Tom_kkh 1st Gear July 27, 2011 Share July 27, 2011 When i go above 110km/h, i brake, the steering vibrate, low speed like 80-100 no such problem. whts wrong, wheel balancing? also nowadays, in the morning, when i start the car, the brake will give a onnnnn onnnn sound when moving straight without me applying the brakes. simi taichi ar? it goes off after a while... ↡ Advertisement Link to post Share on other sites More sharing options...
MG_Myvi 1st Gear July 27, 2011 Share July 27, 2011 When i go above 110km/h, i brake, the steering vibrate, low speed like 80-100 no such problem. whts wrong, wheel balancing? also nowadays, in the morning, when i start the car, the brake will give a onnnnn onnnn sound when moving straight without me applying the brakes. simi taichi ar? it goes off after a while... Should be wheel balancing. As for the sound...it applies to me on most morning leh. I'm immune to it. Link to post Share on other sites More sharing options...
Sky_vinz Clutched July 27, 2011 Share July 27, 2011 Tom_kkh: From what I know, it is mainly due to the lack of these: - Wheel balancing (to provide an even weight all round) - High speed balancing (if steering wheel vibrate at higher speed) However, if vibration only appears during braking, there is a possibility that your rotors have warped (uneven surface). Link to post Share on other sites More sharing options...
MG_Myvi 1st Gear July 27, 2011 Share July 27, 2011 Tom_kkh: From what I know, it is mainly due to the lack of these: - Wheel balancing (to provide an even weight all round) - High speed balancing (if steering wheel vibrate at higher speed) However, if vibration only appears during braking, there is a possibility that your rotors have warped (uneven surface). Bro...Agreed. You are right on the rotors issue. Link to post Share on other sites More sharing options...
Beachboy7718 Clutched July 27, 2011 Share July 27, 2011 When i go above 110km/h, i brake, the steering vibrate, low speed like 80-100 no such problem. whts wrong, wheel balancing? also nowadays, in the morning, when i start the car, the brake will give a onnnnn onnnn sound when moving straight without me applying the brakes. simi taichi ar? it goes off after a while... It is rotor brake disc got warped behavior. It happens on high speed on steering virbation. You may have workshop to skim the disc for you. Link to post Share on other sites More sharing options...
Tom_kkh 1st Gear July 27, 2011 Author Share July 27, 2011 aiyo, than better servicing that time ask them check check.... Link to post Share on other sites More sharing options...
Bullterrier Clutched July 27, 2011 Share July 27, 2011 When i go above 110km/h, i brake, the steering vibrate, low speed like 80-100 no such problem. whts wrong, wheel balancing? also nowadays, in the morning, when i start the car, the brake will give a onnnnn onnnn sound when moving straight without me applying the brakes. simi taichi ar? it goes off after a while... If you only experience the vibrations when braking at speeds your brake rotor is unevenly worn. U need replacements or have the rotors sent for lathe skimming if its not too bad and the rotor thickness still good. Link to post Share on other sites More sharing options...
Calvin79 2nd Gear July 27, 2011 Share July 27, 2011 When i go above 110km/h, i brake, the steering vibrate, low speed like 80-100 no such problem. whts wrong, wheel balancing? also nowadays, in the morning, when i start the car, the brake will give a onnnnn onnnn sound when moving straight without me applying the brakes. simi taichi ar? it goes off after a while... i had the same problem witht eh onnnn onnnn sound too... did u have your brake pads changed? my WS reason to me was because the pad is too close against and will be fine after a while... but honestly now after 1 month the sound is gone Link to post Share on other sites More sharing options...
Civic_newb Neutral Newbie July 27, 2011 Share July 27, 2011 I believe wheel balancing or brake disc is having problem, don't play play, better check soon! Link to post Share on other sites More sharing options...
Tom_kkh 1st Gear July 28, 2011 Author Share July 28, 2011 i had the same problem witht eh onnnn onnnn sound too... did u have your brake pads changed? my WS reason to me was because the pad is too close against and will be fine after a while... but honestly now after 1 month the sound is gone no its old brakes. think mostly like most broi say, the rotor problem.... dono can claim under warranty a not.... will get it check tomorrow Link to post Share on other sites More sharing options...
JaydenSTI 1st Gear July 28, 2011 Share July 28, 2011 hijack this tread for a question, ps ts.... just collected my ride after servicing ytd, ws told me my front brake pads worn out, so i agreed to change. similar to ts case, my steering wheel vibrated when brake around 90-80kph, but it is intermittent..... notice that harder braking (no very hard, as breaking in in process...) no issue, light braking vibrate furiously (but not all the time)...... no such problem before servicing...... any sifus here got any advice??? anyway will be going back to ws again tmr..... wasting time..... Link to post Share on other sites More sharing options...
Jayc Clutched July 28, 2011 Share July 28, 2011 I had similar issues before, normal drive steering vibrating on and off, vibrates alot during braking, check to see if your brake rotors have uneven marks as mine was somehow scratched badly by the brake pad which came loose! Link to post Share on other sites More sharing options...
MG_Myvi 1st Gear July 28, 2011 Share July 28, 2011 From what I know is that if changed to performance brake pads....some stock rotor cannot tahan the grip...will eventually get uneven or so. That's why some car owners choosed to change rotors and brakes to performance type or stick everything to stock. Link to post Share on other sites More sharing options...
SimonTan 2nd Gear July 28, 2011 Share July 28, 2011 My car also got the vibration during braking. I think it's the rotor not smooth. Don't know can claim warranty or not......brake rotor consider wear and tear item. Link to post Share on other sites More sharing options...
MG_Myvi 1st Gear July 28, 2011 Share July 28, 2011 My car also got the vibration during braking. I think it's the rotor not smooth. Don't know can claim warranty or not......brake rotor consider wear and tear item. If not wrong...Rotor I think can....but as usual lah....AD will start telling grandfather stories when comes to claiming. I ever heard of people claiming but forgot what brand of cars liao. Link to post Share on other sites More sharing options...
Beachboy7718 Clutched July 28, 2011 Share July 28, 2011 I claim once before with disc rotor as when it is new one. After 10kkm, it start to virbate at high speed during braking. As this is 2.4 liter car and heavier abit, the AD start to refuse changing.. after kept compaining, then they change free for you. Normally it shall last longer. As I know many ppl complaining due to inferior rotor disc from Thailand mfg. I drove japan made model, it works well without the problem. So keep complaining if it is new one and from AD, they will eventually change for you. Also remember, after long hour drive and brake, never send your car for washing.. if you can see the steam come out when the cleaner spray the water on it. It will deform the rotor disc with warpages... then the problem comes again. ↡ Advertisement Link to post Share on other sites More sharing options...
Fatty Kim going crazy again
Washing machine front loading
Brake Pads
Brake Pads
Going to Polyclinic
Going to Polyclinic
Indonesia high-speed railway still beset by problems
Front lower arm and suspension questions
