Jacklim82 Neutral Newbie April 5, 2013 Share April 5, 2013 Hi,Anyone on d1 spec coilover?Any review for this coilover?THanks ↡ Advertisement Link to post Share on other sites More sharing options...
Lanceraz Clutched May 16, 2013 Share May 16, 2013 anyone..... Link to post Share on other sites More sharing options...
Zerstorer 1st Gear May 16, 2013 Share May 16, 2013 Performs well but the dampers don't seem to last very long. They wear out at around 2yr mark. I'm on the same set of coils but 3rd set of dampers in 6yrs. 1 Link to post Share on other sites More sharing options...
Lanceraz Clutched June 1, 2013 Share June 1, 2013 hi, yours is twin tube or mono tube ....tks Link to post Share on other sites More sharing options...
Squall9281 Neutral Newbie June 2, 2013 Share June 2, 2013 Performs well but the dampers don't seem to last very long. They wear out at around 2yr mark. I'm on the same set of coils but 3rd set of dampers in 6yrs. Did you tracked on them? Link to post Share on other sites More sharing options...
Zerstorer 1st Gear June 14, 2013 Share June 14, 2013 Monotube. Never tracked on them, just road usage. Link to post Share on other sites More sharing options...
88rusher88 Clutched July 12, 2013 Share July 12, 2013 they got review in sgcarmart. http://www.sgcarmart.com/news/writeup.php?AID=184 1 Link to post Share on other sites More sharing options...
Timbuktoo 1st Gear July 25, 2013 Share July 25, 2013 Performs well but the dampers don't seem to last very long. They wear out at around 2yr mark. I'm on the same set of coils but 3rd set of dampers in 6yrs. pretty much the same problem for BC. Wears out after the 2 year mark. Link to post Share on other sites More sharing options...
6789city Neutral Newbie August 3, 2013 Share August 3, 2013 BC should be better though, i've seen many people using it Link to post Share on other sites More sharing options...
6789city Neutral Newbie August 3, 2013 Share August 3, 2013 Performs well but the dampers don't seem to last very long. They wear out at around 2yr mark. I'm on the same set of coils but 3rd set of dampers in 6yrs. Bro. Dont all coilovers wear out in 2 years? My dad's FD2r is running ohlins dvf , and the dampers scrapped thru only 2.5 years not bad liao Link to post Share on other sites More sharing options...
D4rkFly3r Neutral Newbie August 8, 2013 Share August 8, 2013 If coilover can last for about 2 years is considered not bad already. Link to post Share on other sites More sharing options...
Yuan 6th Gear August 8, 2013 Share August 8, 2013 BC should be better though, i've seen many people using it I have used BC for more than 2 years and they were still working after that mark. Dampers can be serviced for BC. Link to post Share on other sites More sharing options...
Timbuktoo 1st Gear August 14, 2013 Share August 14, 2013 Bro. Dont all coilovers wear out in 2 years? My dad's FD2r is running ohlins dvf , and the dampers scrapped thru only 2.5 years not bad liao agreed. They all wear out in 2 years or so. I have used BC for more than 2 years and they were still working after that mark. Dampers can be serviced for BC. Every part in BC can be changed, Dampers, Springs, Pillowball mount, etc. But after 2 years most parts are meant to fail. So even if they can be changed, is it worth the money to change one item at a time? Do the math. It is probably worth changing to a whole new set of coils after 2 years. Link to post Share on other sites More sharing options...
Therock610 Clutched September 5, 2013 Share September 5, 2013 Is changing the damper for BC expensive? Link to post Share on other sites More sharing options...
Yeobt Supercharged October 2, 2013 Share October 2, 2013 I hv no idea what coil I'm using now cos it came with it when I bought the used car few years back. My coilover are still working well for at least 3 years. Touch wood..... Link to post Share on other sites More sharing options...
Bieffe 2nd Gear January 23, 2014 Share January 23, 2014 There is also a brand D2 is it same as D1 cos the website are linked. Link to post Share on other sites More sharing options...
Ake109 6th Gear October 14, 2014 Share October 14, 2014 I using KWv2. After 2 years (and under 30k) , one of the front dampers also up lorry. Had to change entire front set for about 40% cost of a new full set. Now hoping rears don't go.... Link to post Share on other sites More sharing options...
bellboy 4th Gear October 14, 2014 Share October 14, 2014 I'm using D1 Spec on my 1.5 ton car for the past 2 years. Should be almost 40,000km already. Still no problem. But I'm crossing my fingers already since its well-know that coilovers don't last much longer than 2 years. Price is not expensive, so I don't mind to change back to new D1 Spec. Just that I find it troublesome to go down the workshop at Ubi. ↡ Advertisement Link to post Share on other sites More sharing options...
