the accelerator? Edited April 1, 2019 by makeanewcall Link to post Share on other sites More sharing options...
SZ_ford 5th Gear April 1, 2019 Share April 1, 2019 How about simply flooring the accelerator? haha right, that's the 3rd option i find this usually less responsive than the 2 choices i mentioned ealier ↡ Advertisement 1 Link to post Share on other sites More sharing options...
[Official] 2024 8th Generation BMW 5 Series (G60)
