Camrytron 6th Gear March 26, 2013 Share March 26, 2013 Last week my camry became 10 foot lorry than manage to change the absorber after sacrificing my body massage section. Now like riding in a boat.This is my 1st time using kyb absorber gas shock.Previously got change once 2yrs back but ws use Toyota original shock (should be Thailand shock)The ride is good than.. but kyb(Toyota Japan shock)seem like not so good lei.Thought kyb Japan should be better than Thailand shock.Or I had installed the boat absorber ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Watwheels Supersonic March 26, 2013 Share March 26, 2013 Kyb not necessary from Japan, some are from MY. Could be the spring. How long have your springs been in use? Are they stock? 2 Link to post Share on other sites More sharing options...
RadX Moderator March 26, 2013 Share March 26, 2013 row row row row your boat...gently down the road...... Link to post Share on other sites More sharing options...
Camrytron 6th Gear March 26, 2013 Author Share March 26, 2013 Kyb not necessary from Japan, some are from MY. Could be the spring. How long have your springs been in use? Are they stock? Ya spring are stock and 7yrs liao Link to post Share on other sites More sharing options...
Camrytron 6th Gear March 26, 2013 Author Share March 26, 2013 row row row row your boat...gently down the road...... See me better siam far far cos my titanic will hit u woh Link to post Share on other sites More sharing options...
Mockngbrd Supersonic March 26, 2013 Share March 26, 2013 Put in Bilsteins lo 2 Link to post Share on other sites More sharing options...
Yuan 6th Gear March 26, 2013 Share March 26, 2013 Ya spring are stock and 7yrs liao Springs can last for a long time. Check your shocks again (through a workshop). 2 Link to post Share on other sites More sharing options...
Camrytron 6th Gear March 26, 2013 Author Share March 26, 2013 Springs can last for a long time. Check your shocks again (through a workshop). Just change the front shock and now I suspect it's the rear shock also uplorry. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear March 26, 2013 Share March 26, 2013 hmm sure bo my camry i fit kyb excel g at 4 yrs mark now 8 yr liao still ok le not boat i on michelin vivacy tyre somemore leh soft soft 2 Link to post Share on other sites More sharing options...
Camrytron 6th Gear March 26, 2013 Author Share March 26, 2013 hmm sure bo my camry i fit kyb excel g at 4 yrs mark now 8 yr liao still ok le not boat i on michelin vivacy tyre somemore leh soft soft I think maybe is my rear shock also got liao. Tmr after confirm with ws than update here Link to post Share on other sites More sharing options...
5936 1st Gear March 26, 2013 Share March 26, 2013 Some aftermarket KYB came marked MIC. 2 Link to post Share on other sites More sharing options...
Syaheerbmw 3rd Gear March 26, 2013 Share March 26, 2013 My ride currently using KYB MIJ... Good leh.. Try check ur springs... I changed to lowering sports springs at the same time when changing my shocks... 2 Link to post Share on other sites More sharing options...
Yuan 6th Gear March 26, 2013 Share March 26, 2013 hmm sure bo my camry i fit kyb excel g at 4 yrs mark now 8 yr liao still ok le not boat i on michelin vivacy tyre somemore leh soft soft Same here. My previous ride using KYB gas shocks. Made In Japan. Change all 4 with wheel alignment (which is a must) after that. Everything works fine till the day I sold my car. Link to post Share on other sites More sharing options...
Camrytron 6th Gear March 26, 2013 Author Share March 26, 2013 Me very suay.. Just change front shock less than 24hrs and now the rear jam liao. Tmr change the rear. Will be using KYB GAS absorber too since good review here Link to post Share on other sites More sharing options...
Moredhel 2nd Gear March 26, 2013 Share March 26, 2013 Me very suay.. Just change front shock less than 24hrs and now the rear jam liao. Tmr change the rear. Will be using KYB GAS absorber too since good review here You sure your workshop never touch hand leg? KYB general good for slightly firmer ride. Otherwise, save money and go for thailand absorbers, cheap and good. 2 Link to post Share on other sites More sharing options...
Camrytron 6th Gear March 26, 2013 Author Share March 26, 2013 You sure your workshop never touch hand leg? KYB general good for slightly firmer ride. Otherwise, save money and go for thailand absorbers, cheap and good. My eyes never leave the car Absorber is kyb confirm. Rear absorber spoilt also just confirm. Will get the rear absorber change tmr. Link to post Share on other sites More sharing options...
Yuan 6th Gear March 27, 2013 Share March 27, 2013 My eyes never leave the car Absorber is kyb confirm. Rear absorber spoilt also just confirm. Will get the rear absorber change tmr. Remember to do wheel alignment. Link to post Share on other sites More sharing options...
Solar Turbocharged March 27, 2013 Share March 27, 2013 Last week my camry became 10 foot lorry than manage to change the absorber after sacrificing my body massage section. Now like riding in a boat. This is my 1st time using kyb absorber gas shock. Previously got change once 2yrs back but ws use Toyota original shock (should be Thailand shock)The ride is good than.. but kyb(Toyota Japan shock)seem like not so good lei. Thought kyb Japan should be better than Thailand shock. Or I had installed the boat absorber my previous LGT's shocks leaked oil on its 4-5th year. if i'm not wrong, kyb also. then changed to bilsteins & tein springs setup. no more rocking.. but got good massage for a couple of years before i sold the car off ↡ Advertisement 2 Link to post Share on other sites More sharing options...
KYB Shock absorber ride like boat
KYB oil-a-just
KYB oil-a-just
KYB Absorber
KYB Absorber
JDM - KYB Shock Absorbers : where to get?
