Nlatio Turbocharged February 12, 2013 Share February 12, 2013 hey guys, need some expert advice on fridges. My MIL's home fridge, 12 years old liao. Suddenly not cold already. I ask one of fridge salesman and his advise is to switch off the fridge for 2 hours and switch on again. See if it is back to normal. If it is still no good, then the fridge up lorry liao. MIL followed instructions and still find the fridge not cold anymore. So my question is: what else can we do? Is it due to no more compressor gas? Can ask the repair guy to come and see? or just throw and buy new one? Clear all the stuff in the fridge.... off it.... clean it.... on it back.... should be okay after that... if not.... time to visit the store.... ↡ Advertisement Link to post Share on other sites More sharing options...
Kungfu Clutched February 12, 2013 Share February 12, 2013 adjusting the 2 front feet,means till the fridge tilt one end??? Link to post Share on other sites More sharing options...
Opel17 6th Gear February 12, 2013 Share February 12, 2013 adjusting the 2 front feet,means till the fridge tilt one end??? The tilt need not be very much and would not be obvious visually. Open the door halfway, and gradually adjust the 2 front feet until the door started to move. Link to post Share on other sites More sharing options...
Kungfu Clutched February 12, 2013 Share February 12, 2013 alrite man....will try,anyway.............the top freezer is back to life...............guess if the motor is new...........is new...........tks for the advice Link to post Share on other sites More sharing options...
Kungfu Clutched March 9, 2013 Share March 9, 2013 Fridge repair guy came.......changed the motor for my Sharp........now top n bottom compartment very cold............no issue.........BUT.....got water on the floor leh.......is it usual??? other than that nothing else.........any advice???? Link to post Share on other sites More sharing options...
Opel17 6th Gear March 9, 2013 Share March 9, 2013 (edited) Fridge repair guy came.......changed the motor for my Sharp........now top n bottom compartment very cold............no issue.........BUT.....got water on the floor leh.......is it usual??? other than that nothing else.........any advice???? I think the water is due to the "defrost cycle". Is there a drain tray at the bottom of your fridge ? Usually, you can reach the trap by pulling out a removable grille/panel at the front bottom of the fridge. Usually, the condensate would evaporate on it own, and no need to pour it away. Clear away the condensate and monitor further. If you had adjusted the front feet of the fridge [to help door close], then you may need to put back to previous setting. Perhap, the drain tray is tilted too much and cause overflow. Edited March 9, 2013 by Opel17 Link to post Share on other sites More sharing options...
Kungfu Clutched March 9, 2013 Share March 9, 2013 I think the water is due to the "defrost cycle" - oh,so nothing is wrong with my fridge (in fact, I dun suspect anything wrong as it is functioning properly) Is there a drain tray at the bottom of your fridge? - Yes, there is. Usually, you can reach the trap by pulling out a removable grille/panel at the front bottom of the fridge. Usually, the condensate would evaporate on it own, and no need to pour it away. Clear away the condensate and monitor further. - alrite, will try tmr If you had adjusted the front feet of the fridge [to help door close], then you may need to put back to previous setting. Perhaps, the drain tray is tilted too much and cause overflow. - tks so much for the advice Link to post Share on other sites More sharing options...
Kungfu Clutched March 10, 2013 Share March 10, 2013 I took some pics at the back of the fridge....show some condensation on one of the pipe....but the "water on the floor" syndrome not so bad already.......but motor bit hot though. Any cause for concern???? Link to post Share on other sites More sharing options...
Opel17 6th Gear March 10, 2013 Share March 10, 2013 I took some pics at the back of the fridge....show some condensation on one of the pipe....but the "water on the floor" syndrome not so bad already.......but motor bit hot though. Any cause for concern???? The tubing with the frost/ice buildup is the suction line. When the compressor operate in on-off cycle. When the compressor is off, the frost/ice will melt into water on the floor. This water is different from the defrost water, which is frost melted from the freezer cooling coil. The motor is actually the refrigerant compressor (black color) with built-in motor. It is normal for it to be hot. Link to post Share on other sites More sharing options...
Kungfu Clutched March 11, 2013 Share March 11, 2013 so as conclusion.....there is no cause for concern.....cause calling the fridge man to come check it out and he not yet got back to me. Link to post Share on other sites More sharing options...
