Mazdaowner Moderator April 30, 2012 Share April 30, 2012 WD40 use to unfreeze seized bolts and nuts. Quite effective especially let it soak overnight. But for my car its also a NO. I use Dupont teflon dry wax lube and LPS aerosol I recommend you this for seized bolts and nuts Weicon Rust-Shock, no need soak overnight. Spray on, few minutes, can open. ↡ Advertisement Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged April 30, 2012 Share April 30, 2012 OT a little.. if seat belt not so smooth when pulling, can do anything like greasing it? If can, use WD40 or those Singer lubricating oil? Or silicon spray? Link to post Share on other sites More sharing options...
Poker Neutral Newbie April 30, 2012 Share April 30, 2012 For questions regarding rubbber, think must ask rubberpad anyway hijack this thread abit.. if my rubber has already hardened, is there any other way to maintain other than replacing everything? tried grease and silicon spray already.. nth's working Link to post Share on other sites More sharing options...
Mazdaowner Moderator April 30, 2012 Share April 30, 2012 For questions regarding rubbber, think must ask rubberpad anyway hijack this thread abit.. if my rubber has already hardened, is there any other way to maintain other than replacing everything? tried grease and silicon spray already.. nth's working Change new one. Link to post Share on other sites More sharing options...
Nightkids 6th Gear April 30, 2012 Share April 30, 2012 Hi guys, use this can or not huh?? Link to post Share on other sites More sharing options...
Warthog Clutched May 13, 2012 Share May 13, 2012 Nut, not exactly. Not ALL rubber products, it depends on the rubber content. I had one experience many years ago, spraying WD40 onto a "rubber' product, within 5mins, I could feel the slight "stickiness" with my fingers, had to immediately clean item, bit late though, ended up replacing it. Best deal is silicon spray or Petroleum jelly aka Vaseline. I use Vaseline even on electrical components with plastic gears, lasts far longer then grease, and totally safe. For squeaking fan & alternator belts, WD40 or silicon spray better? Link to post Share on other sites More sharing options...
Jellyfish 1st Gear May 16, 2012 Share May 16, 2012 all those produce selling out there just shines your rubber and at best give a light coating of oil. what you need is a chemical grease which is specially formulated for rubber door seal, sun roof, and roadster cars alike, the grease need to be applied by hand or finger which every way you wanna, but a light and thin coat will, do, and all you got to do is just apply to all the rubber seal, leave it on for 3 days, as watch your car rubber seal puff up, and after 3 days, just use a unwanted rag , wipe off the exess grease, and you are good to go for another 6 mth before needing another application. but be warned those rubber puffing grease ain't cheap, but as a roadster car user, its every $ well spent!!!! let me know who wanna them as i still got a tube left, as my friend brought 1 off me as the workshop quoted that his honda jazz rubber seal is wasted, and was told it would cost 1600 to change them all, but just a application of the grease help solved his water lekage problem, and now his door close with a reassuring thud rather than a a crack!!!! Link to post Share on other sites More sharing options...
Leiquiz Clutched May 16, 2012 Share May 16, 2012 Hi bro, I am interested to get it from me. PM me. Thanks! Link to post Share on other sites More sharing options...
Leiquiz Clutched May 17, 2012 Share May 17, 2012 Dear Jellyfish bro, Thanks for the patience. Looking forward to using the chemical grease! :) Link to post Share on other sites More sharing options...
Jellyfish 1st Gear May 17, 2012 Share May 17, 2012 hey bro no worries, i`m just killing time over there with car magazines, do let me know if you can feel and see the difference Link to post Share on other sites More sharing options...
Harlow123 Neutral Newbie June 1, 2012 Share June 1, 2012 all those produce selling out there just shines your rubber and at best give a light coating of oil. what you need is a chemical grease which is specially formulated for rubber door seal, sun roof, and roadster cars alike, the grease need to be applied by hand or finger which every way you wanna, but a light and thin coat will, do, and all you got to do is just apply to all the rubber seal, leave it on for 3 days, as watch your car rubber seal puff up, and after 3 days, just use a unwanted rag , wipe off the exess grease, and you are good to go for another 6 mth before needing another application. but be warned those rubber puffing grease ain't cheap, but as a roadster car user, its every $ well spent!!!! let me know who wanna them as i still got a tube left, as my friend brought 1 off me as the workshop quoted that his honda jazz rubber seal is wasted, and was told it would cost 1600 to change them all, but just a application of the grease help solved his water lekage problem, and now his door close with a reassuring thud rather than a a crack!!!! Hi Jellyfish, You still got the grease ? I am interested. If not can PM me where to get ? many many thks Link to post Share on other sites More sharing options...
Ilmw 1st Gear June 1, 2012 Share June 1, 2012 (edited) See this thread http://www.mycarforum.com/index.php?showtopic=1491635 talking about this http://www.303products.com/shop303/index.c...-protectant.cfm I've been using this for 4.5 yrs.... Edited June 1, 2012 by Ilmw Link to post Share on other sites More sharing options...
Hollysurly Neutral Newbie June 4, 2012 Share June 4, 2012 (edited) 1.Patch split sills that are otherwise intact with glue and screws. Use a glue syringe, available at hardware stores, to apply glue to the inside of the split. Lift the sill up into position. 2.Drill pilot holes in at least three places into the edge of the sill. Select treated deck screws long enough to run at least Edited June 4, 2012 by Hollysurly Link to post Share on other sites More sharing options...
Thedream 3rd Gear June 4, 2012 Share June 4, 2012 sibeh chim... got youtube video or not ah?... ↡ Advertisement Link to post Share on other sites More sharing options...
Where can I get rubber sheet
Drive shaft rubber boot/cover
Home window - Sliding or casement?
49 cases of fallen windows
Rain Shield for Side Mirror and Side Windows
How do you maintain your white car?
Windows 10 to be free for 1st year
