Pisces69 6th Gear August 25, 2011 Share August 25, 2011 i also got chao tar smell from my car when i high rev... thats redline all 1st.. 2nd.. 3rd... 4th hardly red line... then 5th mission impossible to redline... sure confirm have chao tar smell... but seriously my experience tells me cars which hardly high rev (eg. grandma's car)... when ever drive hard abit only sure smthing smells burnt... could be so many things.. the dust in the engine.. the pads.. the brakes... the etc.... Yr chao tar smell is yr clutch burning or yr tires slipping as u rev to the end of the world. Or maybe yr engine oil or gearoil dried up already? ↡ Advertisement Link to post Share on other sites More sharing options...
Pisces69 6th Gear August 25, 2011 Share August 25, 2011 Ya smells like soot smell... Will it be ok if i juz flushed my engine? When u blow yr engine, look behind at yr exhaust. Is it smoking? If not, then not carbon lah. Link to post Share on other sites More sharing options...
WFME Neutral Newbie August 25, 2011 Share August 25, 2011 When u blow yr engine, look behind at yr exhaust. Is it smoking? If not, then not carbon lah. Typically, your engine will overheat before it blows (though it can happen VERY FAST which is why some performance cars has a water/engine temp warning meter). Interesting note is that as your car overheats, most modern cars have a safety cut off that reduces the load (ie, A/C cut off) of the car to reduce stress on engine. So in some cases, the A/C will cut off then you realize your car is overheating. There is a chance that it's "burning clutch or engine smell" but from your description, don't really seem like it. You really have to be honest to yourself here if it smell only appears at high rev or excessive 1/2 clutch. Link to post Share on other sites More sharing options...
Ken4555 1st Gear August 25, 2011 Share August 25, 2011 My latio sometimes also have similar smell only during hard acc around 3k rpm. sent to TC and let them test. but during test drive didn't have such smell. I guess it is the clutch, maybe it is slipping during hard rev. Although my latio is cvt, there is also a clutch. what car got no clutch? Link to post Share on other sites More sharing options...
Ken4555 1st Gear August 25, 2011 Share August 25, 2011 It is only during REALLY EXTREME CASES that the high rev cause the smell. When I mean extreme cases, I'm talking about track conditions and cases at the blink of engine failure which I can quite safely assume is not the case for you. Typically, the smell is caused by 3 things (excluding the cases above) from cheapest to most expensive 1) Dirty Air System (ie, A/C system is contaminated with dirt and/or bacterial) Solutions: a) Remove any air or smell purifiers you are currently using for at least a month to see if causes residue to be left behind in the A/C system. b) Change your A/C (pollen) filter c) Put Pandan Leaves & Charcoal in the car to absorb as much of the smell as possible d) Use A/C hygiene spray to purge the air system. 2) Clogged A/C discharge pipe a) Unless you know where it is, how to do it and have the right tools like a compressor, get your mechanic to purge the discharge pipe. It is often stuck causing a build-up of water and thus the rotting smell. 3) Contaminated Compressor a) Often, residue from air purifiers (cheapo ones and those not suitable for cars) get stuck there along with tons of other nonsense. Pending on the model of your car, this may cost quite a bit but may be worth it in the long run as excessive dirt may lead to pre-mature failures. Try out the first before the other 2 as, from experience, it solves 60% of the cases within a month or so. Hope this helps. wah lau... we are talking about CHAO TAR... BURNING SMELL... not SMELLY SMELL... Link to post Share on other sites More sharing options...
Ken4555 1st Gear August 25, 2011 Share August 25, 2011 Typically, your engine will overheat before it blows (though it can happen VERY FAST which is why some performance cars has a water/engine temp warning meter). Interesting note is that as your car overheats, most modern cars have a safety cut off that reduces the load (ie, A/C cut off) of the car to reduce stress on engine. So in some cases, the A/C will cut off then you realize your car is overheating. There is a chance that it's "burning clutch or engine smell" but from your description, don't really seem like it. You really have to be honest to yourself here if it smell only appears at high rev or excessive 1/2 clutch. P69 probably mean 'blow' engine as in 'rev' the engine... 'throttle' the engine... not blow engine as in the pistons seize... Link to post Share on other sites More sharing options...
Jchuacl Clutched August 25, 2011 Share August 25, 2011 I had that smell for the first 50k whenever I redline at 8k+ rpm. After that, it went away and I didn't really bother. i also got chao tar smell from my car when i high rev... thats redline all 1st.. 2nd.. 3rd... 4th hardly red line... then 5th mission impossible to redline... sure confirm have chao tar smell... but seriously my experience tells me cars which hardly high rev (eg. grandma's car)... when ever drive hard abit only sure smthing smells burnt... could be so many things.. the dust in the engine.. the pads.. the brakes... the etc.... Link to post Share on other sites More sharing options...
