Baxter Neutral Newbie January 17, 2011 Share January 17, 2011 (edited) Guys, My car headlight has some scratches and a bit blurish but not yellow stain on them. Anyway to get rid of the scratches? Read on the internet, using sandpaper method or some polish cream. Any good recommendation ? DIY or Professional services ? I called Autobac, only can get rid of yellow stain. Thanks in advance. Edited January 17, 2011 by Baxter ↡ Advertisement Link to post Share on other sites More sharing options...
Exprezstar Neutral Newbie January 18, 2011 Share January 18, 2011 Autosol will do fine. I didn't believe my mech when he recommended it, but it certainly worked better than my novus 3 (novus is a plastic polisher). Do try on an inconspicuous part first though. Link to post Share on other sites More sharing options...
Zuoom 1st Gear January 18, 2011 Share January 18, 2011 something the ArmorCoatSG guys did for my lights n car. headlight was getting cloudy n scratches/chips from the usual stone n whatnots. so, the guys there took it out, gave it a good sanddown to remove the damaged top layer. then sprayed a clear film over. as good as a fresh pair of lamps. and getting some amount of protection from the ArmorCoat clear film. via : http://www.celicasg.org/index.php/topic,7948.0.html Link to post Share on other sites More sharing options...
Chengwh492 Clutched January 18, 2011 Share January 18, 2011 looks good! how much? Link to post Share on other sites More sharing options...
Zuoom 1st Gear January 18, 2011 Share January 18, 2011 you might want to give them a beep. Vendor site. http://www.mycarforum.com/index.php?autoco...p;COM=ArmorCoat the guy active here. http://www.mycarforum.com/index.php?showuser=66736 my price is a package as i did the entire car. Link to post Share on other sites More sharing options...
Rb26dett Clutched January 18, 2011 Share January 18, 2011 first off , i read this thread yesterday morning .and was considering of restoring my 5yrs old really really bad condition headlights. so couple of hours ago , i went into JB , as usual makan , buy disc , wash car.then i was at this regular car washing shop they advertised their price list. headlight polishing for RM60.so i thought no harm give it a try. i watched the entire process , they water sand down a couple of times making sure they remove all the dirt and impurities and also the slight scratches. they then use some chemical to clean it throughly before proceeding to buff the headlights with some headlight restoration cream or such. when it's done they applied a layer of sealant onto it .total job took about 45 mins.job well done and i was very satisfied. for a mere RM60 , no harm trying.the shop i visited is B.O.S.S. Link to post Share on other sites More sharing options...
Rb26dett Clutched January 18, 2011 Share January 18, 2011 (edited) edited * double post. Edited January 18, 2011 by Rb26dett Link to post Share on other sites More sharing options...
Baxter Neutral Newbie January 18, 2011 Author Share January 18, 2011 Wow, thanks guys for the info. Link to post Share on other sites More sharing options...
Chengwh492 Clutched January 18, 2011 Share January 18, 2011 how much is this armorcoat? is it cheaper than buying a new set of headlights or visiting JB as the other say? Link to post Share on other sites More sharing options...
Bummer 1st Gear January 19, 2011 Share January 19, 2011 Do the processes to restore the headlights come with UV protection coat against fading? If they do not, the fading will occur again really quickly. Link to post Share on other sites More sharing options...
ArmorCoatSG Clutched January 19, 2011 Share January 19, 2011 Hi guys, Just for your info, ArmorCoat can be coated onto headlights and painted surfaces. Damage for coating your headlights will be $240 per pair. After the coat is done, you'll get back your clarity and it will not fade unless it is condensation from the inside which means you'll have to change your housing? Jonathan Link to post Share on other sites More sharing options...
ArmorCoatSG Clutched January 19, 2011 Share January 19, 2011 Do the processes to restore the headlights come with UV protection coat against fading? If they do not, the fading will occur again really quickly. Hi bro, Yes it comes with UV protection:) So no worries about fading Jonathan Link to post Share on other sites More sharing options...
Rollagt 5th Gear January 19, 2011 Share January 19, 2011 Autosol will do fine. I didn't believe my mech when he recommended it, but it certainly worked better than my novus 3 (novus is a plastic polisher). Do try on an inconspicuous part first though. How about Brasso ? Currently i make it a point after every car wash, apply Soft99 on to the headlamps. Let it "season" for awhile then apply a few drops of Soft99 and "polish" it. After that wipe it with a clean cloth. It works quite okie but cant compared with other bros who had sent for professional buffing Link to post Share on other sites More sharing options...
Rb26dett Clutched January 19, 2011 Share January 19, 2011 Do the processes to restore the headlights come with UV protection coat against fading? If they do not, the fading will occur again really quickly. for a mere RM60 which makes up to less than $30 sgd , no harm giving it a try in JB . if all fails , can try the expensive $240 armor coat Link to post Share on other sites More sharing options...
Garyong88 Neutral Newbie January 20, 2011 Share January 20, 2011 Dude where is this BOSS? Care to share location or e-mail to me at [email protected].. Thanx Link to post Share on other sites More sharing options...
Lation Neutral Newbie January 20, 2011 Share January 20, 2011 Tried using autosol on my headlight today. It works wonder. Solve my blurry headlight prob. +1 for autosol. Link to post Share on other sites More sharing options...
Subzro Neutral Newbie January 20, 2011 Share January 20, 2011 Any chance you'd have the before and after pictures of your headlamps? Link to post Share on other sites More sharing options...
Sirex Neutral Newbie January 20, 2011 Share January 20, 2011 Guys, My car headlight has some scratches and a bit blurish but not yellow stain on them. Anyway to get rid of the scratches? Read on the internet, using sandpaper method or some polish cream. Any good recommendation ? DIY or Professional services ? I called Autobac, only can get rid of yellow stain. Thanks in advance. Try this http://www.turtlewax.com/main.taf?p=2,1,4,32 I bought one in caltex. Excellent as it removes the fine scratches and restores the clarity! Quite ex though.. ↡ Advertisement Link to post Share on other sites More sharing options...
Quad Light Bulb Size
Recommendations for light kitchen carpentry and sink works
Car vandals are petty losers
New Age Polish -->Land Rover Portfolio
Are LED lights subject to brightness checks?
2009 hyundai avante HD
