  • Search this thread
  • Reply to this topic
32 replies to this topic | 305 praises
#1
Posted 26 October 2011 - 07:20 AM
Ysc3
  • THREAD STARTER
  • Premium member
    Ysc3
    2Fast2Furious
    Author Image
    21,442
anyone using these type of portable aircon for their rooms ? how is the noise level ? and is it cold enuff ?
(sample image from google)
#2
Posted 26 October 2011 - 07:28 AM
Rustyz
  • Premium member
    Rustyz
    6th Gear
    Author Image
    4,531
Depend on ur room size?
It is not really air con, it is more like putting a wet cloth before your fan. A lot problem if u don't use regularly like algae in the tank and so on. If u want it to be cooler, just add cold water to the water tank.
Noise level like a normal fan.
Go for a window unit, which I personally think it is a better buy.
Edited by Rustyz, 26 October 2011 - 07:32 AM.
If anyone can have it, I don't want it.
#3
Posted 26 October 2011 - 08:44 AM
Ysc3
  • THREAD STARTER
  • Premium member
    Ysc3
    2Fast2Furious
    Author Image
    21,442
i am asking about portable aircon with BTU specs, eg : http://portableairco...ortable_air-con
not air-coolers.
problem is i am not staying in the master bedroom so cannot install window unit. as for split, too much hassle and like renovation liddat.
so i am actually using a casement a/c fitted on my sliding window frame at the moment ... but it gets kinda noisy/
Edited by Ysc3, 26 October 2011 - 08:45 AM.
#4
Posted 26 October 2011 - 10:11 AM
Rustyz
  • Premium member
    Rustyz
    6th Gear
    Author Image
    4,531
Sorry my bad the photo look like air cooler.
Where are u planning to put the compressor? I think it can be quite noisy(Humming) and hot.
#5
Posted 26 October 2011 - 10:12 AM
Acanthus
  • Acanthus
    3rd Gear
    Author Image
    398
i am using the Europace 12k BTU portable aircon.
Noise level is acceptable and it is able to cool the master room to about 22 ~ 24 degree celcius (depending on the weather outside)
Only problem is that there is the outlet pipe that you need to attach to your window, and the adapter does not fit all types of windows(especially older ones) so you have to make some modifications on your part.
Power usage i would say is much higher than a normal wall unit but what the heck, at least it is easier to re-sell when you dun need it anymore.
#6
Posted 26 October 2011 - 10:19 AM
Friendstar
  • Friendstar
    NOS-ed
    Author Image
    17,327
I have one from Trends
#7
Posted 26 October 2011 - 08:56 PM
Ysc3
  • THREAD STARTER
  • Premium member
    Ysc3
    2Fast2Furious
    Author Image
    21,442
installation shud be something like this is it ??
ie, place a board on the sliding window and then just put the venting tube into a hold on the board to extract the hot air ?
#8
Posted 26 October 2011 - 08:57 PM
Ysc3
  • THREAD STARTER
  • Premium member
    Ysc3
    2Fast2Furious
    Author Image
    21,442
do you have a pic of your install ? maybe this week want to see if carrefour got offer or not ....
Edited by Ysc3, 26 October 2011 - 08:57 PM.
#9
Posted 03 November 2011 - 06:37 PM
Cheepo
  • Cheepo
    5th Gear
    Author Image
    1,317
I checked out a brand called Splendid a few years ago. Felt quite powerful. I remember seeing a showroom with all their products but cannot remember where now...
#10
Posted 03 November 2011 - 07:56 PM
Cdior
  • Cdior
    Banned
Not worth the $. I hv 1 in my living rm. Not cold 1.
400 NM to U!
#11
Posted 03 November 2011 - 08:29 PM
Fcw75
  • Fcw75
    2Fast2Furious
    Author Image
    69,129
http://www.azvac.net/
268 Balestier Road.
#12
Posted 03 November 2011 - 08:59 PM
Cheepo
  • Cheepo
    5th Gear
    Author Image
    1,317
I saw this type, which is different as it has 2 parts, in a temporary office today...
Anyone knows if it is better?
#13
Posted 10 June 2017 - 04:19 PM
RH1667
  • Premium member
    RH1667
    2Fast2Furious
    Author Image
    114,448
Is there any portable air con that don't need the venting? So can be moved anywhere around the home.
Staff69 and 2BDriver praised this
#14
Posted 10 June 2017 - 05:16 PM
Volvobrick
  • Volvobrick
    2Fast2Furious
    Author Image
    32,573
Scientifically an impossible task...... You cool things down by extracting heat from it and you have to dump this heat somewhere (and it has to be at a higher temperature than surrounding).
Unless you use ice packs and blow air over it.
#15
Posted 10 June 2017 - 05:52 PM
Ender
  • Premium member
    Ender
    2Fast2Furious
    Author Image
    70,891
I have been using alot face towel wet it with tap water at home wiping my body every now and then. Machiam like hawker. Most economical way to cool your body at home.
You don’t stop running because you get old, you get old because you stop running.
#16
Posted 10 June 2017 - 08:52 PM
RH1667
  • Premium member
    RH1667
    2Fast2Furious
    Author Image
    114,448
Oh, I see.
Thank you
Pinobii praised this
#17
Posted 10 June 2017 - 09:19 PM
Mustank
  • Mustank
    2Fast2Furious
    Author Image
    109,227
Got one tech call absorption chilling
I not engineer so I don't understand it
Think it uses heat to make air cool
But machinery very big
Still2016 praised this
#18
Posted 10 June 2017 - 10:49 PM
Freeder
  • Premium member
    Freeder
    2Fast2Furious
    Author Image
    94,077
Portable air con very noisy one hor...
Like using generators... no joke..
Think u buy air cooler better..put ice n ice packs into the container n slim design too..confirm got cold air out..
Pinobii, Still2016 and Uncle2 praised this
I'm always learning how to drive...
#19
Posted 10 June 2017 - 10:57 PM
RH1667
  • Premium member
    RH1667
    2Fast2Furious
    Author Image
    114,448
Thank you for the review and recommendation.
Still2016, Uncle2, JustGoodTrades, Pinobii, Carbon82, Angcheek, Sunny and 8 other members praised this
#20
Posted 10 June 2017 - 11:50 PM
Mustank
  • Mustank
    2Fast2Furious
    Author Image
    109,227
Quick Reply
Tags: Portable, aircon
