Coldshot Neutral Newbie December 26, 2011 Share December 26, 2011 Hi A few months back CnC replaced a defective engine mount in my 1yr old forte. There was some unusual vibrations coming from the steering wheel and driver seat. After the replacement the vibration has lessened but i can still feel this pulsating vibration from the driver/passenger seat. This is pretty noticable when the aircon is on and in idle with the gear in 'D' At 'P' or 'N' the vibration is minimal. ITs quite frustrating cos i'm not sure if its normal to have such vibrations or is something wrong with the car? ↡ Advertisement Link to post Share on other sites More sharing options...
ER-3682 Twincharged December 26, 2011 Share December 26, 2011 Well,most small C.C. 4 cylinders,F.W.D. cars will have some sort of vibration after 1 yr,nothing much can be done... Link to post Share on other sites More sharing options...
Swiftee Clutched December 26, 2011 Share December 26, 2011 Never had such problem thr out my 18+ yrs of driving. Perhaps a screw loosen some where. But i never owned a Kia b4. :) Link to post Share on other sites More sharing options...
Nismo22 Neutral Newbie December 26, 2011 Share December 26, 2011 (edited) they replaced with a OEM mounting , OEM mounting although some may say it may last much longer , its vibration absorbing isnt as good as the orignial ,so u may still feel some slight vibration after awhile OEM mounting costs almost half of that of the originals. Edited December 26, 2011 by Nismo22 Link to post Share on other sites More sharing options...
Leech Clutched December 26, 2011 Share December 26, 2011 I thought all Korean cars vibrate anyway? Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged December 26, 2011 Share December 26, 2011 I thought all Korean cars vibrate anyway? My jap car also vibrate leh.. Due to dirty throttle body n sensitive sensor.. Clean throttle body stop vibrating, after 3000km or so the vibration starts Link to post Share on other sites More sharing options...
Kelvingoh45 Clutched December 26, 2011 Share December 26, 2011 Most car will vibrate after sometimes due to wear & tear. Causes may be from engine or gear box mounting. Link to post Share on other sites More sharing options...
Monoswift Clutched December 26, 2011 Share December 26, 2011 1 year old and there is defective engine mounting? that is very fast leh... or is it due to aircon cutting in and out? but i do agree with chucky it might be dirty TB or MAF sensor.. Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear December 26, 2011 Share December 26, 2011 Well,most small C.C. 4 cylinders,F.W.D. cars will have some sort of vibration after 1 yr,nothing much can be done... Can go for servicing? Link to post Share on other sites More sharing options...
Jamesc Hypersonic December 26, 2011 Share December 26, 2011 Vibrating like Osim massage chair? Korean car so high tech now? You have to pay big bucks on S class for this feature. Link to post Share on other sites More sharing options...
Coldshot Neutral Newbie December 26, 2011 Author Share December 26, 2011 1 year old and there is defective engine mounting? that is very fast leh... or is it due to aircon cutting in and out? but i do agree with chucky it might be dirty TB or MAF sensor.. I noticed that the vibration is worse with the aircon on and the gear engaged. Otherwise its prettt silent Link to post Share on other sites More sharing options...
Coldshot Neutral Newbie December 26, 2011 Author Share December 26, 2011 they replaced with a OEM mounting , OEM mounting although some may say it may last much longer , its vibration absorbing isnt as good as the orignial ,so u may still feel some slight vibration after awhile OEM mounting costs almost half of that of the originals. Is there a way to check if its OEM mounting or not? Link to post Share on other sites More sharing options...
Coldshot Neutral Newbie December 26, 2011 Author Share December 26, 2011 1 year old and there is defective engine mounting? that is very fast leh... or is it due to aircon cutting in and out? but i do agree with chucky it might be dirty TB or MAF sensor.. I'm not sure if CnC with check the TB or MAF sensor if i tell them to. Most prob i will get the usual 'its normal' reply from them Might have to bring it to a private workshop if thats the case but i dont wana void my warranty. My car is only 10k km. Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged December 26, 2011 Share December 26, 2011 I'm not sure if CnC with check the TB or MAF sensor if i tell them to. Most prob i will get the usual 'its normal' reply from them Might have to bring it to a private workshop if thats the case but i dont wana void my warranty. My car is only 10k km. Under warranty? If so tell them vibration may due to dirty throttle body. c&c will clean it for u foc.. At least if that's not the cause of the problem, yr car will have a clean throttle body.. Haha Link to post Share on other sites More sharing options...
Happily1986 5th Gear December 26, 2011 Share December 26, 2011 Well,most small C.C. 4 cylinders,F.W.D. cars will have some sort of vibration after 1 yr,nothing much can be done... vibration is not definitely not normal to be felt in driver seat. Link to post Share on other sites More sharing options...
Raytham Neutral Newbie December 26, 2011 Share December 26, 2011 I noticed that the vibration is worse with the aircon on and the gear engaged. Otherwise its prettt silent Your case is almost same as mine. But my case is when aircon kick in RPM drop Vibration will come in. Very prominent especially when headlights is turned on at night. Nothing really can be done though. My is a Jap ride btw. Link to post Share on other sites More sharing options...
Kelvingoh45 Clutched December 26, 2011 Share December 26, 2011 Your case is almost same as mine. But my case is when aircon kick in RPM drop Vibration will come in. Very prominent especially when headlights is turned on at night. Nothing really can be done though. My is a Jap ride btw. Maybe some sensors are not working properly. Link to post Share on other sites More sharing options...
Monoswift Clutched December 26, 2011 Share December 26, 2011 I noticed that the vibration is worse with the aircon on and the gear engaged. Otherwise its prettt silent eh when u on aircon, headlight n engaged gear its normal to feel the slight vibration more prominent..as voltage is use to supply for aircon + headlight..aldou they say 12v but there is noise n thus not constant 12v thru out.. thus causing the vibration to be slightly prominent..but if you are saying your car is 1yr old only.. to me it is relatively new unlikey to be engine mounting..unless to start with the stock engine mounting is a lemon.. since its under warranty, mayb u can ask cnc to check maf n tb 1st lor..at least maf n tb no prob then mayb u can have a direction to narrow the root of the problem else where..or recently u installed any new ICE? ↡ Advertisement Link to post Share on other sites More sharing options...
2022 Kia EV6
2022 Kia EV6
Kia EV9 Concept
Kia EV9 Concept
KIA K3 Owners check-in!
Kia Stonic
Kia Stonic
Kia K5
Kia K5
