Nastrix 1st Gear November 15, 2011 Share November 15, 2011 I intend to change my tyre for my odyssey to Michelin PS3 215/55/R17Any user pls share your thoughts on its performance and the noise level.Appreciate the feedback ↡ Advertisement Link to post Share on other sites More sharing options...
Arowana1 1st Gear November 15, 2011 Share November 15, 2011 i hv this on my e90 for >30,000km. grip in wet and dry so damn good, i hv yet to lose confident when taking corners or long winding roads. better than my csc3. sidewall is hard so good for corners even with higher sidewall cos my profile is 225/45/r17. just lower tyre pressure a bit for a more comfortable ride. noise is loud (on some road surface) when compared to comfort tyres but so much quieter than other sports range (e.g. falken, dunlop, eagle). great tyres for daily drives and occasional sprint. and peace of mind. Link to post Share on other sites More sharing options...
Kch32 Neutral Newbie November 15, 2011 Share November 15, 2011 i hv this on my e90 for >30,000km. grip in wet and dry so damn good, i hv yet to lose confident when taking corners or long winding roads. better than my csc3. sidewall is hard so good for corners even with higher sidewall cos my profile is 225/45/r17. just lower tyre pressure a bit for a more comfortable ride. noise is loud (on some road surface) when compared to comfort tyres but so much quieter than other sports range (e.g. falken, dunlop, eagle). great tyres for daily drives and occasional sprint. and peace of mind. then do you think PS3 is better than CSC3? Is CSC3 quieter than PS3? Link to post Share on other sites More sharing options...
Byond 1st Gear November 15, 2011 Share November 15, 2011 PS3 is good. in wet or dry highly recommended Although its a sports tyre, but noise level, is much more better than GY E F1, Re001, Yoko S drive... Link to post Share on other sites More sharing options...
Hoppie24 1st Gear November 15, 2011 Share November 15, 2011 losy tires, wear rate is super fast, if you have money to burn buy it, confirm wear out within 6months+ And when it's old, it's super noisy. CSC5 is out and CSC3 225/40R18 having promo now at all tire shop $250 to $260 per piece. Link to post Share on other sites More sharing options...
Patricklyb Clutched November 15, 2011 Share November 15, 2011 losy tires, wear rate is super fast, if you have money to burn buy it, confirm wear out within 6months+ And when it's old, it's super noisy. CSC5 is out and CSC3 225/40R18 having promo now at all tire shop $250 to $260 per piece. i installed mine during june and so fur no sign of wearing out....... btw there are two version.....asia or euro made,which i is yours? Link to post Share on other sites More sharing options...
Fourth 2nd Gear November 15, 2011 Share November 15, 2011 noise is loud (on some road surface) when compared to comfort tyres but so much quieter than other sports range (e.g. falken, dunlop, eagle). That means it is quiet. Make no sense to compare noise level with comfort tires. Link to post Share on other sites More sharing options...
Patricklyb Clutched November 16, 2011 Share November 16, 2011 That means it is quiet. Make no sense to compare noise level with comfort tires. the noise is consider veri quiet when travelling at 120km.....but sometmes depend on road conditions also. Link to post Share on other sites More sharing options...
Kudass Neutral Newbie November 16, 2011 Share November 16, 2011 (edited) i also have thought to change PS3 to my FD1 soon. but was recommended by SA to go for bridgestone GR90 as it is equally good. is it true? Edited November 16, 2011 by Kudass Link to post Share on other sites More sharing options...
Elmo 4th Gear November 16, 2011 Share November 16, 2011 Hi. I've been on PS3 225/45R17 since last Dec. Think the wear-rate's pretty good. At least better than my last Eagle Revspec. For a sports tyre the wear rate is good compared to CSC3 and BS RE050. I tracked with the PS3 at PG and the grip in dry is very good. At the optimal pressure of 32psi, they grip very well under hard cornering. Wet grip is good compared to my earlier Falkens and Eagles. They are noisy compared to CSC3 but not that far off from similar class tyres like RE001. If you want comfort over handling, the CSC3 may be a better choice as the sidewall of CSC3 is softer. Though the CSC3 will wear out faster, it is offset by a comfortable and quiet ride. Chk out CSC5 since it is already out. I haven't got a chance to try them out yet. Cheers! Link to post Share on other sites More sharing options...
Kch32 Neutral Newbie November 16, 2011 Share November 16, 2011 Hi. I've been on PS3 225/45R17 since last Dec. Think the wear-rate's pretty good. At least better than my last Eagle Revspec. For a sports tyre the wear rate is good compared to CSC3 and BS RE050. I tracked with the PS3 at PG and the grip in dry is very good. At the optimal pressure of 32psi, they grip very well under hard cornering. Wet grip is good compared to my earlier Falkens and Eagles. They are noisy compared to CSC3 but not that far off from similar class tyres like RE001. If you want comfort over handling, the CSC3 may be a better choice as the sidewall of CSC3 is softer. Though the CSC3 will wear out faster, it is offset by a comfortable and quiet ride. Chk out CSC5 since it is already out. I haven't got a chance to try them out yet. Cheers! i personally think that the sidewall for PS3 is softer than the CSC3. but overall, both tyres are excellent. Link to post Share on other sites More sharing options...
Eyke Supercharged November 16, 2011 Share November 16, 2011 buy PSS or GY E F1 Asym 2! Link to post Share on other sites More sharing options...
Hermes_1 Neutral Newbie November 16, 2011 Share November 16, 2011 Hey bros/ sis, Any idea if any shops having promo for Michelin PS3 size 205/45/r16? Thks & regards. Link to post Share on other sites More sharing options...
Mcf777 Turbocharged November 16, 2011 Share November 16, 2011 buy PSS or GY E F1 Asym 2! Asym2 damn good during raining season. Link to post Share on other sites More sharing options...
Patricklyb Clutched November 16, 2011 Share November 16, 2011 Hey bros/ sis, Any idea if any shops having promo for Michelin PS3 size 205/45/r16? Thks & regards. what promo....buy 3 get 1? u will be lucky if got stock deal to flood to thailand Link to post Share on other sites More sharing options...
Hermes_1 Neutral Newbie November 16, 2011 Share November 16, 2011 what promo....buy 3 get 1? u will be lucky if got stock deal to flood to thailand Ps3 MIT? I meant Xmas promo or something similar. Link to post Share on other sites More sharing options...
Mcf777 Turbocharged November 16, 2011 Share November 16, 2011 PS3 agent tyre is MIT. PI may be very Italy, hungary etc Link to post Share on other sites More sharing options...
Patricklyb Clutched November 16, 2011 Share November 16, 2011 Ps3 MIT? I meant Xmas promo or something similar. PS3 are produced in asia and also euro.... price wise asia cheaper than euro. im using 225/45/17 made in spain cos $245pc to $190pc mit. ↡ Advertisement Link to post Share on other sites More sharing options...
[Official] 2024 3rd Generation Porsche Panamera
Indonesia's Batik Air faces probe after pilots fall asleep mid-flight
Attention all Duragloss #951 Aquawax user.
