Bluepica 4th Gear March 14, 2011 Share March 14, 2011 I got this cheap water filter system from MY. It has a dome ceramic on top, the some soil and gravel in the tube, and bottom of the filter is some volcanic rocks. You pour the tap water on top and the water will slowly drip downwards. There's the plastic tap for you to push to dispense the water for drinking like those we see at those normal bottled water drinking dispenser. Where in SG can I buy the replacement plastic tap? Anyone knows? I have bought it once in KL but now pecah again :( ↡ Advertisement Link to post Share on other sites More sharing options...
jhonnikolson August 11, 2019 Share August 11, 2019 (edited) I got this cheap water filter system from MY. It has a dome ceramic on top, the some soil and gravel in the tube, and bottom of the filter is some volcanic rocks. You pour the tap water on top and the water will slowly drip downwards. There's the plastic tap for you to push to dispense the water for drinking like those we see at those normal bottled water drinking dispenser. Where in SG can I buy the replacement plastic tap? Anyone knows? I have bought it once in KL but now pecah again :( The replacement filter so this so called best water filter is not easy to find. Edited August 11, 2019 by jhonnikolson ↡ Advertisement Link to post Share on other sites More sharing options...
Air Purifier Discussion - tips and info
Interior wrapping
Interior wrapping
