Zafchen Neutral Newbie November 27, 2010 Share November 27, 2010 Need help from bro here.. Wanted to buy Pro - RS steel brake hose for my ride, but was wondering can the Hose be transfer to another ride in-case i change my ride... Also where can i go to purchase and install... ↡ Advertisement Link to post Share on other sites More sharing options...
Itsec 2nd Gear November 27, 2010 Share November 27, 2010 Need help from bro here.. Wanted to buy Pro - RS steel brake hose for my ride, but was wondering can the Hose be transfer to another ride in-case i change my ride... Also where can i go to purchase and install... only same model transferable... due to the length... warranty wise.. better check with the dealer... Link to post Share on other sites More sharing options...
Byond 1st Gear November 27, 2010 Share November 27, 2010 Pro RS, Go to Singapore LAncer Club Look for Zo (Lorenzo)...i think he is selling... u might also wanna keep ur options open for other brands like 1) HEL 2) Goodridge 3) many more..... Link to post Share on other sites More sharing options...
Zafchen Neutral Newbie November 27, 2010 Author Share November 27, 2010 icic..... What i mean is any shop to recommend for installation? Link to post Share on other sites More sharing options...
Ysc3 Twincharged November 27, 2010 Share November 27, 2010 any mech will be able to do it ... its just a normal job, nothing special. just make sure they bleed the brake hose after installation. i did it for $30(labour) + $15(brake fluid) at tampines industrial park. however, like what ITSEC said, each set is car model dependent = non-transferable. Link to post Share on other sites More sharing options...
Djdp Clutched November 27, 2010 Share November 27, 2010 u can get e SS hose for $240/ set of 4. include installation + top up fluid Link to post Share on other sites More sharing options...
Ghostami 2nd Gear November 27, 2010 Share November 27, 2010 There is another brand call magnium, if you are interested. Its a sub brand of hel Link to post Share on other sites More sharing options...
Moredhel 2nd Gear November 27, 2010 Share November 27, 2010 u can get e SS hose for $240/ set of 4. include installation + top up fluid You can get for 160 if you know where. Link to post Share on other sites More sharing options...
Galantspeedz Turbocharged November 27, 2010 Share November 27, 2010 You can get for 160 if you know where. And u intend to tell? Link to post Share on other sites More sharing options...
Ysc3 Twincharged November 28, 2010 Share November 28, 2010 (edited) google for the retailer in KL and then order direct. If you organize mass order, possible can even get at lower than $160. Edited November 28, 2010 by Ysc3 Link to post Share on other sites More sharing options...
Ghostami 2nd Gear November 28, 2010 Share November 28, 2010 google for the retailer in KL and then order direct. If you organize mass order, possible can even get at lower than $160. How much for workshop installation and also brake fluid ? If adds up to about 200+ I rather do it in Singapore. 1 - Warranty issue easy to get help 2 - All the trouble just to save a little bit Sometimes material cost might be cheaper to order out of Sg but if you consider those 2 factors and it adds up to almost the same to be done in Sg might as well do it in Sg. Link to post Share on other sites More sharing options...
Rb26dett Clutched November 28, 2010 Share November 28, 2010 around 260-280 range , can get you reputable brands like goodridge ,HD project mu .and that includes installation and bleeding of brakes with brake fluid. better to get big brands that are proven , gives you peace of mind and the "money well spent" feel. Link to post Share on other sites More sharing options...
Kurty Supercharged November 28, 2010 Share November 28, 2010 does it really worth the money? i'm already using good tires, sport brakes. just curious Link to post Share on other sites More sharing options...
Karebu 1st Gear November 28, 2010 Share November 28, 2010 does it really worth the money? i'm already using good tires, sport brakes. just curious bump your question up. want to zhng go add in whatever filter or pod la. want add crazy lights change lights more lights do it la. want add kit add lor. just better not to f around with brakes. all the BBK and hoes and shits. i think if genna accident you may not be covered. Link to post Share on other sites More sharing options...
Ghostami 2nd Gear November 28, 2010 Share November 28, 2010 SS hoses are a thing to invest if you wanna drive long. Normal rubber hose will just wear off and you do not want to get yourself in a situation where there is no brakes like my boss car due to the failure of rubber hose for his brakes due to wear and tear. Especially for auto cars as your form of braking most of the time is using brakes rather than engine brakes. Link to post Share on other sites More sharing options...
Yuan 6th Gear November 28, 2010 Share November 28, 2010 does it really worth the money? i'm already using good tires, sport brakes. just curious In my opinion, grippy brake pads and tires are sufficient. Link to post Share on other sites More sharing options...
Brucelee Neutral Newbie November 28, 2010 Share November 28, 2010 ss hose b4 changing brake. Link to post Share on other sites More sharing options...
Fresh Clutched November 28, 2010 Share November 28, 2010 yes ↡ Advertisement Link to post Share on other sites More sharing options...
Brake Pads
Brake Pads
Steel cabinet
Steel cabinet
Brake squeak every morning
