Shor 1st Gear June 12, 2011 Share June 12, 2011 Could this be the engine mounting problem? If so, is it necessary to change all four? I presumed not the Spark plug and wire because I had just change it. Any other possibilities bros?? Can someone recommend me workshop can diagnose what the actual problems with a minimum fee? Thank you! ↡ Advertisement Link to post Share on other sites More sharing options...
Alg 5th Gear June 12, 2011 Share June 12, 2011 Did you hit your exhuast pipe recently when you reverse park? Link to post Share on other sites More sharing options...
Shor 1st Gear June 12, 2011 Author Share June 12, 2011 No bro, I think it's nothing to do with my exhaust pipe. Did you hit your exhuast pipe recently when you reverse park? Link to post Share on other sites More sharing options...
Hermit 1st Gear June 12, 2011 Share June 12, 2011 It may well be the spark plug, due to misfiring.. eg, wrong rating.. Any CEL? Link to post Share on other sites More sharing options...
Shor 1st Gear June 12, 2011 Author Share June 12, 2011 At first I suspect to be the Spark Plug too, but second thought, I had just change my Spark plug month ago..... the biggest possibility suppose to be the engine mounting. But I am looking for a workshop that can diagnose it for a minimum fee. It may well be the spark plug, due to misfiring.. eg, wrong rating.. Any CEL? Link to post Share on other sites More sharing options...
Ithunk 1st Gear June 12, 2011 Share June 12, 2011 actually how bad is the vibration? if not jus go back to the workshop ask for the original spark plug Link to post Share on other sites More sharing options...
Shor 1st Gear June 12, 2011 Author Share June 12, 2011 Not terribly vibrate, but can feel the vibrate like the mirror shaking . This is not usual because all the while my car is very "quiet" one. actually how bad is the vibration? if not jus go back to the workshop ask for the original spark plug Link to post Share on other sites More sharing options...
Stanchiam 1st Gear June 12, 2011 Share June 12, 2011 Not terribly vibrate, but can feel the vibrate like the mirror shaking . This is not usual because all the while my car is very "quiet" one. could also be due to throttle dirty, check if dirty, clean it Link to post Share on other sites More sharing options...
Ithunk 1st Gear June 12, 2011 Share June 12, 2011 Not terribly vibrate, but can feel the vibrate like the mirror shaking . This is not usual because all the while my car is very "quiet" one. wow could be throttle body.... rear view mirror or side mirror shaking? Link to post Share on other sites More sharing options...
Tiger21 Clutched June 12, 2011 Share June 12, 2011 Just guessing... The cable to the spark plug connected in the wrong order? resulting in incorrect firing? Link to post Share on other sites More sharing options...
Latka 1st Gear June 12, 2011 Share June 12, 2011 Could this be the engine mounting problem? If so, is it necessary to change all four? I presumed not the Spark plug and wire because I had just change it. Any other possibilities bros?? Can someone recommend me workshop can diagnose what the actual problems with a minimum fee? Thank you! If mounting is the problem, not neccessary to change all 4, just change the one that has the problem. Link to post Share on other sites More sharing options...
ER-3682 Twincharged June 12, 2011 Share June 12, 2011 Could this be the engine mounting problem? If so, is it necessary to change all four? I presumed not the Spark plug and wire because I had just change it. Any other possibilities bros?? Can someone recommend me workshop can diagnose what the actual problems with a minimum fee? Thank you! Your Murano or GTR are both V6,if the vibration are so bad,most likely are the mountings. Link to post Share on other sites More sharing options...
Lowrider 2nd Gear June 12, 2011 Share June 12, 2011 Could this be the engine mounting problem? If so, is it necessary to change all four? I presumed not the Spark plug and wire because I had just change it. Any other possibilities bros?? Can someone recommend me workshop can diagnose what the actual problems with a minimum fee? Thank you! If it's an engine mounting, you can feel the vibration on your steering wheel. Is that the case? Link to post Share on other sites More sharing options...
Zoom99 Neutral Newbie June 13, 2011 Share June 13, 2011 If I'm correct, it is likely that your engine mounting is gone. Especially if you switch to reverse gear, the whole car will vibrate more. What is your mileage now? Link to post Share on other sites More sharing options...
Meganut 2nd Gear June 13, 2011 Share June 13, 2011 could be engine mounting (gasket) or could be drive shaft... cos im now stuck in my mechanic office for the past 2 hours getting my shaft fixed for the front two wheels... cos i thought its gasket problem but its not for my case, the virbration happens when it idle... the rear mirror shakes but the steering is ok... the virbration can be quite strong when stuck in jam or reversing slowly... Link to post Share on other sites More sharing options...
KaKiLang 4th Gear June 13, 2011 Share June 13, 2011 (edited) Your Murano or GTR are both V6,if the vibration are so bad,most likely are the mountings. Huh, GTR and you going to cheep workshop, changing back brake pads oridy, 500-600, changing the two gear boxes transmission fluid will cost 800-1000. Any workshop can do meh? Edited June 13, 2011 by KaKiLang Link to post Share on other sites More sharing options...
Shor 1st Gear June 13, 2011 Author Share June 13, 2011 GTR is my brother ride. Ya, I oso think is the Engine mount. I go check it out first see whether to change how many piece. And I'll try to clean the fuel injector see any different or not. Your Murano or GTR are both V6,if the vibration are so bad,most likely are the mountings. Link to post Share on other sites More sharing options...
Shor 1st Gear June 13, 2011 Author Share June 13, 2011 Steering quite minor vibrate, but steer extreme will feel more. Reversing oso can feel a it, so highly is the engine mounting worn. If it's an engine mounting, you can feel the vibration on your steering wheel. Is that the case? ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding - March 2024
Car fails to reverse out of HDB car park lot after 12 tries
Xiaomi EV is Coming
Xiaomi EV is Coming
Cars at Expo - Apr 2024