Yuan 6th Gear August 25, 2011 Share August 25, 2011 It is only during REALLY EXTREME CASES that the high rev cause the smell. When I mean extreme cases, I'm talking about track conditions and cases at the blink of engine failure which I can quite safely assume is not the case for you. Typically, the smell is caused by 3 things (excluding the cases above) from cheapest to most expensive 1) Dirty Air System (ie, A/C system is contaminated with dirt and/or bacterial) Solutions: a) Remove any air or smell purifiers you are currently using for at least a month to see if causes residue to be left behind in the A/C system. b) Change your A/C (pollen) filter c) Put Pandan Leaves & Charcoal in the car to absorb as much of the smell as possible d) Use A/C hygiene spray to purge the air system. 2) Clogged A/C discharge pipe a) Unless you know where it is, how to do it and have the right tools like a compressor, get your mechanic to purge the discharge pipe. It is often stuck causing a build-up of water and thus the rotting smell. 3) Contaminated Compressor a) Often, residue from air purifiers (cheapo ones and those not suitable for cars) get stuck there along with tons of other nonsense. Pending on the model of your car, this may cost quite a bit but may be worth it in the long run as excessive dirt may lead to pre-mature failures. Try out the first before the other 2 as, from experience, it solves 60% of the cases within a month or so. Hope this helps. Thanks for sharing. Some of it is correct and this is informative. Link to post Share on other sites More sharing options...
Yuan 6th Gear August 25, 2011 Share August 25, 2011 Yr chao tar smell is yr clutch burning or yr tires slipping as u rev to the end of the world. Or maybe yr engine oil or gearoil dried up already? That is the Ken we all know..... Link to post Share on other sites More sharing options...
Yuan 6th Gear August 25, 2011 Share August 25, 2011 wah lau... everyone here you all serious anot?... i have whacked/trashed numurous cars... you whack to the redline non-stop for awhile SURE got abit of burning smell whatever ever car lah... some makes are better quality built so sound proofing better which means the smell less likely to get in cabin... PERIOD... and pls engine flushing is NOT going to get rid if this problem which is not even a problem... *faints* Next time I see a smelly or smoky Sunny, I know it is you. Link to post Share on other sites More sharing options...
Mazda-6 1st Gear August 26, 2011 Share August 26, 2011 Bro, could be your a/c dampers, they open and shut when u switch the a/c mode from internal to external. Maybe they are not shut fully, hence when u rev hard, u get that chow tar smell, could be anything thats causing the smell, oil hitting exhaust, water from road, brakes etc. If I were you, go to any a/c w/s and shut ur dampers using duct tape, its not like we use recirculation mode often, in fact cant really recall when I touched that button. My 2 cents worth. I could be wrong though, but its worth a try. FYI, mine has that smell too when I rev hard, but it goes away just as quickly, it don really bother me, so I live with it. Cheers, have a good weekend. Link to post Share on other sites More sharing options...
Raytham Neutral Newbie August 26, 2011 Share August 26, 2011 hey hey hey , last time my new daihatsu auto 1.3 sirion same problem if rev from 0-90, thick plastic burnt smell, some say its tyre smell cos not season, i think its to do with the cheapskate engine & tranny Friend, my daihatsu 1.5 also the same case as yours. haha. Link to post Share on other sites More sharing options...
Jujitsuka 4th Gear August 26, 2011 Author Share August 26, 2011 Thk you bros for all the kind advice! Tink i will just let my wkshop do a thorough checkup for my next servicing lol... Link to post Share on other sites More sharing options...
Ken4555 1st Gear August 26, 2011 Share August 26, 2011 Next time I see a smelly or smoky Sunny, I know it is you. ???... i tink in your eyes i'm juz a boy racer who likes to thrash cars... Link to post Share on other sites More sharing options...
Pisces69 6th Gear August 26, 2011 Share August 26, 2011 what car got no clutch? Toy car? Link to post Share on other sites More sharing options...
Pisces69 6th Gear August 26, 2011 Share August 26, 2011 P69 probably mean 'blow' engine as in 'rev' the engine... 'throttle' the engine... not blow engine as in the pistons seize... Oh ya hor. I was wondering what he meant. Hahaha. Thanks fr clarifying. Link to post Share on other sites More sharing options...
Pisces69 6th Gear August 26, 2011 Share August 26, 2011 That is the Ken we all know..... Dont play play with Ken hor. I think he has the only 2 seater Sunny around. Link to post Share on other sites More sharing options...
Ken4555 1st Gear August 26, 2011 Share August 26, 2011 Dont play play with Ken hor. I think he has the only 2 seater Sunny around. okok... this i need to clarify.... my rear shocks are set slighty softer then i think i should... and the last time (which was my 1st time ever in this car)... i fetch 3 meimeis behind and 1 infront... thats 5pax in my car never ever before... my toyos kanna my back fender and rubber was scraped off... it could have exploded... now i have slightly harded my back shocks... lower abit the tyre profile... and i afraid to let histiry repeat itself mah... some more desaru road i not sure mah... and also i had so much rubbish in my back seat... ↡ Advertisement Link to post Share on other sites More sharing options...
Car air-con
Car air-con
Home Aircon
Home Aircon
Yes, ‘old person smell’ is a thing – but what causes it and can you neutralise it?
ACS boy dies during high adventure course
