SimplyTWL 1st Gear April 11, 2011 Share April 11, 2011 Hi guys, just wondering if any of you have this issue and how do you solve it. Over the weekend it was pouring rain heavily, and i drove my whole family out for dinner then realised that my rear left door is leaking. My mum who was sitting behind told me that. So how or what can i do to resolve this issue? Thanks in advance. ↡ Advertisement Link to post Share on other sites More sharing options...
Mystupidger Clutched November 16, 2012 Share November 16, 2012 BRO IS IT FIXED YET? SO WHATS THE ISSUE? having the same issue as well Link to post Share on other sites More sharing options...
QQDreamer 4th Gear November 16, 2012 Share November 16, 2012 check your door rubber seals, are they damaged? Link to post Share on other sites More sharing options...
Jtb 6th Gear November 16, 2012 Share November 16, 2012 Hi guys, just wondering if any of you have this issue and how do you solve it. Over the weekend it was pouring rain heavily, and i drove my whole family out for dinner then realised that my rear left door is leaking. My mum who was sitting behind told me that. So how or what can i do to resolve this issue? Thanks in advance. By right should not leak, even if you have parked more to the sun, it may take a long time to be brittle to leak. Change the gasket or install the shield if you have not done so. Link to post Share on other sites More sharing options...
Clementi123 Neutral Newbie August 8, 2013 Share August 8, 2013 So TS what's the actual cause of leak? Link to post Share on other sites More sharing options...
Barbarik Neutral Newbie August 8, 2013 Share August 8, 2013 Mine faced the same issue of water leaking through the rear door behind the driver seat. WS changed thw door seal but problem still not solved, even I had paid more than a hundred dollars. In the end, I open up the inner door panel and repasted the "clear plastic sheet". This sheet is to stop water from going into the car and divert it to the small water outlet located at the bottom of thw door. Cost me nothing. Hope that is the also the root cause of your problem. Link to post Share on other sites More sharing options...
Comnao 1st Gear August 8, 2013 Share August 8, 2013 yr car got accident before ? maybe the structure already bent. my prev mercedes also had this problem... ever since it kenna langgah. Link to post Share on other sites More sharing options...
Davidtoh Clutched September 11, 2013 Share September 11, 2013 mine also. i dont know how to stop it. Link to post Share on other sites More sharing options...
Subutai 3rd Gear September 11, 2013 Share September 11, 2013 Add another strip next to the current one. Mine not leaking. Got a free lancer to do my vios and it helps in noise reduction as well. Link to post Share on other sites More sharing options...
Ihave10cats Clutched September 14, 2013 Share September 14, 2013 i also wanted to know the solution. on and off like this for many times. Link to post Share on other sites More sharing options...
Jeff23 Neutral Newbie September 15, 2013 Share September 15, 2013 https://www.facebook.com/3mWindStrip Go this link. Buy and DIY. Hope it helps. Link to post Share on other sites More sharing options...
Peterjelly Clutched October 3, 2013 Share October 3, 2013 The rubber seals maybe damaged... Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 4, 2013 Share October 4, 2013 Hi guys, just wondering if any of you have this issue and how do you solve it. Over the weekend it was pouring rain heavily, and i drove my whole family out for dinner then realised that my rear left door is leaking. My mum who was sitting behind told me that. So how or what can i do to resolve this issue? Thanks in advance. Check the rubber seals if ty r properly fitted. Also the alignment of the door if out can let water in. Worst is u need to change the rubber door seals or window seals. Oh n chk if the door has rust all the way tru cos that wil also let water in. First u need to check where is the leak n solve from there. yr car got accident before ? maybe the structure already bent. my prev mercedes also had this problem... ever since it kenna langgah. Your repair was badly done. Door alignment out or the two sides not flush with each other. Can try to putty the affected part n paint. Sometimes it can solve the problem. ↡ Advertisement Link to post Share on other sites More sharing options...
Anyone into laopok Mercs?
Heavy and rain proof curtains/blinder recommendations?
Boy won hearts for sheltering bus passengers from rain
