JBara Neutral Newbie April 22, 2011 Share April 22, 2011 Hi there, I am having problem with my Hyundai Matrix 2005 Problem arise after battery changed. The "control unit and the fobs is out of sync". Means that my fob (transmitter) does not transmit any "Lock/Unlock" command. Will anyone please detail me the step/s to rectify this problem. Tried few procedures but doesn't work. Thanking you in advance Regards ↡ Advertisement Link to post Share on other sites More sharing options...
Topcom Neutral Newbie April 22, 2011 Share April 22, 2011 time to change car.. i had the issue also... quicky did a temp repair and sold it for 23k now got a Mitsubishi Delica Link to post Share on other sites More sharing options...
Picanto 3rd Gear April 22, 2011 Share April 22, 2011 time to change car.. i had the issue also... quicky did a temp repair and sold it for 23k now got a Mitsubishi Delica people come here ask for solution, yet you tell him to change car? you must be a real goondo head Link to post Share on other sites More sharing options...
KaKiLang 4th Gear April 22, 2011 Share April 22, 2011 people come here ask for solution, yet you tell him to change car? you must be a real goondo head He got his point. Link to post Share on other sites More sharing options...
JBara Neutral Newbie April 22, 2011 Author Share April 22, 2011 Sad Pocket not at brim there is a procedure to rectify the fob issue, I am sure about it, only to rectify it.....worst still changing to non-stock unit Link to post Share on other sites More sharing options...
Keithchue 5th Gear April 22, 2011 Share April 22, 2011 change the whole alarm system, should be a cheap fix since cars are expensive now. Link to post Share on other sites More sharing options...
JBara Neutral Newbie April 23, 2011 Author Share April 23, 2011 change the whole alarm system, should be a cheap fix since cars are expensive now. KIV for time being Using the key for entrance Link to post Share on other sites More sharing options...
Zappy 1st Gear April 23, 2011 Share April 23, 2011 Hi there, I am having problem with my Hyundai Matrix 2005 Problem arise after battery changed. The "control unit and the fobs is out of sync". Means that my fob (transmitter) does not transmit any "Lock/Unlock" command. Will anyone please detail me the step/s to rectify this problem. Tried few procedures but doesn't work. Thanking you in advance Regards mine guess, probably u have tried changing your car remote's battery, probably control unit could be faulty, replacing it should be cheaper than fixing it to solve your problem. a normal car alarm shouldn't cost you much. IMHO, if the source is spoilt, no amount of procedures will make it work again. ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback
Feedback
Dealer re-sell problem car
