Kelpie 2nd Gear June 2, 2012 Share June 2, 2012 Hi all, I bought a used car that came with a Simota carbon fibre (enclosed) air-intake system. I find it somewhat noisy and to get the original air box will be expensive. Just wondering if this Simota is notorious for noise or what? What suggestion would you recommend to replace this Simota? Would so called "mushroom" type air-intake system reduce or alleviate the noise problem? Please advise me and Thank you very much. Regards, ↡ Advertisement Link to post Share on other sites More sharing options...
Skyiet27 Clutched June 2, 2012 Share June 2, 2012 Mushroom also noisy Most quiet is stock air box Depending on ur car made Jus post on forum swop with others for the original Link to post Share on other sites More sharing options...
Xers007 Supercharged June 6, 2012 Share June 6, 2012 Hi all, I bought a used car that came with a Simota carbon fibre (enclosed) air-intake system. I find it somewhat noisy and to get the original air box will be expensive. Just wondering if this Simota is notorious for noise or what? What suggestion would you recommend to replace this Simota? Would so called "mushroom" type air-intake system reduce or alleviate the noise problem? Please advise me and Thank you very much. Regards, you dont like more horse ah?? Link to post Share on other sites More sharing options...
QQDreamer 4th Gear June 6, 2012 Share June 6, 2012 you dont like more horse ah?? HP wont gain that much by just replacing to open pod or wat. it depends on the set up as well. Link to post Share on other sites More sharing options...
GTR78 Neutral Newbie June 6, 2012 Share June 6, 2012 Hi If it is comfort & quiet running you are after, your best/ only solution is to get the original airbox & filter etc. The orginal airbox has resonators & other features engineered to remove most of the intake noise. Personal experience on mushroom type : super noisy, I replaced my stock airbox with a HKS HKS green mushroom, car immediately changed from sounding like a choked vaccuum cleaner into a Malaysian lorry with a hole in the exhaust No kidding, the difference was that big (I was already on aftermarket exhaust, one of the quieter ones. LTA approved.) I love the noise since it keeps me awake during rush hour jams & I dun have to use the horn most of the time My car has lousy insulation in the first place & I am too cheap to invest in good ICE Cheers Hi all, I bought a used car that came with a Simota carbon fibre (enclosed) air-intake system. I find it somewhat noisy and to get the original air box will be expensive. Just wondering if this Simota is notorious for noise or what? What suggestion would you recommend to replace this Simota? Would so called "mushroom" type air-intake system reduce or alleviate the noise problem? Please advise me and Thank you very much. Regards, Link to post Share on other sites More sharing options...
Mockngbrd Supersonic June 6, 2012 Share June 6, 2012 HP wont gain that much by just replacing to open pod or wat. it depends on the set up as well. lose HP instead Link to post Share on other sites More sharing options...
Cliveekeo Clutched June 7, 2012 Share June 7, 2012 I think you should have to collect some money, try to buy new air box if it is possible. Link to post Share on other sites More sharing options...
Picanyeo 1st Gear June 7, 2012 Share June 7, 2012 I think you can post in forum to trade for airbox. Airbox is the most quiet of all intakes. Link to post Share on other sites More sharing options...
Colin03 4th Gear June 7, 2012 Share June 7, 2012 you might want to post in the trade column for an exchange to original air-box - you might have some cash in return. Link to post Share on other sites More sharing options...
Yuan 6th Gear June 7, 2012 Share June 7, 2012 lose HP instead And lose the low end torque. Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear June 8, 2012 Share June 8, 2012 Original box is quiet as they have the air routed around pipes...off course air flow is lesser. If you want can get workshop to customise a airbox for you...it helps to reduce the noise a bit. BTW...the noise has nothing to do with filters....its the engine sucking air that is causing the noise. If you want to know who can customise the airbox...drop me a PM and I can share with you. Link to post Share on other sites More sharing options...
MX5NC2 1st Gear June 8, 2012 Share June 8, 2012 Most quiet is stock air box Mazda put a sound enhancer in my car and while it feels and sounds shiok, there're days when I wish the cabin could be a lot more quieter. ↡ Advertisement Link to post Share on other sites More sharing options...
FT discrimination agst locals
Stop False Accusation
NASA's Voyager 1 is sending mysterious data from beyond our solar system. Scientists are unsure what it means.
Alkaline water system
Comments on T3B system as a trading tool
Laundry Drying system - Pull-down/Push-up type
Wireless Portable Speaker For Home Entertainment System
STP fuel system cleaner vs HKS DDR
