Deckbuild 6th Gear December 21, 2012 Share December 21, 2012 engine off=no aircon. u like to wait in the heat? If not wrong, Honda hybrid cut off the aircon fully when stop at traffic lights, hot air are being blown out, any Honda hybrid owners wanna verify this? ↡ Advertisement Link to post Share on other sites More sharing options...
Deckbuild 6th Gear December 21, 2012 Share December 21, 2012 Basically. The day u drive out ur hybrid, u will .... in a very gradual fashion get a worsening battery. My feel is.... hybrid is perfect for the first 5 years. Just like a handphone battery is good for first 1 year For toyota, I doubt so as the battery never drop it's level below 45% charge and never charge over 80%. There are millions being sold Around the world and some have worst weather than us. If there's a problem, it will be blown up. Link to post Share on other sites More sharing options...
Deckbuild 6th Gear December 21, 2012 Share December 21, 2012 I bought Hybrid for its sheer power & efficiency ! You driving crz? Link to post Share on other sites More sharing options...
Deckbuild 6th Gear December 21, 2012 Share December 21, 2012 own RX hybrid, one of best car owned! so far no prob after driving 9 months That's the first hybrid I drove, quite amaze by it because its able to move with engine off. How's your FC like? Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic December 21, 2012 Share December 21, 2012 That's the first hybrid I drove, quite amaze by it because its able to move with engine off. How's your FC like? I can get easily 11km/l despite the 3.5L! Basically awesome Link to post Share on other sites More sharing options...
Deckbuild 6th Gear December 21, 2012 Share December 21, 2012 I can get easily 11km/l despite the 3.5L! Basically awesome Quite good given that enormous size of the car Link to post Share on other sites More sharing options...
Pureness Clutched December 21, 2012 Share December 21, 2012 For toyota, I doubt so as the battery never drop it's level below 45% charge and never charge over 80%. There are millions being sold Around the world and some have worst weather than us. If there's a problem, it will be blown up. then again, those people might be parked under shelter while our drivers might park under hot sun where the interior of the car can hit 60deg i guess this is the biggest consideration among singaporeans. in other countries where land is vast, they usually have car parks the size of vivocity Link to post Share on other sites More sharing options...
Pureness Clutched December 21, 2012 Share December 21, 2012 i can't understand hybrids from an engineering perspective fuel is burnt to produce power, this power is used up when you accelerate if you put a battery in between power from burnt fuel and acceleration, you'll end up using more power am i right? so the actual savings should come from when you are cruising where the free roll will recharge the batteries which will mean you don't get to free roll that much, thus the real power savings will come from braking but it is beyond logic how you can save up so much brake power that you can save 5km/l which translates averagely to 300km per full tank of 60l Link to post Share on other sites More sharing options...
Passion 5th Gear December 21, 2012 Share December 21, 2012 If not wrong, Honda hybrid cut off the aircon fully when stop at traffic lights, hot air are being blown out, any Honda hybrid owners wanna verify this? You are correct. I sat in Insight before, at traffic light the air con will be switched off. just hot air coming out. Link to post Share on other sites More sharing options...
