Where to buy?
Anakusop
Hi. Anyone have any suggestions as to where to buy a rubber hose/connector for open pod piping? Just need the connector. Piping not needed. What is the price range also? Thanks.
At most you could get the wire reinforced fabric ductings. black only. usually open pod guys used this. material or the aluminium ducting.
Fabric ducting available at Kelantan Lane, blk 20+, below the MSCP, where there is coffee shop with laksa opposite Ah Boy bike shop. There are a few hardware shops along the ground floor. At least 2 of them sell these ducts.
1 ft is around $15, IIRC.
You will also need stainless hose clips too.
Edited by 5936
u can try Manz Exhaust, bot from them before a 90 and 45 degree silicone elbox for open pod. Cant remember their address already, long time back.
otherwise u can always try autobacs but they charge a premium usually
Edited by Dice
Thanks bros! Will try the hardware store first. Im assuming its gonna cost cheaper than wkshps. If cant find any will just head down to Man exhaust.
it will be good to bring the open pod filter and other hard pipings if they are of different diameter.
They carry small diameter in 3-4 inchs.
Thats correct ask for black flexible fabric wired hose. By now, if you show them the open pod filter, they will also know what you'll need.
Remember, check out 2-3 stores first.
I found that the first shop just beside the defunct Jln Besar NPP is more expensive.
Hope you'll find what you want, and if you like laksa, it's also at around the area.
