Yattokame 4th Gear November 16, 2011 Share November 16, 2011 Hi guys, need some help here. My uncle commented that his friends are all raving about this device, when plugged into the cigarette lighter, makes the car smoother/more powerful and saves fuel too. sells about $200++ I'm guessing it's some kind of voltage stabilizer but I thought that usually goes next to the car battery in the engine compartment.... anybody has any clue? thanx in advance ↡ Advertisement Link to post Share on other sites More sharing options...
Bluepica 4th Gear November 16, 2011 Share November 16, 2011 Hi guys, need some help here. My uncle commented that his friends are all raving about this device, when plugged into the cigarette lighter, makes the car smoother/more powerful and saves fuel too. sells about $200++ I'm guessing it's some kind of voltage stabilizer but I thought that usually goes next to the car battery in the engine compartment.... anybody has any clue? thanx in advance kena conned? Sounds like those devise plug at home wall outlet and help saves electricity bills Link to post Share on other sites More sharing options...
Luckcent 4th Gear November 16, 2011 Share November 16, 2011 So good, just plug in and car is performing......What are the car manufacturers doing ? Sleeping !!!!@!!!!!!! Link to post Share on other sites More sharing options...
Yattokame 4th Gear November 16, 2011 Author Share November 16, 2011 I'm also doubting the efficacy of this device. But my uncle was sold - he tried it over a week and swears by it. He asked if I know anything about it so I'm just checking here. Link to post Share on other sites More sharing options...
Vhtfhwlego Supercharged November 16, 2011 Share November 16, 2011 Sometimes it is just a case of believing it works. Link to post Share on other sites More sharing options...
Kklim Supercharged November 16, 2011 Share November 16, 2011 Matt black with green LED? Link to post Share on other sites More sharing options...
Eyke Supercharged November 16, 2011 Share November 16, 2011 yeah, it's called "placebo effect" Link to post Share on other sites More sharing options...
Rogersk8ter 1st Gear November 16, 2011 Share November 16, 2011 (edited) yes, that what my boss says" better perform otherwise u get plugged". i wonder he was actually talking abt this device? :huh: Edited November 16, 2011 by Rogersk8ter 1 Link to post Share on other sites More sharing options...
The_Bear Turbocharged November 16, 2011 Share November 16, 2011 yes, that what my boss says" better perform otherwise u get plugged". i wonder he was actually talking abt this device? :huh: 4" dia. Butt Plug. Link to post Share on other sites More sharing options...
Mecontle 1st Gear November 16, 2011 Share November 16, 2011 i put obama name on the edge , ur all gana con , its a sound device that micmic lambo v8 sound or what hv u when u rev so u feel faster , its on fifth gear tv episode b4 Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged November 16, 2011 Share November 16, 2011 kena conned? Sounds like those devise plug at home wall outlet and help saves electricity bills im 1 of the idiot who spent 200+ many yrs ago on those devise plug at home wall outlet and help saves electricity bills [:(] Link to post Share on other sites More sharing options...
Yc86 Clutched November 17, 2011 Share November 17, 2011 How it works is that the device emits electrons (via some ionizer or crystal thingy inside that vibrates). The electrons travel from the ciggy socket into the cars electrical system, where it can top up the spark plugs and give it extra electricity boost when required (i.e when u floor the car). More sparks = better combustion = higher efficiency = more power and save fuel at the same time. When driving normally, the extra electricity inside relieves the load on the alternator, so your engine don't have to keep charging the battery. Therefore you save a bit of fuel in that aspect also. Is this explanation good enough? Link to post Share on other sites More sharing options...
Nightsky 1st Gear November 17, 2011 Share November 17, 2011 Matt black with green LED? ECO device? Link to post Share on other sites More sharing options...
Celicar Turbocharged November 17, 2011 Share November 17, 2011 More sparks = better combustion = higher efficiency = more power and save fuel at the same time. Er, also got limit right. Otherwise then it is just a straightforward case of just dumping in sparks. Link to post Share on other sites More sharing options...
Moredhel 2nd Gear November 17, 2011 Share November 17, 2011 How it works is that the device emits electrons (via some ionizer or crystal thingy inside that vibrates). The electrons travel from the ciggy socket into the cars electrical system, where it can top up the spark plugs and give it extra electricity boost when required (i.e when u floor the car). More sparks = better combustion = higher efficiency = more power and save fuel at the same time. When driving normally, the extra electricity inside relieves the load on the alternator, so your engine don't have to keep charging the battery. Therefore you save a bit of fuel in that aspect also. Is this explanation good enough? Why don't the car owners just install another alternator then? Pump up the ign coils input from 14V to 28V in series. Link to post Share on other sites More sharing options...
Jonjees 1st Gear November 17, 2011 Share November 17, 2011 Hi guys, need some help here. My uncle commented that his friends are all raving about this device, when plugged into the cigarette lighter, makes the car smoother/more powerful and saves fuel too. sells about $200++ I'm guessing it's some kind of voltage stabilizer but I thought that usually goes next to the car battery in the engine compartment.... anybody has any clue? thanx in advance ya its called marijuana ionizer. Link to post Share on other sites More sharing options...
Qms Neutral Newbie November 17, 2011 Share November 17, 2011 It's amazing that in this day and age, still got many people who willingly splash money on false promises. All you need is lots of marketing, false testimonials, put it in a nice package, and idiots will buy it. VS is just as useless as a couple of capacitors put in a nice box. Make it blink and you sell even more. Link to post Share on other sites More sharing options...
Moredhel 2nd Gear November 17, 2011 Share November 17, 2011 It's amazing that in this day and age, still got many people who willingly splash money on false promises. All you need is lots of marketing, false testimonials, put it in a nice package, and idiots will buy it. VS is just as useless as a couple of capacitors put in a nice box. Make it blink and you sell even more. I been bitten by snake oils, but voltage banks does have it's uses. Of coz the theoretical overblown promises are simply, well, overblown.... ↡ Advertisement Link to post Share on other sites More sharing options...
Anyone into laopok Mercs?
Weekend car driving into Malaysia
Anyone into Thai amulet?
Is Something Big Coming To California, USA ?
Plug-and-play vaccine
