Razer_Blaze 2nd Gear August 5, 2012 Share August 5, 2012 My ride is the Elantra 2011 and I have encountered an issue when starting the engine. When I tried to start the engine, the interior meter lights and the Car Entertainment system turned on for a split second before going off again and the engine failed to start. The engine will not start when I tried to start it, throughout this time the Car Entertainment system and meter lights did not turn on. All of this is resolved when I open the car door and closed it, and everything works fine. So far I encountered this issue 3 times in the past 2 weeks. And each time it happens, I have to reprogram my settings again. Any Elantra owners out there encountered this issue? ↡ Advertisement Link to post Share on other sites More sharing options...
Akula Turbocharged August 5, 2012 Share August 5, 2012 There is a Elantra club forum, might have better response if post there.... 1 Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged August 5, 2012 Share August 5, 2012 My ride is the Elantra 2011 and I have encountered an issue when starting the engine. When I tried to start the engine, the interior meter lights and the Car Entertainment system turned on for a split second before going off again and the engine failed to start. The engine will not start when I tried to start it, throughout this time the Car Entertainment system and meter lights did not turn on. All of this is resolved when I open the car door and closed it, and everything works fine. So far I encountered this issue 3 times in the past 2 weeks. And each time it happens, I have to reprogram my settings again. Any Elantra owners out there encountered this issue? No offence, but you should be banging tables at Komoco if this is happening 3 times in the past 2 weeks. I seriously don't think other Elantra owners can help you with this problem. Link to post Share on other sites More sharing options...
Sga54g 1st Gear August 5, 2012 Share August 5, 2012 No offence, but you should be banging tables at Komoco if this is happening 3 times in the past 2 weeks. I seriously don't think other Elantra owners can help you with this problem. But if you have fixed some aftermarket car entertainment systems or similar stuffs, best to go back to where you last did something to your ride... Link to post Share on other sites More sharing options...
Tayspiderx 3rd Gear August 5, 2012 Share August 5, 2012 Since you said yrs is a 2011 model, if its May 2011 first batch may wanna check yr battery Link to post Share on other sites More sharing options...
Trex101 3rd Gear August 6, 2012 Share August 6, 2012 My ride is the Elantra 2011 and I have encountered an issue when starting the engine. When I tried to start the engine, the interior meter lights and the Car Entertainment system turned on for a split second before going off again and the engine failed to start. The engine will not start when I tried to start it, throughout this time the Car Entertainment system and meter lights did not turn on. All of this is resolved when I open the car door and closed it, and everything works fine. So far I encountered this issue 3 times in the past 2 weeks. And each time it happens, I have to reprogram my settings again. Any Elantra owners out there encountered this issue? High chance it could be the immobilizer problem, see your owner manual see if there's instruction for a reset function. if not, bring it back to dealer and ask them to sort it out. Link to post Share on other sites More sharing options...
Roadhogger 2nd Gear August 6, 2012 Share August 6, 2012 If you need answer I give you.. you need you to remove all doors...the Boot...bonnet....take out steering and then the dash...NEXT remove the engine...AT box...then headlight....bumpers...make sure all screw got to be out...NOW you can install back in sequence...including the screws ...it should be working now.. ITs just wasting your time HEre!!! 2011? New car? Jus go back Komoco! 1 Link to post Share on other sites More sharing options...
Hosaybo 6th Gear August 6, 2012 Share August 6, 2012 (edited) Yes, better go back agent and check. Possibility of immobiliser issue. if can start other times, I dun see anything wrong with the starter motor, batteries etc I have a similar case b4 (old car and not elantra) and the reason for that is the wire connecting the immboliser is going to break (connected by a few strands). So at times, my immobiliser cannnot be detected. there could be other possibilities and prob you need a goood mechanic to troubleshoot by slowly eliminating the possibilities. Edited August 6, 2012 by Hosaybo 1 Link to post Share on other sites More sharing options...
Razer_Blaze 2nd Gear August 6, 2012 Author Share August 6, 2012 Hosaybo, I have sent in the car to the agent and the cause was loose electrical connections. Looks like a similar case to yours. Yes, better go back agent and check. Possibility of immobiliser issue. if can start other times, I dun see anything wrong with the starter motor, batteries etc I have a similar case b4 (old car and not elantra) and the reason for that is the wire connecting the immboliser is going to break (connected by a few strands). So at times, my immobiliser cannnot be detected. there could be other possibilities and prob you need a goood mechanic to troubleshoot by slowly eliminating the possibilities. Link to post Share on other sites More sharing options...
Spidercool 1st Gear August 6, 2012 Share August 6, 2012 Hosaybo, I have sent in the car to the agent and the cause was loose electrical connections. Looks like a similar case to yours. Great to know your problem solved and thanks for sharing. You can find many Elantra brothers and sisters in the forum link below. Join us there! :-) http://elantrasg.forumotion.org/ Link to post Share on other sites More sharing options...
Kb27 Supersonic August 6, 2012 Share August 6, 2012 Since you mentioned opening car door and closing it to resolve, maybe it's just the door switch not closing/opening properly and the circuit prevents engine from starting. Link to post Share on other sites More sharing options...
Razer_Blaze 2nd Gear August 7, 2012 Author Share August 7, 2012 Spidercool, Thanks for sharing the link. Great to know your problem solved and thanks for sharing. You can find many Elantra brothers and sisters in the forum link below. Join us there! :-) http://elantrasg.forumotion.org/ ↡ Advertisement Link to post Share on other sites More sharing options...
2016 Hyundai Elantra / Avante
[Seek experts' views] Pioneer Z9250BT vs stock HU
Audi A4/A5 Sportback owners thread
Hyundai Elantra MD
Hyundai Elantra MD
GS automobile
GS automobile
