Donut Supercharged January 19, 2013 Share January 19, 2013 What's up with those batteries used in the plane? Lithium-ion batteries are presumed to be safe to use? ↡ Advertisement Link to post Share on other sites More sharing options...
WTF 4th Gear January 19, 2013 Share January 19, 2013 What's up with those batteries used in the plane? Lithium-ion batteries are presumed to be safe to use? Heard from the news they are for saving fuel cost.......perhaps the re-chargable batteries can cut down on fuel usage....... Link to post Share on other sites More sharing options...
Kb27 Supersonic January 19, 2013 Share January 19, 2013 What's up with those batteries used in the plane? Lithium-ion batteries are presumed to be safe to use? Probably made by Sony. Link to post Share on other sites More sharing options...
Donut Supercharged January 19, 2013 Author Share January 19, 2013 Probably made by Sony. Nope. Made by yusa. The same brandas our car battery. Lol So those who are using yusa cat battery, beware........ Link to post Share on other sites More sharing options...
Donut Supercharged January 19, 2013 Author Share January 19, 2013 Heard from the news they are for saving fuel cost.......perhaps the re-chargable batteries can cut down on fuel usage....... Yeah it's meant to save fuel. But if this brand of battery CMI, get another battery maker to supply Link to post Share on other sites More sharing options...
WTF 4th Gear January 19, 2013 Share January 19, 2013 Yeah it's meant to save fuel. But if this brand of battery CMI, get another battery maker to supply Should recommend them Amaron........at least that's what lots of MCFers recommend too...... Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic January 19, 2013 Share January 19, 2013 thats y its not good plane to have hybrid hahahha jk quite sad that the battery fail on such a new plane, reputation drop Link to post Share on other sites More sharing options...
Kangadrool Supersonic January 19, 2013 Share January 19, 2013 (edited) Think the Japs have been too laid back liao. From cars to electronics/electrical equipment, now to basic battery also problematic. If you have visited Japan recently, you will notice even the manners and social grace also going downhill. Edited January 19, 2013 by Kangadrool Link to post Share on other sites More sharing options...
Sosaria Turbocharged January 19, 2013 Share January 19, 2013 (edited) They use lithium-ion on these new generation aircraft now? Traditionally, the battery is nickel-cadmium type. Lithium-ion has higher energy density than nickel-cadmium, more power and energy stored for the same weight. For the Dreamliner, a lot of electrical systems are used, beyond the usual, to replace some systems that traditionally used hydraulics. Probably that's why they needed to switch to lithium-ion technology. Anyway, aircraft batteries are only used during an emergency as a last resort source of power. There is also a battery at the auxiliary power unit (APU) expressly for starting the APU - I think this is the battery that caused trouble on the JAL aircraft at Boston. For the ANA aircraft with smoke detected, what was the issue? Edited January 19, 2013 by Sosaria Link to post Share on other sites More sharing options...
WTF 4th Gear January 19, 2013 Share January 19, 2013 Thought they found that the battery was badly burnt??? Think news got put photo of it beside a good batt...... Link to post Share on other sites More sharing options...
Wind30 Turbocharged January 20, 2013 Share January 20, 2013 Think the Japs have been too laid back liao. From cars to electronics/electrical equipment, now to basic battery also problematic. If you have visited Japan recently, you will notice even the manners and social grace also going downhill. I think they are more hostile to chinese. Maybe they think we are from China. Link to post Share on other sites More sharing options...
Donut Supercharged January 20, 2013 Author Share January 20, 2013 They use lithium-ion on these new generation aircraft now? Traditionally, the battery is nickel-cadmium type. Lithium-ion has higher energy density than nickel-cadmium, more power and energy stored for the same weight. For the Dreamliner, a lot of electrical systems are used, beyond the usual, to replace some systems that traditionally used hydraulics. Probably that's why they needed to switch to lithium-ion technology. Anyway, aircraft batteries are only used during an emergency as a last resort source of power. There is also a battery at the auxiliary power unit (APU) expressly for starting the APU - I think this is the battery that caused trouble on the JAL aircraft at Boston. For the ANA aircraft with smoke detected, what was the issue? They found out the battery leaked big time and the connections are burnt, resulting in passengers smelling smoke in the cabin Link to post Share on other sites More sharing options...
WTF 4th Gear January 20, 2013 Share January 20, 2013 They found out the battery leaked big time and the connections are burnt, resulting in passengers smelling smoke in the cabin Imagine if the plane is in the middle of the Atlantic or Pacific ocean and the smoke is toxic....... ↡ Advertisement Link to post Share on other sites More sharing options...
My EV journey to the i4
Boeing 737 Max 9 - Alaska Airlines blowout
Battery Voltage up & down
New problems on the now grounded Boeing 737 Max found!
Request for dark mode
The Electric Vehicle Charging Problem
Lithium-Iron Battery (LFP) - New & Better Alternative?
