Riverfish 2nd Gear January 22, 2013 Share January 22, 2013 Hi, need some advice here. Just came back from a regular servicing of my 7-yr old Lancer GLX, and was told by the mechanic that the valve cover gasket and plug seal needed to be replaced for $195, as there was some leakage seen on the spark plugs. I thought those things are just some rubber seals, and was wondering if that kinda price is reasonable? Thanks for any advice. ↡ Advertisement Link to post Share on other sites More sharing options...
Forte3737 5th Gear January 22, 2013 Share January 22, 2013 you have to check with stockists for their price. WS always make $$ from parts they get from stockists Link to post Share on other sites More sharing options...
Wishxsr 2nd Gear January 22, 2013 Share January 22, 2013 Hi, need some advice here. Just came back from a regular servicing of my 7-yr old Lancer GLX, and was told by the mechanic that the valve cover gasket and plug seal needed to be replaced for $195, as there was some leakage seen on the spark plugs. I thought those things are just some rubber seals, and was wondering if that kinda price is reasonable? Thanks for any advice. Dont know about Lancer GLX, but its cost $120 for a 6 year old Altis 3 months ago (Friend Car) Link to post Share on other sites More sharing options...
Simpleonly 5th Gear January 22, 2013 Share January 22, 2013 Change my 7 yr old trajet before... Got the gasket seal from stockie..less then $30.. When to WS say plug seal x4 also need to change $8/PCs buy froom WS.. Labour for all the above change ard$30_40.. Forget the actual,price.. So total ard$100 nia Link to post Share on other sites More sharing options...
Matkeith Neutral Newbie January 22, 2013 Share January 22, 2013 Hi, need some advice here. Just came back from a regular servicing of my 7-yr old Lancer GLX, and was told by the mechanic that the valve cover gasket and plug seal needed to be replaced for $195, as there was some leakage seen on the spark plugs. I thought those things are just some rubber seals, and was wondering if that kinda price is reasonable? Thanks for any advice. It is advisable to change the valve cover gasket and plug seal ASAP. Leaving it unattained, oil may flood the spark plugs well, leading to misfiring and cause damage to the ignition coil which occur higher repair bill. Some workshop don't really explain to their customers what in the repair bill. Ask your mechanic what does the $190 includes. Usually for such situation the 4 spark plugs may need replacement too. Valve cover gasket, plug seals, spark plus and labour should be around the price range if not, SLIGHTLY lower. Total labour hour should be around 2-3 hours. If you are comfortable with the workshop, why not let them do all the work? Treat it as rapport building. Link to post Share on other sites More sharing options...
Earthng Clutched January 22, 2013 Share January 22, 2013 Cfm expensive.Subaru impreze 10 x 13271AA071 Rocker Cover Washers, 04 x 10966AA000 GSKT-SPARK PL PIP 02 x 13294AA053 GSKT-ROCKER COVER. only cost $100. Link to post Share on other sites More sharing options...
Riverfish 2nd Gear January 22, 2013 Author Share January 22, 2013 The mechanic didn't say the spark plugs needed to be replaced. Actually I only replaced the plugs at the same workshop during last servicing about half a year ago. They were those more expensive types (iradium or something, can't recall). Yeah, did check around on the web and looks like there are much cheaper gaskets to buy, but very hesitant to DIY. :) May just go back to the workshop to get them replaced. Anyway, what's $195 compared with the $90k COE now? Link to post Share on other sites More sharing options...
0330 Clutched January 22, 2013 Share January 22, 2013 Depends on your vehicle's make/model, the labour to replace the valve cover gasket can be as expensive as the parts itself. Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged January 22, 2013 Share January 22, 2013 Bought frm GS auto for $20+ then went to replace at Mal at RM50. total damage less than S$50. Link to post Share on other sites More sharing options...
Othello Supersonic January 27, 2013 Share January 27, 2013 yup, just bought mine last week for my Trajet. valve cover gasket - $18 plug seal - $6.5 each Labour - $40 Link to post Share on other sites More sharing options...
Ry0suk1 1st Gear May 12, 2014 Share May 12, 2014 anyone know where to find the lancer cs3 valve cover gasket and plug seal? went to WS was quoted $235 including spark plugs.. Link to post Share on other sites More sharing options...
Simpleonly 5th Gear May 13, 2014 Share May 13, 2014 Google Ming ghee... They are stockist of major cars brand... Your parts cost shall be ard the same as bro Othello about. Normal Spark plug only cost ard 4buck each. Do update us after u have done it for sharing... Thanks Link to post Share on other sites More sharing options...
Fuelsaver Supercharged October 3, 2016 Share October 3, 2016 labor for mine quoted was S$100. ok anot? Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear October 3, 2016 Share October 3, 2016 Bring parts go JB, alot cheaper lor !! labor for mine quoted was S$100. ok anot? Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic October 3, 2016 Share October 3, 2016 Bring parts go JB, alot cheaper lor !!But now added with toll fee, not worth it unless u go there pump petrol, wash car, grocery etc Link to post Share on other sites More sharing options...
Fuelsaver Supercharged October 3, 2016 Share October 3, 2016 So ok anot? Link to post Share on other sites More sharing options...
Carnoob Supercharged October 3, 2016 Share October 3, 2016 So ok anot? Depends on your car model, Toyota cars no need $100. Conti cars may be more expensive Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear October 3, 2016 Share October 3, 2016 (edited) Many ways bro !! Fixed car, next door wash and wax and polish RM80, if before noon, go movie RM8/pax, then grocery, then dinner + FULL Tank- Shake + 1 pack Marlboro Merah - 1 stick RM17. Value for Money Trip lor It is so good my wife keep asking when I go in for servicing or repair..... Clothing ...... also very good and cheap. But now added with toll fee, not worth it unless u go there pump petrol, wash car, grocery etc Edited October 3, 2016 by Apple-Tree ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Car hit by fallen tree? NParks may cover claim
Automatic Whole Car Cover with Remote Control
Drive shaft rubber boot/cover
Plug-and-play vaccine
Condensation in headlight(s)
Valve stem washer?
Valve stem washer?
Side mirror back cover replacement. where and how much?
