Moredhel 2nd Gear November 30, 2010 Share November 30, 2010 google for the retailer in KL and then order direct. If you organize mass order, possible can even get at lower than $160. Correct. If wanna save costs, cable tie your rubber hose lor. Same effect. ^^ ↡ Advertisement Link to post Share on other sites More sharing options...
Crazecow Neutral Newbie November 30, 2010 Share November 30, 2010 SS hoses are a thing to invest if you wanna drive long. Normal rubber hose will just wear off and you do not want to get yourself in a situation where there is no brakes like my boss car due to the failure of rubber hose for his brakes due to wear and tear. Especially for auto cars as your form of braking most of the time is using brakes rather than engine brakes. I think there is a misconception about steel braided hoses. While they may last longer than plain rubber hoses, they do suffer from wear and tear as well. This is because they are not made of entire steel. Its not a steel pipe. Brake lines are usually synthetic rubber wrapped with a layer of stainless steel braiding. The steel braiding will last a long time but the synthetic rubber will still crack and leak over time. So don't asusme that once you get steel braided hoses means they last literally forever. Its not the case. http://www.goodridge.co.uk/buy-goodridge-hoses.htm Link to post Share on other sites More sharing options...
Yeobh 4th Gear November 30, 2010 Share November 30, 2010 Click here for professional steel braided brake hose set http://sg.ebid.net/for-sale/fiat-x1-9-stai...it-23429559.htm ↡ Advertisement Link to post Share on other sites More sharing options...
Brake Pads
Brake Pads
Steel cabinet
Steel cabinet
Brake squeak every morning
