Teewhy 1st Gear December 2, 2018 Share December 2, 2018 I had the 18" Leggeras, 8JJ. Weight around mid 8kg. 17" should be closer to low 8s I guess. Either 7.5 or 8 will fit 225 tyres. For a more sporty look, go with 8 so that the tyres doesn't get the "muffin" bulge. FC is all relative. Increasing a size up won't affect much one. ET is the offset of the rim. How far it gets pushed out. I'd go with 17x8 with 225 tyres. Thank you very much for your advise! Will share a photo tomorrow after I've changed it. I don't understand the Weight (KG) portion though. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Theoldjaffa Hypersonic December 2, 2018 Share December 2, 2018 Thank you very much for your advise! Will share a photo tomorrow after I've changed it. I don't understand the Weight (KG) portion though. Europeans use comma as decimals Link to post Share on other sites More sharing options...
Teewhy 1st Gear December 2, 2018 Share December 2, 2018 Europeans use comma as decimals Link to post Share on other sites More sharing options...
Beregond Supersonic December 3, 2018 Share December 3, 2018 Thank you very much for your advise! Will share a photo tomorrow after I've changed it. I don't understand the Weight (KG) portion though. I would advice 17x 7.5 for 225 width tyres Link to post Share on other sites More sharing options...
Teewhy 1st Gear December 3, 2018 Share December 3, 2018 I would advice 17x 7.5 for 225 width tyresWould like to know, why 7.5jj instead of 8? Link to post Share on other sites More sharing options...
Beregond Supersonic December 3, 2018 Share December 3, 2018 Would like to know, why 7.5jj instead of 8? Not say cannot 0.5' different only. U divide into 2 . 1 side of the rims only 1/4 ' different. i feel 7.5 width will look nicer on most 225 tyres. ( personal experience ) 1 Link to post Share on other sites More sharing options...
Adrianli Hypersonic December 4, 2018 Share December 4, 2018 Eversince i upgraded my rims from 17 to 20, my fc never gone above 9km/L. But the look and size is always amaze me daily. Link to post Share on other sites More sharing options...
Theoldjaffa Hypersonic December 4, 2018 Share December 4, 2018 (edited) Ya it's a matter of personal preference whether you like it "Touring" or "Sports" 17x7.5 on 225 - it's got a bit of a "muffin top" 18x8 on 225 - more tapered to the top Edited December 4, 2018 by Theoldjaffa 3 Link to post Share on other sites More sharing options...
Beregond Supersonic December 4, 2018 Share December 4, 2018 Ya it's a matter of personal preference whether you like it "Touring" or "Sports" 17x7.5 on 225 - it's got a bit of a "muffin top" 08A7648A-2E51-4AFB-A013-DFE25E7A04FE.jpeg 18x8 on 225 - more tapered to the top B82BDD52-1A22-4888-A6B0-8E3652FF8887.jpeg very nice sample photo. can notice the btm photo with the 17x8. the sidewall is slanted abit. the most ideal would be a straight sidewall. Link to post Share on other sites More sharing options...
Teewhy 1st Gear December 13, 2018 Share December 13, 2018 What tyre pressure do y'all recommend to pump for 225/50 R17 tyres? Link to post Share on other sites More sharing options...
Roberttan 5th Gear December 14, 2018 Share December 14, 2018 What tyre pressure do y'all recommend to pump for 225/50 R17 tyres? can share what car is that ? tyre pressures are range from generally from 200kpa to 280kpa Link to post Share on other sites More sharing options...
Ronkovic 5th Gear December 14, 2018 Share December 14, 2018 What tyre pressure do y'all recommend to pump for 225/50 R17 tyres? I suppose you'd be OK at around 32 to 36 psi? Can't remember what that is in Kpa tho' although the Air Pump at the petrol station would allow you to toggle between both. Link to post Share on other sites More sharing options...
KimHwee 1st Gear December 14, 2018 Share December 14, 2018 What tyre pressure do y'all recommend to pump for 225/50 R17 tyres? Usually do 230 kPa for 215/50/R17. Not sure if there is a big difference for 225/50/R17. Also understand that there is a recommended tyre pressure for each car. You might want to check that first and adjust from there to your liking. Link to post Share on other sites More sharing options...
Teewhy 1st Gear December 14, 2018 Share December 14, 2018 can share what car is that ? tyre pressures are range from generally from 200kpa to 280kpa Mazda 3. The recommended pressure for stock wheels, 205/60R16 is 36 psi. Now sure if I should maintain this. The profile is somewhat similar Link to post Share on other sites More sharing options...
Roberttan 5th Gear December 15, 2018 Share December 15, 2018 Mazda 3. The recommended pressure for stock wheels, 205/60R16 is 36 psi. Now sure if I should maintain this. The profile is somewhat similar 36Psi = 250Kpa 2.5 Bar for Jps car if recommended is 36psi propably for Green Driving = Fuel saving for your case Mazda 3 i think is OK to fill 36psi But wondering why 225/50/17 (correct me if i am wrong)? for me i will prefer 215/50/17 for mazda 3 Link to post Share on other sites More sharing options...
Teewhy 1st Gear December 15, 2018 Share December 15, 2018 36Psi = 250Kpa 2.5 Bar for Jps car if recommended is 36psi propably for Green Driving = Fuel saving for your case Mazda 3 i think is OK to fill 36psi But wondering why 225/50/17 (correct me if i am wrong)? for me i will prefer 215/50/17 for mazda 3 I upsized to 17” japan rims with 8jj. 225 for more stability and can protect my rather pricy rims too Link to post Share on other sites More sharing options...
Theoldjaffa Hypersonic December 15, 2018 Share December 15, 2018 I upsized to 17â japan rims with 8jj. 225 for more stability and can protect my rather pricy rims too ð 215/50 and 225/45 are common sizes though. My size is rare and much more expensiveSo end up u bought the TC105? Link to post Share on other sites More sharing options...
No_worries 6th Gear December 15, 2018 Share December 15, 2018 I upsize my rims from 16 inch 205 55 r16 to 18 inch 225 40 r18. 3CA2894F-BD79-4E0A-BE91-88D7CC3EEC24.jpeg Yes fuel economy will drop but you will notice the handling improvement immediately . I also ordered a eibach pro kit to lower my car but not done yet ↡ Advertisement 6 Link to post Share on other sites More sharing options...
Does rims change shape/warp over time?
Shipping USA Rims
Shipping USA Rims
A very touching story ..... truly love conquers ALL
Singapore Brand Rims VS China Brand Rims
Nice / Rare Vehicle Registration Number
Someone's rims and tyres stolen at KSL carpark
