Rezorn86 3rd Gear May 29, 2012 Share May 29, 2012 recently when there is a passengers seat at the front seat, there is a funny noise tat sound like a old wooden chair. does anyone knws wat's the problem?? ↡ Advertisement Link to post Share on other sites More sharing options...
Shibadog Turbocharged May 29, 2012 Share May 29, 2012 recently when there is a passengers seat at the front seat, there is a funny noise tat sound like a old wooden chair. does anyone knws wat's the problem?? how does an old wooden chair sound like? LOL if the sound is coming fm the bottom of the chair, chk if the bolts at the seat/railing/bracket are tight. Link to post Share on other sites More sharing options...
Rezorn86 3rd Gear May 29, 2012 Author Share May 29, 2012 (edited) or make it tis way, its sound like "eeyah eeyah"... previously agent had hlp me tighten the bolt.. Edited May 29, 2012 by Rezorn86 Link to post Share on other sites More sharing options...
Shibadog Turbocharged May 29, 2012 Share May 29, 2012 or make it tis way, its sound like "eeyah eeyah"... previously agent had hlp me tighten the bolt.. after tightening still got sound? did agent use lock-tight material when tightening the bolts? they can come loose after some time. Link to post Share on other sites More sharing options...
Rezorn86 3rd Gear May 29, 2012 Author Share May 29, 2012 mmm shld b using it, as i was at the waiting louge.. but will highlight to them again.. Link to post Share on other sites More sharing options...
Elmo 4th Gear May 29, 2012 Share May 29, 2012 recently when there is a passengers seat at the front seat, there is a funny noise tat sound like a old wooden chair. does anyone knws wat's the problem?? Your passenger too heavy Should be due to railing bolts loosen. Link to post Share on other sites More sharing options...
Rezorn86 3rd Gear May 30, 2012 Author Share May 30, 2012 Your passenger too heavy Should be due to railing bolts loosen. so far no passenger has heavier than me Link to post Share on other sites More sharing options...
LoverofCar 6th Gear May 30, 2012 Share May 30, 2012 so far no passenger has heavier than me Teach you a solution...!........stick a label in rear wind screen......"No fat chick allowed"..... Link to post Share on other sites More sharing options...
Rezorn86 3rd Gear May 30, 2012 Author Share May 30, 2012 Teach you a solution...!........stick a label in rear wind screen......"No fat chick allowed"..... [laugh] good idea!!! Link to post Share on other sites More sharing options...
Thedream 3rd Gear May 30, 2012 Share May 30, 2012 or make it tis way, its sound like "eeyah eeyah"... previously agent had hlp me tighten the bolt.. if it's not the bolts, can try spray some WD40/RP7 at the joints. Link to post Share on other sites More sharing options...
Elmo 4th Gear May 30, 2012 Share May 30, 2012 so far no passenger has heavier than me Haha. Your seat's way of shouting "tolong, tolong, fat chick alert". Link to post Share on other sites More sharing options...
Joajas Neutral Newbie May 30, 2012 Share May 30, 2012 If your seat is covered with leather, it might be the leather rubbing against something, probably the center console. Usually noticeable only when someone sits on it. Link to post Share on other sites More sharing options...
Rezorn86 3rd Gear June 20, 2012 Author Share June 20, 2012 if it's not the bolts, can try spray some WD40/RP7 at the joints. is it around the rail there?? Link to post Share on other sites More sharing options...
I-LOVE-CARS 1st Gear June 20, 2012 Share June 20, 2012 so far no passenger has heavier than me you driving Seat ah, how? Good Or Not? thinking to get one soon 'If the time is rite' Link to post Share on other sites More sharing options...
Json Neutral Newbie June 20, 2012 Share June 20, 2012 If your seat is covered with leather, it might be the leather rubbing against something, probably the center console. Usually noticeable only when someone sits on it. Don't have too much action on the car seat, then there will be less wear and tear on your car seat Link to post Share on other sites More sharing options...
Gee 1st Gear June 20, 2012 Share June 20, 2012 Maybe the S spring rubbing its mounting. That's another moving part when seated. Link to post Share on other sites More sharing options...
SimonTan 2nd Gear June 20, 2012 Share June 20, 2012 (edited) Go rent the same model car. Then swope out the seats! Like how some AD switch seats when customers complain, with another car waiting for delivery. Edited June 20, 2012 by SimonTan Link to post Share on other sites More sharing options...
Joajas Neutral Newbie June 20, 2012 Share June 20, 2012 my driver's seat not big enough for action, belly too big already ↡ Advertisement Link to post Share on other sites More sharing options...
Seat Covers
Seat Covers
Car seat covers
Car seat covers
SEAT Arona
SEAT Arona
Kia Cerato Variant 2 persistent overheating issue
SEAT/Cupra Dealership Transfer. Rumoured Geely's return.
