ahbeng5220 1st Gear May 7, 2018 Share May 7, 2018 You juddering problem at low speed. Has it resolved? Curious to know. Thanks. Judder happens again on 1-1.2k rpm, zzzz. Shall have new pak file to update the gb firmware version. But not sure will it solve the problems or not. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
jg2000 4th Gear May 7, 2018 Share May 7, 2018 (edited) Judder happens again on 1-1.2k rpm, zzzz. Shall have new pak file to update the gb firmware version. But not sure will it solve the problems or not. Maybe book your gb firmware update on Fri. Weekend drive around in areas that don't have jams. Maybe that would help give a better start to the relearning. Also don't stick so close to car in front so that you don't need to brake so often. Look further up front to anticipate traffic also. All these should help give a smoother trip and better relearning for the cvt. Edited May 8, 2018 by jg2000 Link to post Share on other sites More sharing options...
Fuelsaver Supercharged May 8, 2018 Share May 8, 2018 As far as fc is concern.... Not much different for me 1/2 tank travel about 400km 1/4 tank travel about 500 odd km Just that about 8ltrs different ... Yes, pretty much enjoy the drive of the subby car character ... Very in control with the car. Each have it good and bad... For xv - just the cabinet noisy isolation not as good as qq.... Otherwise .... go no comment and being enjoy driving.... Hope to get my ice setup during the school holidays .... If based on that 8l alone, FC would b 12.5kml, wc I think v good for 2l awd Link to post Share on other sites More sharing options...
Seetong 1st Gear May 8, 2018 Share May 8, 2018 To all those who are waiting for tml bidding exercise (including myself), good luck! Link to post Share on other sites More sharing options...
fordsolo 1st Gear May 9, 2018 Share May 9, 2018 (edited) I did not secure my COE in this round Edited May 9, 2018 by fordsolo 1 Link to post Share on other sites More sharing options...
Scenic98 Clutched May 10, 2018 Share May 10, 2018 Anyone secured coe yesterday.? 1 Link to post Share on other sites More sharing options...
MisterTatty Clutched May 10, 2018 Share May 10, 2018 Judder happens again on 1-1.2k rpm, zzzz. Shall have new pak file to update the gb firmware version. But not sure will it solve the problems or not. mine was updated with a test pak once, but it did not help. keep us updated if the latest version solves your problem. 1 Link to post Share on other sites More sharing options...
MisterTatty Clutched May 10, 2018 Share May 10, 2018 Not sure if due to the type of driving that the car goes through when new and the computer is learning the driving pattern and adjusting the CVT behaviour accordingly. I suspect those who have long highway journeys and very little traffic jam type of stop-and-go traffic for first few weeks/months don't face such problems (even if they later drive in traffic jam stop and go traffic). The car computer adjusts the CVT to be quite smooth and ok to drive. Those with lots of traffic jam stop-and-go traffic daily I think are the ones where the computer may have trouble to adjust the CVT correctly. Is your driving pattern having this type of traffic jam situation - esp. for first few weeks when you have this car? The other factor is the driver. I have the older version XV and I did not get used to the CVT and was not able to drive it smoothly at first. My wife had no problem at all and drove it smoothly from day 1. Basically, CVT driving is different from other types of transmissions. After a while, the car got used to my driving pattern (or maybe my wife trained it well) and I got used to the CVT - nowadays very smooth. indeed my driving pattern is non-highway with stop-go traffic.... 1 Link to post Share on other sites More sharing options...
raaa 1st Gear May 10, 2018 Share May 10, 2018 Judder happens again on 1-1.2k rpm, zzzz. Shall have new pak file to update the gb firmware version. But not sure will it solve the problems or not. Just drive more and the juddering will go away. Mine always judder during moveoff in the morning. Took awhile and it's fine now. 2 Link to post Share on other sites More sharing options...
Meemee 5th Gear May 10, 2018 Share May 10, 2018 Rear wheel arch and boot space ... Sound deaderner 2 Link to post Share on other sites More sharing options...
N0068 Clutched May 12, 2018 Share May 12, 2018 Rear wheel arch and boot space ... Sound deaderner So after this got any improvement? Link to post Share on other sites More sharing options...
Meemee 5th Gear May 12, 2018 Share May 12, 2018 So after this got any improvement?More "noise" from the front .... Hahahahahahah..... Link to post Share on other sites More sharing options...
N0068 Clutched May 12, 2018 Share May 12, 2018 More "noise" from the front .... Hahahahahahah..... Recently I put seal on the rear boot door edge People taking,bus ,motorcycle seen abit far I hear now Link to post Share on other sites More sharing options...
Sarion 4th Gear May 12, 2018 Share May 12, 2018 Recently I put seal on the rear boot door edge People taking,bus ,motorcycle seen abit far I hear now u mean for better or worse?... Rear wheel arch and boot space ... Sound deaderner nice... can share where you got those from? the original boot compartment foam tray still can fit i reckon? 1 Link to post Share on other sites More sharing options...
Meemee 5th Gear May 12, 2018 Share May 12, 2018 u mean for better or worse?... nice... can share where you got those from? the original boot compartment foam tray still can fit i reckon? Got them from Ebay Customize reverse cam cable So no cable is cut from the car itself New hdmi and usb cable to hu without addition socket or the need to cut stock cable Rta curve of stock and clarion hu.... More project coming up.. Some dip more then 3db on the stock ... Clarion uh give a more balance curve Link to post Share on other sites More sharing options...
N0068 Clutched May 12, 2018 Share May 12, 2018 Got them from Ebay Customize reverse cam cable So no cable is cut from the car itself New hdmi and usb cable to hu without addition socket or the need to cut stock cable Rta curve of stock and clarion hu.... More project coming up.. Some dip more then 3db on the stock ... Clarion uh give a more balance curve So change the HU from stock u mean for better or worse?... nice... can share where you got those from? the original boot compartment foam tray still can fit i reckon? Abit betterSound proof is the interesting thing to do Same as audio 1 Link to post Share on other sites More sharing options...
Meemee 5th Gear May 12, 2018 Share May 12, 2018 Yes... Need the optical output for the bigger project ...m Link to post Share on other sites More sharing options...
Seetong 1st Gear May 12, 2018 Share May 12, 2018 No time for horn.. But done up the dash cam Can I know your rear connection cable require how long? 5,7 or 11m? ↡ Advertisement 1 Link to post Share on other sites More sharing options...
[Official] 2024 Lexus LBX
Toyota Corolla Cross
[Official] 2024 Audi Q6 e-tron
New Kia Niro Hybrid
New Kia Niro Hybrid
Škoda Epiq Concept
Škoda Epiq Concept
