Jujitsuka 4th Gear August 19, 2011 Share August 19, 2011 hi Bros, any advice to regards to the above mentioned situation? when it rev to 3.5k rpm will have this smell? my frds say need to flush my engine... Is it true? ↡ Advertisement Link to post Share on other sites More sharing options...
Carbine- Clutched August 19, 2011 Share August 19, 2011 aircon filter changed? isit old?.. do a check on it? Link to post Share on other sites More sharing options...
Otoko Neutral Newbie August 19, 2011 Share August 19, 2011 could be due for oil change or oil leakage causing burning smell on other engine components~ whichever u still need a workshop check~ if its aircon issue, consider a compressor change liao~ Link to post Share on other sites More sharing options...
Serag15 Neutral Newbie August 19, 2011 Share August 19, 2011 (edited) Only during high revs? My guess is carbon soot smell. Experienced before with my car.. ur car has got more then 70k mileage? Edited August 19, 2011 by Serag15 Link to post Share on other sites More sharing options...
JaydenSTI 1st Gear August 19, 2011 Share August 19, 2011 hi Bros, any advice to regards to the above mentioned situation? when it rev to 3.5k rpm will have this smell? my frds say need to flush my engine... Is it true? ever drove a sibei lok (quite a new car actually, just that nvr maintain properly) estima years ago, also got chao tah smell whenever i revved. The owner changed the whole tranny few weeks later. all the best to you. Link to post Share on other sites More sharing options...
Ken4555 1st Gear August 19, 2011 Share August 19, 2011 hi Bros, any advice to regards to the above mentioned situation? when it rev to 3.5k rpm will have this smell? my frds say need to flush my engine... Is it true? i also got chao tar smell from my car when i high rev... thats redline all 1st.. 2nd.. 3rd... 4th hardly red line... then 5th mission impossible to redline... sure confirm have chao tar smell... but seriously my experience tells me cars which hardly high rev (eg. grandma's car)... when ever drive hard abit only sure smthing smells burnt... could be so many things.. the dust in the engine.. the pads.. the brakes... the etc.... Link to post Share on other sites More sharing options...
Samula Neutral Newbie August 19, 2011 Share August 19, 2011 your engine may be leaking oil at the front gaskets Link to post Share on other sites More sharing options...
Jujitsuka 4th Gear August 19, 2011 Author Share August 19, 2011 Only during high revs? My guess is carbon soot smell. Experienced before with my car.. ur car has got more then 70k mileage? Ya smells like soot smell... Will it be ok if i juz flushed my engine? Link to post Share on other sites More sharing options...
Bighappyjer 1st Gear August 19, 2011 Share August 19, 2011 i thought that's the carbon smell, quite normal what.. maybe running too rich. Link to post Share on other sites More sharing options...
Mecontle 1st Gear August 19, 2011 Share August 19, 2011 hi Bros, any advice to regards to the above mentioned situation? when it rev to 3.5k rpm will have this smell? my frds say need to flush my engine... Is it true? hey hey hey , last time my new daihatsu auto 1.3 sirion same problem if rev from 0-90, thick plastic burnt smell, some say its tyre smell cos not season, i think its to do with the cheapskate engine & tranny Link to post Share on other sites More sharing options...
Kia0042 2nd Gear August 19, 2011 Share August 19, 2011 Only during high revs? My guess is carbon soot smell. Experienced before with my car.. ur car has got more then 70k mileage? My ride decarbonized at 50k mileage and it's now 100k. Plastic burnt smell during high revs and I have consulted more than 3 workshops and nobody knows how to solve the problem, sighs~~~ Link to post Share on other sites More sharing options...
Ken4555 1st Gear August 20, 2011 Share August 20, 2011 your engine may be leaking oil at the front gaskets i change my oil 5k internals... always check the engine for leaks... even put news papaer beneath oevernite... no gasket leaks... Link to post Share on other sites More sharing options...
Ken4555 1st Gear August 20, 2011 Share August 20, 2011 wah lau... everyone here you all serious anot?... i have whacked/trashed numurous cars... you whack to the redline non-stop for awhile SURE got abit of burning smell whatever ever car lah... some makes are better quality built so sound proofing better which means the smell less likely to get in cabin... PERIOD... and pls engine flushing is NOT going to get rid if this problem which is not even a problem... *faints* Link to post Share on other sites More sharing options...
Hamburger Hypersonic August 20, 2011 Share August 20, 2011 forget about flushing....it only serves to made things worth Link to post Share on other sites More sharing options...
WFME Neutral Newbie August 25, 2011 Share August 25, 2011 It is only during REALLY EXTREME CASES that the high rev cause the smell. When I mean extreme cases, I'm talking about track conditions and cases at the blink of engine failure which I can quite safely assume is not the case for you. Typically, the smell is caused by 3 things (excluding the cases above) from cheapest to most expensive 1) Dirty Air System (ie, A/C system is contaminated with dirt and/or bacterial) Solutions: a) Remove any air or smell purifiers you are currently using for at least a month to see if causes residue to be left behind in the A/C system. b) Change your A/C (pollen) filter c) Put Pandan Leaves & Charcoal in the car to absorb as much of the smell as possible d) Use A/C hygiene spray to purge the air system. 2) Clogged A/C discharge pipe a) Unless you know where it is, how to do it and have the right tools like a compressor, get your mechanic to purge the discharge pipe. It is often stuck causing a build-up of water and thus the rotting smell. 3) Contaminated Compressor a) Often, residue from air purifiers (cheapo ones and those not suitable for cars) get stuck there along with tons of other nonsense. Pending on the model of your car, this may cost quite a bit but may be worth it in the long run as excessive dirt may lead to pre-mature failures. Try out the first before the other 2 as, from experience, it solves 60% of the cases within a month or so. Hope this helps. Link to post Share on other sites More sharing options...
Rongshu Neutral Newbie August 25, 2011 Share August 25, 2011 My latio sometimes also have similar smell only during hard acc around 3k rpm. sent to TC and let them test. but during test drive didn't have such smell. I guess it is the clutch, maybe it is slipping during hard rev. Although my latio is cvt, there is also a clutch. Link to post Share on other sites More sharing options...
WFME Neutral Newbie August 25, 2011 Share August 25, 2011 My latio sometimes also have similar smell only during hard acc around 3k rpm. sent to TC and let them test. but during test drive didn't have such smell. I guess it is the clutch, maybe it is slipping during hard rev. Although my latio is cvt, there is also a clutch. Unless it's REALLY BAD, most of the time the smell is due to the aircon (please also check that the A/C is at internal mode, the picture of a car with a circular arrow INSIDE the car and NOT external, picture of a car with arrow pointing from outside to inside of the car. Anywaz, from experience, the A/C compressor of the Latio (especially the older models) seems to be their "weak point". My aircon man replace an average of 3 a month... Link to post Share on other sites More sharing options...
Pisces69 6th Gear August 25, 2011 Share August 25, 2011 hi Bros, any advice to regards to the above mentioned situation? when it rev to 3.5k rpm will have this smell? my frds say need to flush my engine... Is it true? Check if any of yr belts r slipping? ↡ Advertisement Link to post Share on other sites More sharing options...
Home Aircon
Home Aircon
Yes, ‘old person smell’ is a thing – but what causes it and can you neutralise it?
ACS boy dies during high adventure course
7% GST for Netflix and Spotify coming in 2020
