Mecontle 1st Gear May 21, 2011 Share May 21, 2011 I compare a non-DSG box with paddleshift or sport gate (omitted since proven that DSG is faster than manual) 1 auto-box: rev to peak torque & upshift 2 manual-box: same is the 0-100 same for both? Anyone has experience on this? ↡ Advertisement Link to post Share on other sites More sharing options...
ER-3682 Twincharged May 21, 2011 Share May 21, 2011 (edited) I compare a non-DSG box with paddleshift or sport gate (omitted since proven that DSG is faster than manual) 1 auto-box: rev to peak torque & upshift 2 manual-box: same is the 0-100 same for both? Anyone has experience on this? I know the Nissan 370z 7 speed Auto is a bit faster than it manual ones. Edited May 21, 2011 by ER-3682 Link to post Share on other sites More sharing options...
Aaronlkl Supersonic May 21, 2011 Share May 21, 2011 (edited) I compare a non-DSG box with paddleshift or sport gate (omitted since proven that DSG is faster than manual) 1 auto-box: rev to peak torque & upshift 2 manual-box: same is the 0-100 same for both? Anyone has experience on this? In the hand of a skilled driver, manual should be faster. If its (dual clutch transimmsion) vs conventional manual, dual clutch should be faster. Hope this helps! Edited May 21, 2011 by Aaronlkl Link to post Share on other sites More sharing options...
Expertz 1st Gear May 21, 2011 Share May 21, 2011 1 auto-box: rev to peak torque & upshift 2 manual-box: same auto cars upshift at max rpm not max torque therefore unless you are comparing a 7 speed DSG vs a 6 speed manual, i believe the manual will surely be faster not sure about the newer transmissions like dual clutch manual though Link to post Share on other sites More sharing options...
Fennmax Clutched May 21, 2011 Share May 21, 2011 Auto WRX250bhp beat 5spd wrx 230bhp...400m race. Link to post Share on other sites More sharing options...
Mecontle 1st Gear May 21, 2011 Author Share May 21, 2011 >In the hand of a skilled driver, manual should be faster. I but can human shift faster than 0.2s? thats the pace of auto shift! >auto cars upshift at max rpm not max torque peak torque is at lower rpm than peak hp say we know the engine stats Eg. 180Nm@4000, 140hp@6000 then usually we upshift at past 4k rpm for best compromise >Auto WRX250bhp beat 5spd wrx 230bhp...400m race. I think ur right if bhp is too much then auto or manual no longer matters Link to post Share on other sites More sharing options...
Luv_presea 1st Gear May 21, 2011 Share May 21, 2011 Link to post Share on other sites More sharing options...
Nhrisuzu 1st Gear May 21, 2011 Share May 21, 2011 I think manual can shift faster than auto if the person really driving very spiritedly.. 4AT Sunny n a 5MT Sunny.. 4AT Vios vs 5MT Vios.. Compare same specs but gearbox variant is more fair than putting a 250BHP vs a 230BHP.. Link to post Share on other sites More sharing options...
Mecontle 1st Gear May 21, 2011 Author Share May 21, 2011 guys u didnt get the right topic , i meant shifting manually with an auto box vs shifting manually with a manual box, do u think both pickup speed are comparable? Link to post Share on other sites More sharing options...
ER-3682 Twincharged May 21, 2011 Share May 21, 2011 guys u didnt get the right topic , i meant shifting manually with an auto box vs shifting manually with a manual box, do u think both pickup speed are comparable? Then comfirmed Manually with an autobox faster,because in the 370z case,the pedal shift,my right hand just need to attack the 'up' pedal,the shift is instead. Link to post Share on other sites More sharing options...
A5SB 1st Gear May 21, 2011 Share May 21, 2011 guys u didnt get the right topic , i meant shifting manually with an auto box vs shifting manually with a manual box, do u think both pickup speed are comparable? Shift manual with auto box, when done correctly is always faster bro. Correctly means you keep the engine running at its peak torque as much as possible, and once the rpm starts to exit the peak torque band, you gotta shift. That said, if want fast, don't bother with conventional auto trans. Get either a DSG, or for much more fun, a good old trio pedal manual. That said I have to OT a bit a lament the decline of the MT. It's so much more fun and rewarding, it's fast, it's economical. For man who takes pride in their driving skills, an MT is the car to have at least once in your life time. Link to post Share on other sites More sharing options...
Expertz 1st Gear May 22, 2011 Share May 22, 2011 call himself driftking yet when he changes gears he lets his foot off the accelerator he'll be half a second faster if he continues to floor while changing gears, the additional rpm gain will help with a 6 speed gearbox Link to post Share on other sites More sharing options...
Octopus 3rd Gear May 22, 2011 Share May 22, 2011 I compare a non-DSG box with paddleshift or sport gate (omitted since proven that DSG is faster than manual) 1 auto-box: rev to peak torque & upshift 2 manual-box: same is the 0-100 same for both? Anyone has experience on this? I believe for straight road acceleration (0 ~ 100), DSG > manual > paddleshift. But if the location were at a winding and undulation road, then manual > paddleshift > DSG. Link to post Share on other sites More sharing options...
Mecontle 1st Gear May 22, 2011 Author Share May 22, 2011 After reading all ur replies I think it means if my factory spec says auto-box is 10s & manual-box is 9s then it means that with my sport gate shifter I should be near 9s, swee! Link to post Share on other sites More sharing options...
ER-3682 Twincharged May 22, 2011 Share May 22, 2011 After reading all ur replies I think it means if my factory spec says auto-box is 10s & manual-box is 9s then it means that with my sport gate shifter I should be near 9s, swee! There are many factors,to hit 9 ses to 100 km/h,you need to press your gas pedal to max,change your gear while your foot is pressing the gas pedal....also tires must pump a bit more air. Link to post Share on other sites More sharing options...
Ithunk 1st Gear May 22, 2011 Share May 22, 2011 could be triptronic could be manual no definitive answer Link to post Share on other sites More sharing options...
Watwheels Supersonic May 22, 2011 Share May 22, 2011 (edited) From the way the question is phrased no wonder ppl got confused. The way I see it it's a no brainer question. Regardless the auto has a manual override via paddleshift or it's a tiptronic autobox it's still an autobox which has a torque converter as a transmission medium to transfer power from the engine to the gearbox. And the fact is the engine speed is faster dan that of the transmission speed for an autobox. There will be a lag before the transmission speed catches up. So it will definitely be slightly slower dan a manual box no matter how the autobox's style of manual override is designed. Today's auto have improved a lot from those of the past where there's even more lag. Torque converter drum are slimer so that the oil takes less time to fill & drain, dan there's the lock up clutch to further reduce the difference in speed between engine & transmission. Actually ppl dun know that the torque converters are used in medium & heavy industry machinery like cranes. A crane also have a motor and a gearbox, in-between will be the torque converter to transfer the energy produced by the electric motor. In other words the torque converter existed before cars had them as a transmission medium. Edited May 22, 2011 by Watwheels Link to post Share on other sites More sharing options...
Jchuacl Clutched May 22, 2011 Share May 22, 2011 If the auto gearbox comes with high stall speed, then it'll match or could be slightly faster than manual. However, this setup is not common due to high heat generation. Most road cars comes with low stall speed to minimise the generation of heat, and hence it'll be slower than manual. ↡ Advertisement Link to post Share on other sites More sharing options...
Clutch
Clutch
BMW M Cars Are Done With DCTs, and Soon, Manuals Too
Looking for a manual car because real men use three pedals!
Advice: which web hosting good?
Honda Civic servicing... Which workshop to go?