Mysportwish 1st Gear March 11, 2013 Share March 11, 2013 i encountered fridge not cold before, service man came and it was a thermostat defective.. changed it and everything is well again Link to post Share on other sites More sharing options...
Sdf4786k Twincharged January 31, 2018 Share January 31, 2018 (edited) I have a fridge not cold but Freezer cold. Any clue what to check for a fisher and payker two door fridge. Freezer at the bottom type. Have clear the rear condensor tray already Looking to see if there is a Damper Control Assembly but google nothing came out Edited January 31, 2018 by Sdf4786k Link to post Share on other sites More sharing options...
Alpha78 6th Gear January 31, 2018 Share January 31, 2018 I have a fridge not cold but Freezer cold. Any clue what to check for a fisher and payker two door fridge. Freezer at the bottom type. Have clear the rear condensor tray already Looking to see if there is a Damper Control Assembly but google nothing came out Typically the cold air goes to the freezer first, and some fan is used to suck the cold air to distribute to the fridge compartment. Most fridge designs have a hole somewhere that allows the condensation to flow down to the bottom, as well as to let the cold air down into the fridge compartment. If this drainage is choked (i.e. ice buildup), the fridge may also not be cold. Try turning off the fridge for 12 hours and see if it helps. I used to do quick defrost on my freezer by pouring boiling water down the drainage hole. Because the defrost sensor was not working. 2 Link to post Share on other sites More sharing options...
Evillusion Supersonic January 31, 2018 Share January 31, 2018 (edited) I have a fridge not cold but Freezer cold. Any clue what to check for a fisher and payker two door fridge. Freezer at the bottom type. Have clear the rear condensor tray already Looking to see if there is a Damper Control Assembly but google nothing came out try switching off for 2-4 hrs....can clean the fridge while at it. Usually the older well-known brands is due to motor auto switched off due to over-running. Maybe caused by the door not shut fully. Or just that you need to clean the area around the fan as dust may accumulate and covers the coil and the fan.But those new korean ones doesnt have the auto-switch off function (told by the repairmen when my lg had the same problem......hope this help. Edited January 31, 2018 by Eviilusion Link to post Share on other sites More sharing options...
Ender Hypersonic January 31, 2018 Share January 31, 2018 (edited) I have a fridge not cold but Freezer cold. Any clue what to check for a fisher and payker two door fridge. Freezer at the bottom type. Have clear the rear condensor tray already Looking to see if there is a Damper Control Assembly but google nothing came out Just recently my LG fridge has the same symptoms. Freezer still can freeze, but the fridge temp is 14 c.What I did is pull the fridge out, and clean the coil and fan and observe. Notice that the fan doesn't spin even when the compressir kicked in. Measured that there is AC voltage to the fan, so means the power to fan is ok. Try hand spinning the fan, and it can spin for a while. Next I just oil it while manually turning the fan. Repeat oiling it, until it can spin by itself. Now the fridge is cold liao, can go to 2 degree. Edited January 31, 2018 by Ender 4 Link to post Share on other sites More sharing options...
Jtb 6th Gear January 31, 2018 Share January 31, 2018 I have a fridge not cold but Freezer cold. Any clue what to check for a fisher and payker two door fridge. Freezer at the bottom type. Have clear the rear condensor tray already Looking to see if there is a Damper Control Assembly but google nothing came out turn the mechanical timer or check where is the fan mounted as seemed to be stuck that caused no circulation. Make sure power is switch off first. 2 Link to post Share on other sites More sharing options...
Sdf4786k Twincharged January 31, 2018 Share January 31, 2018 turn the mechanical timer or check where is the fan mounted as seemed to be stuck that caused no circulation. Make sure power is switch off first. I pull the fan out and seems like the fan a little resistance to spin for both the freezer and the Fridge. Link to post Share on other sites More sharing options...
Evillusion Supersonic January 31, 2018 Share January 31, 2018 I pull the fan out and seems like the fan a little resistance to spin for both the freezer and the Fridge.something new to learn everyday..... ↡ Advertisement Link to post Share on other sites More sharing options...
Crazy weather in Singapore ?
Car air-con
Car air-con
Electrical appliances
Everything about ice creams
When anything happens…CHANGE CAR!
LG Fridge door open sensor keeps beeping
Neighbour from the artic
Which fridge brand is better?
