Stooky 6th Gear August 27, 2011 Share August 27, 2011 this morning while turning into the MSCP slope, accidentally scratch the front bumper against the wall. no dents but there are white paint marks on the front bumper roughly the size of a 50 cent coin. will Scratch X be able to remove the scratches completely? thanks in advance ↡ Advertisement Link to post Share on other sites More sharing options...
Rustyz 5th Gear August 27, 2011 Share August 27, 2011 Is the car paint still intact? It would be good if u can upload a photo of the damage then we can access and discuss Link to post Share on other sites More sharing options...
Mintt 1st Gear August 27, 2011 Share August 27, 2011 depends on how deep is your scratch. if the metal can be seen, then no use. if just the coating, can use autoglyn super resin polish to polish it off. Link to post Share on other sites More sharing options...
Optivax 1st Gear August 27, 2011 Share August 27, 2011 If it hits the prime coat..sand down wif 2500 grit sand paper then keep polishing..may see the line mark only after polish Link to post Share on other sites More sharing options...
Yeobh 4th Gear August 27, 2011 Share August 27, 2011 Polishing with buffer coated with very fine abrasive may help. Link to post Share on other sites More sharing options...
5936 1st Gear August 28, 2011 Share August 28, 2011 White paint marks from MSCP wall. Usually the steps will be progressive, starting with washing, and waxing. If cannot then move on with polish and later rubbing compound. Link to post Share on other sites More sharing options...
Stooky 6th Gear August 28, 2011 Author Share August 28, 2011 managed to polish off the white paint marks. luckily the car paint is still intact! took me 1 hr to polish off the marks ↡ Advertisement Link to post Share on other sites More sharing options...
Car vandals are petty losers
Is this minor scratch or it hits the primer already?
Need Repair on removing scratches
Coated, still getting water marks and scratches
Removing Scratches on Headlight - Head light Polishing
Removing old wax....
Yishun Residents saved cats from hdb fire
Removing smell lying beneath leather car seat
