Hamburger Hypersonic January 28, 2012 Share January 28, 2012 any bros can help where to get this toshiba HDD???? Tks ↡ Advertisement Link to post Share on other sites More sharing options...
Joseph22 Turbocharged January 28, 2012 Share January 28, 2012 any bros can help where to get this toshiba HDD???? Tks why must get back the same brand?? Link to post Share on other sites More sharing options...
Vid Hypersonic January 28, 2012 Share January 28, 2012 30GB? Antique leh. Can't get any other? You can probably get any EIDE HDD to work Link to post Share on other sites More sharing options...
Hamburger Hypersonic January 28, 2012 Author Share January 28, 2012 because i am nuts about HDD... btw, this is taken off from a HU of a alphard mpv. seem its konk out, need to do a replacement. So any HDD will do?? Link to post Share on other sites More sharing options...
Hamburger Hypersonic January 28, 2012 Author Share January 28, 2012 30GB? Antique leh. Can't get any other? You can probably get any EIDE HDD to work simi lye?? care to elaborate?? Link to post Share on other sites More sharing options...
Bluethorn Neutral Newbie January 28, 2012 Share January 28, 2012 w/o the Hd, does your HU still working ? If HU cannot start up w/o HD, it is pointless to replace the harddisk as the OS or HU programme is gone. If HU can startup w HD, can worth a try to replace it. Link to post Share on other sites More sharing options...
Hamburger Hypersonic January 28, 2012 Author Share January 28, 2012 w/o the Hd, does your HU still working ? If HU cannot start up w/o HD, it is pointless to replace the harddisk as the OS or HU programme is gone. If HU can startup w HD, can worth a try to replace it. good point there, noted with thanks. Was told that the HDD may be use for controlling the surround sound system of the mpv. very true, no point replace it with another HDD that is blank with no OS in it.... Link to post Share on other sites More sharing options...
Karebu 1st Gear January 28, 2012 Share January 28, 2012 bro, you check if your HU works without the hard disk. if everything works except when u try to press hard disk button then it may be purely a storage medium Link to post Share on other sites More sharing options...
Babyt 4th Gear January 28, 2012 Share January 28, 2012 30G no more selling now le... Link to post Share on other sites More sharing options...
Vid Hypersonic January 28, 2012 Share January 28, 2012 simi lye?? care to elaborate?? HDD got 2 types. One is IDE and another is SATA. IDE is the older generation of connection to the motherboard. Your HDD probably is those type if it's just 30GB. Go Sim Lim Sq and find. I think it's more expensive than SATA cos going obsolete already but you should get it to work on your computer. Max size is around 250GB or 500GB. You will need to reinstall the OS yourself though. Link to post Share on other sites More sharing options...
Hamburger Hypersonic January 28, 2012 Author Share January 28, 2012 ask and you shall be answered and learnt from it................. thks to many bros for your input..... Link to post Share on other sites More sharing options...
Rncw 5th Gear January 28, 2012 Share January 28, 2012 Toshiba MK3029GAC 30GB UDMA/100 4200RPM 8MB 2.5" IDE Hard Drive Link to post Share on other sites More sharing options...
Wolfy3769 2nd Gear January 28, 2012 Share January 28, 2012 just bring it to Sim Lim square, they will intro u new one.. as long as interface is the same can liao.. cap, u probably can get a bigger GB one Link to post Share on other sites More sharing options...
Hamburger Hypersonic January 28, 2012 Author Share January 28, 2012 like bros here mentioned, w/o OS or the program...........the newer HDD is next to useless so better go check again to confirm........ Link to post Share on other sites More sharing options...
Happily1986 5th Gear January 28, 2012 Share January 28, 2012 like bros here mentioned, w/o OS or the program...........the newer HDD is next to useless so better go check again to confirm........ better check whether HDD itself has kee chia or not. if the HDD is fine then you just end up liao lui buy new one. Link to post Share on other sites More sharing options...
Hamburger Hypersonic January 28, 2012 Author Share January 28, 2012 when it comes to IT thingy, confirm happybro sure comes in one.... its confirm the HDD is dead and buried.......only doubts now is whether HU will start up, without it or with a new one. Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear January 28, 2012 Share January 28, 2012 I got one 40GB salvaged from previous Desktop if you want it. I believe got nothing obscene inside. Link to post Share on other sites More sharing options...
Hamburger Hypersonic January 28, 2012 Author Share January 28, 2012 ok thks. PM you later .....why you delete those away ↡ Advertisement Link to post Share on other sites More sharing options...
Citroen C4 1.2 Sensor & Display
MyResponder app to call SCDF
Help with STA report remarks
