Myxilplix Turbocharged December 17, 2012 Share December 17, 2012 How did you tune for the straight thru and sti turbo in the first place? or did you mean yours is an sti? ↡ Advertisement Link to post Share on other sites More sharing options...
Caravan 5th Gear December 17, 2012 Share December 17, 2012 can still tune back right? if not, what other legal mods needed to push it back to the old figures If exhaust is the limitation, then whatever else you do will be of limited benefit. You need to find out what is limiting your performance. Exhaust is very important to turbo, and if you stay legal, there's not much you can do. The stock exhaust is extremely restrictive. Link to post Share on other sites More sharing options...
Mllcg 3rd Gear December 17, 2012 Author Share December 17, 2012 (edited) get rid of ss. no more wrx on this xos. get a catback. stock sti 300hp 400nm 1bar. easily done on a wrx no LTA legal cat back im driving a GC8 Edited December 17, 2012 by Mllcg Link to post Share on other sites More sharing options...
Mllcg 3rd Gear December 17, 2012 Author Share December 17, 2012 If exhaust is the limitation, then whatever else you do will be of limited benefit. You need to find out what is limiting your performance. Exhaust is very important to turbo, and if you stay legal, there's not much you can do. The stock exhaust is extremely restrictive. what about dummy catalytic converter? like the cover still there but inside straight through Link to post Share on other sites More sharing options...
Boo_saa Neutral Newbie December 17, 2012 Share December 17, 2012 Bro. With your so call sti turbo , hopefully u have other supporting hardware. Like bigger or at lease a sti tmic ,Fuel pump ,and injector. The rest up pipe dp and extractor can be stock but de-meow it and get a Fuji. A good open source tunner should make u happy. Link to post Share on other sites More sharing options...
Mllcg 3rd Gear December 17, 2012 Author Share December 17, 2012 Bro. With your so call sti turbo , hopefully u have other supporting hardware. Like bigger or at lease a sti tmic ,Fuel pump ,and injector. The rest up pipe dp and extractor can be stock but de-meow it and get a Fuji. A good open source tunner should make u happy. no legal fuji for GC8.. and all STI parts.. STI TMIC, Fuel Pump and sard fuel injectors Link to post Share on other sites More sharing options...
Myxilplix Turbocharged December 17, 2012 Share December 17, 2012 With all the parts already in the car, i would expect it to already have some sort of tuning done to it. So it would just be a matter of getting the tuner to make the necessary adjustments to accomodate the exhaust change. Unless you have been running with a stock tune all this while Link to post Share on other sites More sharing options...
Mllcg 3rd Gear December 17, 2012 Author Share December 17, 2012 With all the parts already in the car, i would expect it to already have some sort of tuning done to it. So it would just be a matter of getting the tuner to make the necessary adjustments to accomodate the exhaust change. Unless you have been running with a stock tune all this while my brand of ECU has no tuner in SG... unless someone can tell me where to tune microtech ecu Link to post Share on other sites More sharing options...
ER-3682 Twincharged December 17, 2012 Share December 17, 2012 what about dummy catalytic converter? like the cover still there but inside straight through The LTA officer will know,because the car is noisier & the fumes smell not the same. Link to post Share on other sites More sharing options...
Caravan 5th Gear December 17, 2012 Share December 17, 2012 The LTA officer will know,because the car is noisier & the fumes smell not the same. 2nd that. The smell alone is an instant giveaway. Link to post Share on other sites More sharing options...
I-love-singapore December 18, 2012 Share December 18, 2012 what about dummy catalytic converter? like the cover still there but inside straight through catless can pass. all stock cover cannot remove. even with the bad smell, emission test pass also Link to post Share on other sites More sharing options...
Kman08 3rd Gear December 18, 2012 Share December 18, 2012 catless can pass. all stock cover cannot remove. even with the bad smell, emission test pass also Agreed. Another point to note is that u can tune your catless exhaust to meet inspection requirement if I am not mistaken. But not sure if it maximizes the bhp potential. Link to post Share on other sites More sharing options...
Weichien Clutched December 18, 2012 Share December 18, 2012 Microtech quite a old tech Liao leh. Link to post Share on other sites More sharing options...
Mllcg 3rd Gear December 18, 2012 Author Share December 18, 2012 can aftermarket extractor pass? Link to post Share on other sites More sharing options...
Ahmi Neutral Newbie December 18, 2012 Share December 18, 2012 Microtech can look for GTR technologies - Donald 9088 0686 They are at Batok crescent, Unity Centre. They do alot of GC8 models. There is currently a 2 door one in at his place, but dunno if it is running on Microtech or not Link to post Share on other sites More sharing options...
Mllcg 3rd Gear December 18, 2012 Author Share December 18, 2012 i rather change ecu. was recommended unichip Link to post Share on other sites More sharing options...
Amgm125 2nd Gear December 18, 2012 Share December 18, 2012 can aftermarket extractor pass? NOPE. I was escorted by LTA back to inspection centre where my WHOLE car is legal except for the aftermarket tomei unequal length extractor. Lesson learnt. Link to post Share on other sites More sharing options...
Mllcg 3rd Gear December 18, 2012 Author Share December 18, 2012 NOPE. I was escorted by LTA back to inspection centre where my WHOLE car is legal except for the aftermarket tomei unequal length extractor. Lesson learnt. whats their reason for failing? ↡ Advertisement Link to post Share on other sites More sharing options...
New Subaru XV
New Subaru XV
2015 Forester 2.0
2015 Forester 2.0
Advice on exhaust.
Advice on exhaust.
2023 Tan Chong Car Challenge
RIP Shinji Tanimura 谷村新司
2016 / 2017 Subaru Impreza
