3dwin Neutral Newbie September 14, 2011 Share September 14, 2011 Hi, anyone using the Mobile-i f1000 DVR for their car? I would like to check if is it a must to use the cable and 12V power adapter provided by them in order for the auto start and off to work when the car engine is switched on or off? I have set mine to recycle: 500m but use my old car camera's USB cable to power it and it won't start or stop by itself when I on or stop my engine. I have yet to use the cable provided by them to try. Hope someone can enlighten me on this point. Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Unfair 3rd Gear September 14, 2011 Share September 14, 2011 i think you have to wait 10-15s after pulling out your key for it to stop. if you just off your engine, your electricals are still running. Link to post Share on other sites More sharing options...
3dwin Neutral Newbie September 14, 2011 Author Share September 14, 2011 it did not even start in the first place when I start my engine or turn the key to on position. Link to post Share on other sites More sharing options...
Adrianli Hypersonic September 14, 2011 Share September 14, 2011 Read the manual. If its same as DOD-tec, u must select USB-in then it will auto start and stop. Sorry, I dont have this car cam. Just my guessing. Link to post Share on other sites More sharing options...
3dwin Neutral Newbie September 14, 2011 Author Share September 14, 2011 Read the manual. If its same as DOD-tec, u must select USB-in then it will auto start and stop. Sorry, I dont have this car cam. Just my guessing. Thanks Adrian...I have the DOD too...but this one does not have the USB in selection....sigh Link to post Share on other sites More sharing options...
Shochong Clutched September 14, 2011 Share September 14, 2011 Hi, anyone using the Mobile-i f1000 DVR for their car? I would like to check if is it a must to use the cable and 12V power adapter provided by them in order for the auto start and off to work when the car engine is switched on or off? I have set mine to recycle: 500m but use my old car camera's USB cable to power it and it won't start or stop by itself when I on or stop my engine. I have yet to use the cable provided by them to try. Hope someone can enlighten me on this point. Thanks Hi there, Have tested before like you, the auto start & record only works with the original charger it comes with. Hope this will clear your doubt. Cheers~ Link to post Share on other sites More sharing options...
3dwin Neutral Newbie September 14, 2011 Author Share September 14, 2011 ok. i have tested liao. must use the cable supplied with car camera in order for the auto start and stop to work. Link to post Share on other sites More sharing options...
0wnage 2nd Gear October 5, 2011 Share October 5, 2011 Hi, can someone who uses the mobile-i F1000 tell me what's recycle? I don't get the 300M/500M/No in the menu. What's the best setting for the EV, contrast and sharpness too? Thanks in advance for reading Link to post Share on other sites More sharing options...
0wnage 2nd Gear October 6, 2011 Share October 6, 2011 anyone? Link to post Share on other sites More sharing options...
TVT Supercharged October 6, 2011 Share October 6, 2011 Did u buy it locally from one of those sponsors? If so u can asked them... I think EV is to control the brightness. My cam I set it to '0'. Link to post Share on other sites More sharing options...
3dwin Neutral Newbie October 6, 2011 Author Share October 6, 2011 hi. the ev, i left it as default which is auto. as for the size of file, 300m is about 8 mins of recording and 500m is about 13 mins of recording per file. hope i have answered your query. Link to post Share on other sites More sharing options...
Dafansu Turbocharged October 7, 2011 Share October 7, 2011 Is this cam good. Seems to be one of the more popular models? Link to post Share on other sites More sharing options...
3dwin Neutral Newbie October 7, 2011 Author Share October 7, 2011 Is this cam good. Seems to be one of the more popular models? I find it not bad. Good in day and night recording. very clear. Link to post Share on other sites More sharing options...
Changky 1st Gear October 7, 2011 Share October 7, 2011 I have to re-set date and time every time when i start on a trip with f1000 esply after parking for a few hours. Has anyone met with this problem? Link to post Share on other sites More sharing options...
3dwin Neutral Newbie October 7, 2011 Author Share October 7, 2011 I have to re-set date and time every time when i start on a trip with f1000 esply after parking for a few hours. Has anyone met with this problem? Let me check and confirm on this point. will get back to you Link to post Share on other sites More sharing options...
3dwin Neutral Newbie October 7, 2011 Author Share October 7, 2011 Let me check and confirm on this point. will get back to you I have checked mine. not problem with the date and time problem. maybe you shd disconnect from the power source and see if your build in battery can power up the set after half day or so. If cannot, I think it is the build in battery having problem. Cheers Link to post Share on other sites More sharing options...
Changky 1st Gear October 7, 2011 Share October 7, 2011 Thanks for the reply. When connected to the car, the dvr battery showed fully charged. Once removed from power source, it indicates low battery. Now charging the dvr at home and see if the battery is functioning properly. Link to post Share on other sites More sharing options...
0wnage 2nd Gear October 7, 2011 Share October 7, 2011 I've just started using it a few days ago. There's no problem with the date and time for me. The video quality is very good too anyway, thanks 3dwin for your answer! ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding - March 2024
Xiaomi EV is Coming
Xiaomi EV is Coming
Cars at Expo - Apr 2024
UMIDIGI mobile phone