CH_CO 6th Gear December 21, 2012 Share December 21, 2012 (edited) i can't understand hybrids from an engineering perspective fuel is burnt to produce power, this power is used up when you accelerate if you put a battery in between power from burnt fuel and acceleration, you'll end up using more power am i right? so the actual savings should come from when you are cruising where the free roll will recharge the batteries which will mean you don't get to free roll that much, thus the real power savings will come from braking but it is beyond logic how you can save up so much brake power that you can save 5km/l which translates averagely to 300km per full tank of 60l They use engine brake whenever one lets go of the accelerator , one to slow down the car , two to charge their power for their batteries via a single direction power to charge the battery i suppose via a capacitor. I believe in terms of energy wastage it is better to be used to charge the batt than to be wasted via slowing down and using the power to move the car from a stationary position which is quite fuel consuming. As for free roll, unless u free up ur gear to roll or else there isn't much As for hybrids , i believe the toyotas have done alot more test before they released the 3rd gen and i believe the batts that are designed are suppose to last 10 years or a certain mileage but even if u discount 20% it is still good for 8 years , as for iphones , i have used it for more than 3 years for my 3GS which i used regularly whenever i go overseas and it is still up can going lasting easily over a day but the same cannot be said for a S2 which i bought merely 1 and half year ago. Both are bought for the purpose of using normal size SIM cards but Quality and build is so much different. To me , la sup can only sell cheap. They aren't meant to last . Edited December 21, 2012 by CH_CO Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic December 21, 2012 Share December 21, 2012 i can't understand hybrids from an engineering perspective fuel is burnt to produce power, this power is used up when you accelerate if you put a battery in between power from burnt fuel and acceleration, you'll end up using more power am i right? so the actual savings should come from when you are cruising where the free roll will recharge the batteries which will mean you don't get to free roll that much, thus the real power savings will come from braking but it is beyond logic how you can save up so much brake power that you can save 5km/l which translates averagely to 300km per full tank of 60l but this engineering has proven better fuel saving! when u cruising and u release ur gas pedal, they will charge ur battery full so when complete stop in traffic light u save lots of fuel. basically hybrid car best for city driving but not highway driving Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic December 21, 2012 Share December 21, 2012 Quite good given that enormous size of the car yes some more got power, when u accelerate, it reach 100 easily Link to post Share on other sites More sharing options...
Deckbuild 6th Gear December 22, 2012 Share December 22, 2012 then again, those people might be parked under shelter while our drivers might park under hot sun where the interior of the car can hit 60deg i guess this is the biggest consideration among singaporeans. in other countries where land is vast, they usually have car parks the size of vivocity Maybe some of the Prius owner can cone out and share on how's the battery condition after so many years of drive. Link to post Share on other sites More sharing options...
Deckbuild 6th Gear December 22, 2012 Share December 22, 2012 i can't understand hybrids from an engineering perspective fuel is burnt to produce power, this power is used up when you accelerate if you put a battery in between power from burnt fuel and acceleration, you'll end up using more power am i right? so the actual savings should come from when you are cruising where the free roll will recharge the batteries which will mean you don't get to free roll that much, thus the real power savings will come from braking but it is beyond logic how you can save up so much brake power that you can save 5km/l which translates averagely to 300km per full tank of 60l I just got over 800 km for 30 liter of fuel. Anyway if you are interested, you can do a research on how it works. Cruising with ICE can achieve around 25 to 35 km per liter which charges the batt at the same time. Link to post Share on other sites More sharing options...
Deckbuild 6th Gear December 22, 2012 Share December 22, 2012 yes some more got power, when u accelerate, it reach 100 easily To me it's powerful, I drove the 400, which has a smaller engine. Link to post Share on other sites More sharing options...
Markzz Neutral Newbie April 15, 2013 Share April 15, 2013 (edited) For Hybrid cars, seem all got promotions as: Toyota prius 140K Toyota prius C 97K Honda insight 110K Honda civic hybrid 126K Considering the price factors & also performance of their hybrid, how you guys think? Which car is more worthy to buy? Edited April 15, 2013 by Markzz Link to post Share on other sites More sharing options...
Hexxor 1st Gear April 15, 2013 Share April 15, 2013 Prius 140k seem like a good buy....the thing is the rebate set 45k? Link to post Share on other sites More sharing options...
Spica Clutched April 15, 2013 Share April 15, 2013 btw is the hybrid car use replaceable battery for electric motor? if yes, anyone ever change that battery, say after 3-5 years drive? ↡ Advertisement Link to post Share on other sites More sharing options...
Electric cars
Electric cars
Unusual or Rare Cars - Part 3
Cars at Expo - Apr 2024
Cars We Don't Get to Drive in Singapore
