  • Search this thread
  • Reply to this topic
607 replies to this topic | 180 praises
#601
Posted 21 June 2019 - 10:56 PM
Newowner2009
  • Newowner2009
    Clutched
    Author Image
    25
The last dip is torque converter locking up.
Thanks for the input.
Can share more advice on this?   As the car also got gear transmission issue
It jerks if did not drive for prolong period at this point
1st change 1-2
2nd change 2-3   <------- Jerk here
3rd change. 3-4
4th change. 4-5
Maybe is related?
#602
Posted 21 June 2019 - 11:01 PM
Stik
  • Stik
    Author Image
    19
1st change 1-2
3rd change. 3-4
4th change. 4-5
Maybe is related?
No. It's not related.
You might want to have your gearbox flushed and use proper ATF, to begin with.
Mine will give me a kick when downshift from 4 to 3 on high speed kick down, but the frequency of it gets less after I did 3 rounds of fluid change within 15,000km.
The ATF condition when I first got the car was quite coarse, like having sand. Now it's much smoother.
#603
Posted 21 June 2019 - 11:16 PM
Stik
  • Stik
    Author Image
    19
1st change 1-2
3rd change. 3-4
4th change. 4-5
Maybe is related?
This usually is problem with solenoid in the valve body.
Some clean and fresh ATF might help improve the operation of it but will not cure it.
#604
Posted 21 June 2019 - 11:57 PM
Newowner2009
  • Newowner2009
    Clutched
    Author Image
    25
Thanks for the insight . I went to a couple of workshop , 1 suspect is electronic board . The other quite sure is ecu.
Did atf oil change . Atf filter also changed . Same issue but getting worse as the months went by . Now almost everyday when stationary , change gear from n to d, car also slight jerk
Instead of trying luck , most likely will go to Komoco solve once and for all
#605
Posted 22 June 2019 - 08:26 AM
Stik
  • Stik
    Author Image
    19
I hope we are talking the same symptom:-
1. At stationary, it hesitate to change gear.
For me, when I shift from P->R, there is a delay before it engaged.
Also delay in N->D.
This is definitely solenoid problem.
2. Kicking / knocking when engaging D --> R.
This happens when I want to reverse into parking lot.
Shift from D->R like immediately after car fully stopped will sometimes give a violent knock.
If I wait for 2-3 seconds after full stop and shift, it's OK. So I am practicing this now.
3. Kicking / knocking during highspeed downshift from 4->3.
Usually happens after cruising for long time on 4th,
then floor accelerator to pick up speed for overtaking.
My workshop also noticed (1) and (2) above when they move my car around during servicing. They gave me feedback about it, but since they are not gearbox specialist which they openly tell all their customer, they didn't offer repair advise.
What I had done so far:
a. On receiving the car (127,000km on clock, genuine) --> Replace ATF and filter.
b. At 135,000km, feeling all above symptom --> Replace ATF + 1 bottle additive / cleaner.
c. At 148,000km, after plentiful of instigating the kicking of gearbox (to get the solenoid work hard with cleaner) --> Replace the ATF.
The symptom is very much relieved and gear change is very smooth now. Still get the knock but it's rare now, and it's very mild knock for (3) above.
To reduce cost, I bought Hyundai ATF from Malaysia HyunKia or Mobis stockist for RM85 / 4 liter pack. The additive / cleaner cost me RM35. I still have a bottle of additive in my trunk, with 2 pack of ATF. If you keen to try, I can always pass to you.
To me, it's no harm trying the additive with the intention of overhaul the gearbox if all doesn't go well. Going back to Komoco for a solenoid problem, means changing the entire valve body, if they do that at all. No harm asking though. However, I am ear marking workshops that does gearbox reconditioning in case I need to drop it there for such a job. Will compare to cost of replacing valve body at Komoco.
BTW, my ride is i30cw but it has the same engine / gearbox / mechanical as the Avante.
teomingern praised this
#606
Posted 22 June 2019 - 12:33 PM
teomingern
  • Premium member
    teomingern
    6th Gear
    Author Image
    3,305
Very nice analysis!
#607
Posted 22 June 2019 - 03:27 PM
Stik
  • Stik
    Author Image
    19
Also delay in N->D.
Don't know how to edit my post above, but © should be 138,000km and not 148,000km...
#608
Posted 23 June 2019 - 01:38 PM
teomingern
  • Premium member
    teomingern
    6th Gear
    Author Image
    3,305
You can't edit after a fixed time has elapsed since posting...
Back to Korean Talk  ·  Car Brands Top Reply to this topic
Quick Reply
Tags: Hyundai, Avante, Maintenance and 1 more...
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
