teomingern 6th Gear August 21, 2018 Share August 21, 2018 (edited) I second this. I'm a fan of Xiaomi's car cams too, they are cheap, high quality and reliable. I already have to use it once when I was rear ended at a red light.Pity they don't do front and back. Was thinking of installing two cameras... but they're separate streams... not sure if can be installed like that or not... it's a much cheaper solution to what I have now... how did you get the footage of the rear since the camera is front facing and you got rear-ended? Edited August 21, 2018 by teomingern ↡ Advertisement Link to post Share on other sites More sharing options...
mengami 2nd Gear August 21, 2018 Share August 21, 2018 Pity they don't do front and back. Was thinking of installing two cameras... but they're separate streams... not sure if can be installed like that or not... it's a much cheaper solution to what I have now... how did you get the footage of the rear since the camera is front facing and you got rear-ended? Oh yes it's only a front camera. The camera showed that I was already stationary for a period of time and then the car jerked forward during the impact. That was sufficient evidence. There was no contest from the bus company. Link to post Share on other sites More sharing options...
teomingern 6th Gear August 21, 2018 Share August 21, 2018 Oooo... that's nice to know... thanks for sharing... Link to post Share on other sites More sharing options...
DACH Supersonic August 21, 2018 Share August 21, 2018 I second this. I'm a fan of Xiaomi's car cams too, they are cheap, high quality and reliable. I already have to use it once when I was rear ended at a red light. Can they be remotely connected to a HP app? Link to post Share on other sites More sharing options...
Dafansu Turbocharged August 21, 2018 Share August 21, 2018 Can they be remotely connected to a HP app? can just use wi-fi connect directly 1 Link to post Share on other sites More sharing options...
Jq1988 4th Gear August 21, 2018 Share August 21, 2018 go for thinkware, pricy but very reliable, never worry about anything. 2 Link to post Share on other sites More sharing options...
Sunsiang August 22, 2018 Share August 22, 2018 I will recommend Goluk M1 with GPS, Live monitoring, 3G, Remote control, Goluk Care App, 24hours security, Parking Mode.. I used this around 1yr.. Everything goods, Video Quality very clear Link to post Share on other sites More sharing options...
mengami 2nd Gear August 23, 2018 Share August 23, 2018 Can they be remotely connected to a HP app? They have their own android mobile app. You can change settings using the app or onboard camera. Firmware update is done via the app too, I've done a few times and its very stable. Connection is by wifi. Don't try transferring data through wifi though, takes forever. Jus pop the sd card info your pc is the best way to transfer media. Link to post Share on other sites More sharing options...
DACH Supersonic August 23, 2018 Share August 23, 2018 They have their own android mobile app. You can change settings using the app or onboard camera. Firmware update is done via the app too, I've done a few times and its very stable. Connection is by wifi. Don't try transferring data through wifi though, takes forever. Jus pop the sd card info your pc is the best way to transfer media.Thanks man. Link to post Share on other sites More sharing options...
Mcf777 Turbocharged August 23, 2018 Share August 23, 2018 Thanks man. I have two new sets. i can lend you one set to play with it. i bought it last month during their promo S$25.60 per set. Link to post Share on other sites More sharing options...
teomingern 6th Gear August 24, 2018 Share August 24, 2018 I have two new sets. i can lend you one set to play with it. i bought it last month during their promo S$25.60 per set. Do you intend to mount one front and one back? Is that why you have 2 sets? Do let me know... cos I was very interested in the Xiaomi car cams but due to not having a rear channel, I decided not to follow up... interested in how to connect it up and concealed cos I understand the connection is done via USB cables and not the usual link to the fuse box... Link to post Share on other sites More sharing options...
Mcf777 Turbocharged August 24, 2018 Share August 24, 2018 I already have two sets mounted front/rear of my car. These two extra sets is to bring overseas when I rent car in Australia and new Zealand. Link to post Share on other sites More sharing options...
mengami 2nd Gear August 24, 2018 Share August 24, 2018 Just spoke to a colleague about this, realise it depends on what you want. For him the file writing process has to be protected in the event of a power cut, otherwise the file before an accident may be corrupted. Some want front and rear so they can be passive witnesses. Some want GPS to add another layer of evidence in case of accident. Some want 24-hour recording. So I guess you need to know your requirements really well. Link to post Share on other sites More sharing options...
Sunsiang August 25, 2018 Share August 25, 2018 Just spoke to a colleague about this, realise it depends on what you want. For him the file writing process has to be protected in the event of a power cut, otherwise the file before an accident may be corrupted. Some want front and rear so they can be passive witnesses. Some want GPS to add another layer of evidence in case of accident. Some want 24-hour recording. So I guess you need to know your requirements really well.High recommended car dashcam - Goluk M1 with above function and others useful function Link to post Share on other sites More sharing options...
KathrinRichKathi August 25, 2018 Share August 25, 2018 The KDLINKS® X1 is great. Extraordinary unit with various highlights like stopping mode with trigger element, and so forth. Link to post Share on other sites More sharing options...
CarMe Clutched August 26, 2018 Share August 26, 2018 Does anyone have the price of the Blackvue DR590W Wifi edition single channel? I may be getting one for my used car. Link to post Share on other sites More sharing options...
Terrylmt Supercharged August 26, 2018 Share August 26, 2018 Does anyone have the price of the Blackvue DR590W Wifi edition single channel? I may be getting one for my used car. Recommend you to get 2CH if you can. Dangers lurk not only from the front these days. Link to post Share on other sites More sharing options...
ApplePing Neutral Newbie September 2, 2018 Share September 2, 2018 i bought from this site also some good stuff i found there, so i recommend it. ↡ Advertisement Link to post Share on other sites More sharing options...
Dashcam with GPS
Dashcam with GPS
Blackvue users - please come in AGAIN 2
IRoad X9 drains battery until it is flat
WIN attractive prizes worth $4,440! Submit reviews on any car tyres, lubricant or accessories now.
Cam Camera System that can store multiple days of recording
