Xbraveheartx Clutched November 5, 2012 Share November 5, 2012 I see. But no need say must immediately go for alignment after changing the shocks, right? Should go ASAP once changed if not u will find ur tires start wearing off unevenly after traveling for long period. ↡ Advertisement Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 5, 2012 Share November 5, 2012 I see. But no need say must immediately go for alignment after changing the shocks, right? Of course e sooner e better. Link to post Share on other sites More sharing options...
YMGoh Neutral Newbie January 18, 2013 Share January 18, 2013 (edited) Thanks for the Info. Edited January 18, 2013 by YMGoh Link to post Share on other sites More sharing options...
Premacist 5th Gear March 21, 2013 Share March 21, 2013 got a quote from autosaver for my camry 2.4, total $1,200 for 4 shocks. if just replacing the back shocks about $700. Any bro/sis know cheaper WS (~$500) to replace just the back shocks ? Got all 4 shock absorbers for my camry (Tokico, made in Thailand, which is the OEM for Camry) for S$58 each before GST from local stockist. Changed the absorbers by Hawk Tyre in JB, was charged RM209 for labour, including alignment, balancing, rotation and checking of brake system. Link to post Share on other sites More sharing options...
Archaic 1st Gear March 21, 2013 Share March 21, 2013 Got all 4 shock absorbers for my camry (Tokico, made in Thailand, which is the OEM for Camry) for S$58 each before GST from local stockist. Changed the absorbers by Hawk Tyre in JB, was charged RM209 for labour, including alignment, balancing, rotation and checking of brake system. Where you got yours? Link to post Share on other sites More sharing options...
Aries333 Neutral Newbie March 21, 2013 Share March 21, 2013 Got all 4 shock absorbers for my camry (Tokico, made in Thailand, which is the OEM for Camry) for S$58 each before GST from local stockist. Changed the absorbers by Hawk Tyre in JB, was charged RM209 for labour, including alignment, balancing, rotation and checking of brake system. I just replace my rear camry suspension KYB Japan Made locally for S$418. Link to post Share on other sites More sharing options...
Pisces69 6th Gear March 21, 2013 Share March 21, 2013 I just replace my rear camry suspension KYB Japan Made locally for S$418. U said KYB Japan made locally...... means made in spore????? Link to post Share on other sites More sharing options...
Aries333 Neutral Newbie March 21, 2013 Share March 21, 2013 U said KYB Japan made locally...... means made in spore????? Suspension is Japan made, change of suspension is local. Link to post Share on other sites More sharing options...
Pisces69 6th Gear March 21, 2013 Share March 21, 2013 Suspension is Japan made, change of suspension is local. Oh......okie. Link to post Share on other sites More sharing options...
Premacist 5th Gear March 21, 2013 Share March 21, 2013 Where you got yours? Bought from Tye Soon at Toh Guan. Link to post Share on other sites More sharing options...
Premacist 5th Gear March 21, 2013 Share March 21, 2013 Suspension is Japan made, change of suspension is local. I was quoted by the local KYB stockist for S$12x per piece last week, can't remember the exact amount. Link to post Share on other sites More sharing options...
Redsuns85 Neutral Newbie April 2, 2013 Share April 2, 2013 Every single time I hits a bump or knocks over a hole on the road, there is a lot of noise and vibration. Like metal part hitting against car. However, the suspension is fine when going over a hump.. What could be the problem ? Link to post Share on other sites More sharing options...
Camrytron 6th Gear April 2, 2013 Share April 2, 2013 I was doing alignment at jb just now and was recommended a adjustable nuts for the alignment thing. Was told after fix, the car alignment will not run even change absorber. Any bro got experience with this? RM 160 front RM 120 rear. Even after alignment, the first 15min driving is excellent but after a while, car still seem like going left but not so bad. Link to post Share on other sites More sharing options...
Huat138 2nd Gear April 2, 2013 Share April 2, 2013 I was doing alignment at jb just now and was recommended a adjustable nuts for the alignment thing. Was told after fix, the car alignment will not run even change absorber. Any bro got experience with this? RM 160 front RM 120 rear. Even after alignment, the first 15min driving is excellent but after a while, car still seem like going left but not so bad. Camber bolt? I was charged rm60 in melaka. Link to post Share on other sites More sharing options...
Ichibawa 5th Gear April 3, 2013 Share April 3, 2013 I was doing alignment at jb just now and was recommended a adjustable nuts for the alignment thing. Was told after fix, the car alignment will not run even change absorber. Any bro got experience with this? RM 160 front RM 120 rear. Even after alignment, the first 15min driving is excellent but after a while, car still seem like going left but not so bad. Its normal. Sg roads are tilted slightly to the left. Normally a skilled mech will put a mark before replacing the absorbers. If they place it back at the same position hence no big changes and no need for alignment. Link to post Share on other sites More sharing options...
Ichibawa 5th Gear April 3, 2013 Share April 3, 2013 Every single time I hits a bump or knocks over a hole on the road, there is a lot of noise and vibration. Like metal part hitting against car. However, the suspension is fine when going over a hump.. What could be the problem ? Did you feel like you are driving a boat instead of a car? Have your mech check things out. It may be other suspension parts (ball joints, control arms, stabilizer links, etc.) that is faulty. Link to post Share on other sites More sharing options...
Camrytron 6th Gear April 3, 2013 Share April 3, 2013 Camber bolt? I was charged rm60 in melaka. I don't have the correct name. Was told by them it's adjustable nut for the suspension part. All car have but it's the fixed one and cant auto adjust itself. I wonder is it useful? And if it's camber bolt than am I overcharge? U mean rm60 is for 1 side only huh? Total need 4 rite? Link to post Share on other sites More sharing options...
Camrytron 6th Gear April 3, 2013 Share April 3, 2013 Its normal. Sg roads are tilted slightly to the left. Normally a skilled mech will put a mark before replacing the absorbers. If they place it back at the same position hence no big changes and no need for alignment. Actually beginning it's Ok but after a week alignment gone. Pay rm30 for 4 wheel computer alignment. ↡ Advertisement Link to post Share on other sites More sharing options...
Eating too much protein?
Replacing fuel filter
How much did you spend on house renovation?
How much to install Retractable Awning for home?
