Garlic 1st Gear March 6, 2012 Share March 6, 2012 (edited) My 2 cents if I may, have only used it on light colors (white and silver). Prep procedure is similar for both products. I personally find Nano Clear more user friendly as it gives more "feedback" during application, its also more forgiving. OC 1.0 cures within an hour and you discover a streak after that, the only way to remove it is to repeat prep and application procedure on entire panel. As for durability, its still too early to tell as its only been couple of weeks since I applied Nano Clear on the other car. OC 1.0 has been on my white car below for a year and water is still sheeting off surface like day one, car is parked outdoors all the tie. Edited March 6, 2012 by Garlic ↡ Advertisement Link to post Share on other sites More sharing options...
Garlic 1st Gear March 6, 2012 Share March 6, 2012 Some comparisson going on.... OC hazes in the heat on dark colors? Interesting finding, might be worth the effort starting a discuss at OPT's tech forum. Link to post Share on other sites More sharing options...
Maddriver 4th Gear March 29, 2012 Author Share March 29, 2012 Thanks for sharing Bro Garlic.. Link to post Share on other sites More sharing options...
Maddriver 4th Gear May 14, 2012 Author Share May 14, 2012 The Opti-Coat 2.0 will be here this week..Opti-Guard for professional will be here as well.. Link to post Share on other sites More sharing options...
Optivax 1st Gear July 22, 2012 Share July 22, 2012 OptiGuard 10cc/40cc and Opticoat 2.0 consumer will be here this 2 days..place your order now.. Link to post Share on other sites More sharing options...
Antirain Neutral Newbie July 26, 2012 Share July 26, 2012 Hi just check with you before applying opti coat 2.0 need to polish our car first?? If I feel not satisfy the result can I remove it using what kind of product? Link to post Share on other sites More sharing options...
Yixiang1 3rd Gear July 26, 2012 Share July 26, 2012 How does DG and opti compare against this new thing called permanon and recently w permanon gloss enhancer? Newbie to detailing.. Advice greatly appreciated. Link to post Share on other sites More sharing options...
Optivax 1st Gear July 26, 2012 Share July 26, 2012 Hi just check with you before applying opti coat 2.0 need to polish our car first?? If I feel not satisfy the result can I remove it using what kind of product? Hi..if you wish to remove this coating..a buffing machine with cutting compound will remove it Link to post Share on other sites More sharing options...
Optivax 1st Gear July 26, 2012 Share July 26, 2012 How does DG and opti compare against this new thing called permanon and recently w permanon gloss enhancer? Newbie to detailing.. Advice greatly appreciated. Hi yixiang..i am sorry that i cant provide you any information or comments.on the products you mentioned..you can try to google..there should be some info and answers for your questions. Try this www.autopia.org Link to post Share on other sites More sharing options...
Seanboi 1st Gear July 26, 2012 Share July 26, 2012 How does DG and opti compare against this new thing called permanon and recently w permanon gloss enhancer? Newbie to detailing.. Advice greatly appreciated. There are a couple of reviews on page 3. Link to post Share on other sites More sharing options...
Maddriver 4th Gear July 27, 2012 Author Share July 27, 2012 For application..both are easy to use.. Link to post Share on other sites More sharing options...
Eeee78 Neutral Newbie July 30, 2012 Share July 30, 2012 How does DG and opti compare against this new thing called permanon and recently w permanon gloss enhancer? Newbie to detailing.. Advice greatly appreciated. I had tried the Permanon before. I will give it a miss, the DG 951 works better IMHO in terms of application method. Link to post Share on other sites More sharing options...
Anyname Neutral Newbie July 31, 2012 Share July 31, 2012 Permanon is not in the same league, glossy easy to apply but not very permanent. forgive the pun. Price disproportionately expensive for the length of coverage. Got free bottle to give away. Link to post Share on other sites More sharing options...
Arixlim Clutched July 31, 2012 Share July 31, 2012 where to get free bottle..? Link to post Share on other sites More sharing options...
Seanboi 1st Gear August 16, 2012 Share August 16, 2012 Anyone can comment on the durability of the Duragloss Nano glass? Link to post Share on other sites More sharing options...
Firestorm_33 Neutral Newbie August 18, 2012 Share August 18, 2012 Anyone can comment on the durability of the Duragloss Nano glass? had test it on my bike last year when bro benny brought in the sample.... till date, haven't polish but the shine and looks is definitely still there :) Link to post Share on other sites More sharing options...
Optivax 1st Gear September 27, 2012 Share September 27, 2012 This is the very first VW POLO when Opticoat landed.. The car was prep and coated by the owner aka Garlic in mcf too ..It lasted more than a year and is still going strong.. Link to post Share on other sites More sharing options...
Optivax 1st Gear October 4, 2012 Share October 4, 2012 Extreme testing on opticoat. Do not try it at home... testing of opticoat..extreme This is only on opticoat 2.0 consumer version..not to mention the optiguard professional series.. ↡ Advertisement Link to post Share on other sites More sharing options...
Optimum No Rinse Wash & Shine
Clear your plates or kena orh gong ah
Attention all Duragloss #951 Aquawax user.
How to clear kitchen choked floor piping?
[INCIDENT] SIA A380 experienced severe clear air turbulence
Recommended car coating?
Heavy duty clear garbage bag
Condensation in headlight(s)
