Qms Neutral Newbie November 17, 2011 Share November 17, 2011 I been bitten by snake oils, but voltage banks does have it's uses. Of coz the theoretical overblown promises are simply, well, overblown.... Capacitors has its uses when put at the end devices, not put on the battery. The battery itself is a huge capacitors. I've seen a few circuits that a cap is also present at the alternator as well. It's not as if it's useless and need aftermarket VS to fill that void. But that could also be said for grounding cables. There are plenty of grounding cables around the car. When it's hidden no one sees it. They go buy nice coloured grounding cables and put inside the engine bay to show off. If your car really need those "nice" grounding cables, a lot of devices would not have worked in the first place. ↡ Advertisement Link to post Share on other sites More sharing options...
Happily1986 5th Gear November 17, 2011 Share November 17, 2011 Hi guys, need some help here. My uncle commented that his friends are all raving about this device, when plugged into the cigarette lighter, makes the car smoother/more powerful and saves fuel too. sells about $200++ I'm guessing it's some kind of voltage stabilizer but I thought that usually goes next to the car battery in the engine compartment.... anybody has any clue? thanx in advance pray tell whats the name of this product? I am guessing Placebo? Link to post Share on other sites More sharing options...
The_Bear Turbocharged November 17, 2011 Share November 17, 2011 It's amazing that in this day and age, still got many people who willingly splash money on false promises. All you need is lots of marketing, false testimonials, put it in a nice package, and idiots will buy it. VS is just as useless as a couple of capacitors put in a nice box. Make it blink and you sell even more. How do you think we vote for the President? Link to post Share on other sites More sharing options...
LoverofCar 6th Gear November 17, 2011 Share November 17, 2011 Hi guys, need some help here. My uncle commented that his friends are all raving about this device, when plugged into the cigarette lighter, makes the car smoother/more powerful and saves fuel too. sells about $200++ I'm guessing it's some kind of voltage stabilizer but I thought that usually goes next to the car battery in the engine compartment.... anybody has any clue? thanx in advance I have a device that use can charge the car battery via the cigarette lighter 12V outlet....If the battery is flat.....Just plug in for 10 min and the battery will be charged up , enough for a car start... but never heard of such a device that can boost fuel and power.. Link to post Share on other sites More sharing options...
Yc86 Clutched November 17, 2011 Share November 17, 2011 Er, also got limit right. Otherwise then it is just a straightforward case of just dumping in sparks. [laugh] yes.. gort limit. the limit r the laws of physics n conservation. Why don't the car owners just install another alternator then? Pump up the ign coils input from 14V to 28V in series. good idea.. there is this electrical motor + alternator, 2 in 1. the engine charges the alternator when the car is not moving. When the car is moving, the stored power runs the electric motor to provide the charging instead. this saves the engine from having power loss in turning the alternator, = more power and less fuel consumption also. the thread is still about fantasy sci-fi devices right Link to post Share on other sites More sharing options...
Yattokame 4th Gear November 17, 2011 Author Share November 17, 2011 LOL my guess was as good as u guys - snake oil; but what to do? my uncle swears by snake oil.... that it turns his car into a rocket overnight. anyway i was just trying to find out something about it. never said i would promote buying one. Link to post Share on other sites More sharing options...
5936 1st Gear November 17, 2011 Share November 17, 2011 Yes, efficiency can be achieved with cars designed to operate on higher voltages. This was already in history, after it was the norm for 12V and 24V standards. Link to post Share on other sites More sharing options...
Picanto 3rd Gear November 17, 2011 Share November 17, 2011 Hi guys, need some help here. My uncle commented that his friends are all raving about this device, when plugged into the cigarette lighter, makes the car smoother/more powerful and saves fuel too. sells about $200++ I'm guessing it's some kind of voltage stabilizer but I thought that usually goes next to the car battery in the engine compartment.... anybody has any clue? thanx in advance can you take a photo of this device? Link to post Share on other sites More sharing options...
Yattokame 4th Gear November 17, 2011 Author Share November 17, 2011 can you take a photo of this device? I haven't seen it before, and my uncle only used it for a short while for trial. Link to post Share on other sites More sharing options...
Yc86 Clutched November 17, 2011 Share November 17, 2011 LOL my guess was as good as u guys - snake oil; but what to do? my uncle swears by snake oil.... that it turns his car into a rocket overnight. anyway i was just trying to find out something about it. never said i would promote buying one. u know what you can do.. Ask to borrow the device, then unscrew the part which sticks into the ciggy socket. Inside should have a fuse, spring and plunger thingy, place something like a plastic tab in between the plunger and fuse to open the circuit. Return to him n see whether he notice any difference or not after that. [laugh] but i think this kind of device usually have LED light which glows/pulse or something. Partly psychological reason - gives visual feedback to the driver that it is doing something. Link to post Share on other sites More sharing options...
Jansonfinn Neutral Newbie February 21, 2012 Share February 21, 2012 I have a device that use can charge the car battery via the cigarette lighter 12V outlet....If the battery is flat.....Just plug in for 10 min and the battery will be charged up , enough for a car start... but never heard of such a device that can boost fuel and power.. This device is very useful! Where can I get it? Link to post Share on other sites More sharing options...
Kwanheng 1st Gear April 5, 2012 Share April 5, 2012 total bull shyt. ask the seller to strip this device and let us see what's in side. maybe all we see is just led and registers. Link to post Share on other sites More sharing options...
Ken4555 1st Gear April 5, 2012 Share April 5, 2012 Hi guys, need some help here. My uncle commented that his friends are all raving about this device, when plugged into the cigarette lighter, makes the car smoother/more powerful and saves fuel too. sells about $200++ I'm guessing it's some kind of voltage stabilizer but I thought that usually goes next to the car battery in the engine compartment.... anybody has any clue? thanx in advance i saw a blue one... called sixth element or smthing... also saw some Japanese brands hving this device all the logic makes sense... improvement in your ride could be like 0.00001% lol i remember i had some 2T poured into a nice container, gave a colleague and told him it was some fuel enhancer... he used it and said wah smoother more power better mileage etc... when i told him 2T he got so worried his car will spoilt etc and was damn pissed with me... btw i've been using 2T for 2yrs+ liao its great... no wet plugs no fouling... even tried moth balls etc... (but was on company's vehicle) engine was like on steriods lol Link to post Share on other sites More sharing options...
Ken4555 1st Gear April 5, 2012 Share April 5, 2012 Link to post Share on other sites More sharing options...
Vhtfhwlego Supercharged April 5, 2012 Share April 5, 2012 u looking for something to poke plug is it??? so old thread & u go dig out... Link to post Share on other sites More sharing options...
Ken4555 1st Gear April 5, 2012 Share April 5, 2012 u looking for something to poke plug is it??? so old thread & u go dig out... hey not i dig out one leh.... yah hor so old liao the thread... opps btw yes i like poking n pluging... lol Link to post Share on other sites More sharing options...
Aeromania 1st Gear April 5, 2012 Share April 5, 2012 ku ku bird? Link to post Share on other sites More sharing options...
Kwanheng 1st Gear April 12, 2012 Share April 12, 2012 by the way moth balls myth does work. just don't add to much.. ↡ Advertisement Link to post Share on other sites More sharing options...
Anyone into laopok Mercs?
Weekend car driving into Malaysia
Anyone into Thai amulet?
Is Something Big Coming To California, USA ?
Plug-and-play vaccine
