Stratovarius Turbocharged July 27, 2017 Share July 27, 2017 sure it doesn't look as sporty or beautiful IMO, but the 800+kg kerb weight really does intrigue me. the recipe sounds good already It is rumored to be around 900kg. Even so, I wonder how the designers shave of 200kg from ZC32 and definitely a concern at high speeds. ↡ Advertisement Link to post Share on other sites More sharing options...
SGCMmaomao 6th Gear July 27, 2017 Share July 27, 2017 Evolving into an SUV Link to post Share on other sites More sharing options...
walkofwinners 4th Gear July 27, 2017 Share July 27, 2017 It is rumored to be around 900kg. Even so, I wonder how the designers shave of 200kg from ZC32 and definitely a concern at high speeds.Should be fine if they lower the centre of gravity closer to the ground and add in wider tires. This car is gonna fly like a beast. Link to post Share on other sites More sharing options...
Stratovarius Turbocharged July 27, 2017 Share July 27, 2017 Should be fine if they lower the centre of gravity closer to the ground and add in wider tires. This car is gonna fly like a beast. Swift is well known for high cg and thin stock tires and no downward force at stock condition. Thats why must zhng. Lol. Also. I refering to straight ways high speed. My zc31 @ 1.1ton already feels very floaty @ 150 kph. Link to post Share on other sites More sharing options...
Sugimoto 6th Gear July 27, 2017 Share July 27, 2017 I think this 1.4 turbo engine may come from fiat's bravo. They have some sort of agreement earlier. Link to post Share on other sites More sharing options...
walkofwinners 4th Gear July 27, 2017 Share July 27, 2017 (edited) I think this 1.4 turbo engine may come from fiat's bravo. They have some sort of agreement earlier. Engine is fine as long as not a similar transmission! Edited July 27, 2017 by walkofwinners Link to post Share on other sites More sharing options...
Soya Supersonic July 27, 2017 Share July 27, 2017 Engine is fine as long as not a similar transmission!Or built by the same Italians...... 1 Link to post Share on other sites More sharing options...
TheRingFan 1st Gear July 27, 2017 Share July 27, 2017 i think they have already confirmed that they will be using the 1.4T engine from the vitara S? i'm really excited about the power + the lightened chasis though. Link to post Share on other sites More sharing options...
Stratovarius Turbocharged July 27, 2017 Share July 27, 2017 i think they have already confirmed that they will be using the 1.4T engine from the vitara S? i'm really excited about the power + the lightened chasis though.1.4 boosterjet.I think is developed by suzuki. The vitara s is quite well received. Ya, its quite exciting to see it on a lighter and stiffer chasis. Also hope that the engine will be tuned differently than the vitara s. Link to post Share on other sites More sharing options...
TheRingFan 1st Gear July 27, 2017 Share July 27, 2017 1.4 boosterjet.I think is developed by suzuki. The vitara s is quite well received. Ya, its quite exciting to see it on a lighter and stiffer chasis. Also hope that the engine will be tuned differently than the vitara s. yeah totally! i hope it is tuned differently too. Link to post Share on other sites More sharing options...
Eyke Supercharged August 5, 2017 Share August 5, 2017 (edited) don't understand y they like to have the speedo from 0 all the way to 260km/h when the top speed is only ~190km/h... Edited August 5, 2017 by Eyke Link to post Share on other sites More sharing options...
Jamesc Hypersonic August 5, 2017 Share August 5, 2017 (edited) don't understand y they like to have the speedo from 0 all the way to 260km/h when the top speed is only ~190km/h... In case you add a bigger turbo and chip it so you see how fast you are going. Edited August 5, 2017 by Jamesc Link to post Share on other sites More sharing options...
Stratovarius Turbocharged August 5, 2017 Share August 5, 2017 don't understand y they like to have the speedo from 0 all the way to 260km/h when the top speed is only ~190km/h... I think that is the speed limiter. A regulation for the japanese car manufacturers. The old ss can reach 220, max speed at the odo after ecu reflash and removing the speed limiter. Before the that, the speed limiter would kick in around 190, 200 and drop the speed to around 180. Nice to see to zero for both dials is at the 6 o clock position. A tribute to suzuki's heritage in bike manfacturing. Link to post Share on other sites More sharing options...
Vratenza Supersonic August 5, 2017 Share August 5, 2017 They do have suzuki swift in Germany/autobahn right? don't understand y they like to have the speedo from 0 all the way to 260km/h when the top speed is only ~190km/h... Link to post Share on other sites More sharing options...
Eyke Supercharged August 6, 2017 Share August 6, 2017 They do have suzuki swift in Germany/autobahn right?the road top speed might not be limited, but the car's top speed is Link to post Share on other sites More sharing options...
CbCoe Neutral Newbie September 5, 2017 Share September 5, 2017 Woohoo.. megasport zc31s parts available at carousell . Time for shopping !! Link to post Share on other sites More sharing options...
DilshanDre Neutral Newbie January 14, 2019 Share January 14, 2019 Hey all, I just test drove a 2007 Swift Sports A/T. One issue I realised was that when accelerating hard from a stop/low speed, the engine hits the rev limiter for a second before shifting up. Would anyone know whether this is something I should be worried about? Thanks! Link to post Share on other sites More sharing options...
Hosaybo 6th Gear November 17, 2019 Share November 17, 2019 https://m.sgcarmart.com/used_cars/info.php?ID=867762 Any comments or inputs if this is a worth buy for coe renewal? Think can negotiate down but any inputs on the fair value? ↡ Advertisement Link to post Share on other sites More sharing options...
Swift Owners
Swift Owners
singaporean in WWE
singaporean in WWE
Any Swift 1.2 XG owner?
Turf City closes 31 Dec 2023
2018 Toyota Supra
2018 Toyota Supra
[Spyshots] 2023 Suzuki Jimny Long
