Peqasus 1st Gear April 9, 2013 Share April 9, 2013 Hi all, I'm driving a 07 avante. Just yesterday my engine light came on and I sent down to Komoco to see what's wrong. It was diagnosed to be a catalytic converter issue. My mileage is only at 97k km and always been using unleaded petrol. Anyone else has this issue? ↡ Advertisement Link to post Share on other sites More sharing options...
kqkhlj Clutched April 15, 2013 Share April 15, 2013 what exactly is the issue? what is the code? Catalytic converter very difficult to spoil, need to be super lucky then will happen. maybe sensor dirty or Catalytic converter needs washing. Link to post Share on other sites More sharing options...
Ooosh 1st Gear April 15, 2013 Share April 15, 2013 Normally it is a due to a clogged cat or dirty oxygen sensor which is mounted on the cat. This sensor is very sensitive to any air differences passing through the cat. My car is already running 120k and the Engine light came up. Upon scanning with an OBD scanner, the error code came out to be P0420 which is a cat error code. So went to workshop, took out cat, see through it, there are no blockage, it was perfectly healthy so i cleared the engine light using the OBD scanner. How do you know if it is a clogged cat is when you start car, ask a friend to rev the throttle and you stand near the exhaust to listen....if you near metal clinking sound, there are bits are clogged in the cat... In my opinon, if the cat is not clogged there is nothing much to worry about, just buy a OBD scanner like Ultra guage to clear the check engine light. Link to post Share on other sites More sharing options...
Altivo 3rd Gear April 15, 2013 Share April 15, 2013 (edited) Honestly, I don't really trust Komoco. The first time when the CEL came on for my avante, the mechs at Komoco told me not to pump RON92 and 95. Must use 98. What rubbish. I went to 2 more workshops and asked for their opinions. Both told me my error code P2096 was very common for avantes and is not necessarily due to catalytic converter issue. They just told me to get a bottle of fuel injection cleaner and the CEL will go off after a few days. I did and the CEL has not come back since. Edited April 15, 2013 by Altivo Link to post Share on other sites More sharing options...
Leijasper 1st Gear April 15, 2013 Share April 15, 2013 Honestly, I don't really trust Komoco. The first time when the CEL came on for my avante, the mechs at Komoco told me not to pump RON92 and 95. Must use 98. What rubbish. I went to 2 more workshops and asked for their opinions. Both told me my error code P2096 was very common for avantes and is not necessarily due to catalytic converter issue. They just told me to get a bottle of fuel injection cleaner and the CEL will go off after a few days. I did and the CEL has not come back since. Last time I was driving an 08 avante, if I pump Caltex 92/95, check light would appear.. 98, den nothing happens.. So I look for alternative.. Went esso, pump 5000 which is equalievent to Caltex 95, no more check light pro :) Some mechanics says it's caused by jb petrol, I don't rules out the possibility as I does pump jb petrol on e in a while.. Manage to solve by switching brand of petrol used :) Anyway, if u go to Hyundai forum, there's a Christmas list of common pro wit avante.. But so far so gd, no breaks down nor major repair happens during the period of my ownership till the day aft I sign on the papers to sold it off.. Funny things did happen along the way thou, but still it delivered me to the dealer safely :) Link to post Share on other sites More sharing options...
kqkhlj Clutched April 22, 2013 Share April 22, 2013 my korean car had been on jbee oil for 3 years already, now already 120k, changed petrol filter every year, so far, so good. Link to post Share on other sites More sharing options...
Hshs 5th Gear April 23, 2013 Share April 23, 2013 Pump JB since day one. 6.5yr 100k mileage. Not issue at all. Other than wear and tear. This car never give me any problem. Very reliable car. Better than my previous car Corolla. Maybe luck? Link to post Share on other sites More sharing options...
Altivo 3rd Gear April 23, 2013 Share April 23, 2013 Just changed the fan belt and water pump for the first time yesterday. Despite my mileage being 130k, the fan belt was still in good condition. Also, it helps when you use good coolant (not water or distilled water) as there were no signs of rust and corrosion on the impellers of the water pump. Link to post Share on other sites More sharing options...
Hshs 5th Gear April 23, 2013 Share April 23, 2013 Forgot to mention, I replace the fuel strainer at 60k. And never skip any normal or major servicing. Don't know is it related or not. Link to post Share on other sites More sharing options...
Joe8688 Neutral Newbie April 23, 2013 Share April 23, 2013 Pump JB since day one. 6.5yr 100k mileage. Not issue at all. Other than wear and tear. This car never give me any problem. Very reliable car. Better than my previous car Corolla. Maybe luck? Not luck,i am also driving avante.so far no major problem.Had clocked more than 200k. Link to post Share on other sites More sharing options...
Joe8688 Neutral Newbie April 23, 2013 Share April 23, 2013 Hi all, I'm driving a 07 avante. Just yesterday my engine light came on and I sent down to Komoco to see what's wrong. It was diagnosed to be a catalytic converter issue. My mileage is only at 97k km and always been using unleaded petrol. Anyone else has this issue? I never had such issue though my mileage is more than 200k. Link to post Share on other sites More sharing options...
Hshs 5th Gear April 23, 2013 Share April 23, 2013 Just changed the fan belt and water pump for the first time yesterday. Despite my mileage being 130k, the fan belt was still in good condition. Also, it helps when you use good coolant (not water or distilled water) as there were no signs of rust and corrosion on the impellers of the water pump. My fan belt still in good condition too. Think this is the only belt we need to replace right? Unlike other model got Aircorn, power streeing, timing belt. Link to post Share on other sites More sharing options...
Kenlee79 Neutral Newbie June 7, 2013 Share June 7, 2013 I also having this issue now. My CEL is on and i bring to KOMOCO to check. The mechanic told me is due to catalytic converter spoiled and need to be replace. The cost is about 3K - 4K.. I bring the car to check in workshop nearby my area, the mechanic said may be i pump petrol in JB that causing this. He just clear to code for me. But after 2 days the CEL on again. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear June 7, 2013 Share June 7, 2013 I also having this issue now. My CEL is on and i bring to KOMOCO to check. The mechanic told me is due to catalytic converter spoiled and need to be replace. The cost is about 3K - 4K.. I bring the car to check in workshop nearby my area, the mechanic said may be i pump petrol in JB that causing this. He just clear to code for me. But after 2 days the CEL on again. bro check your oxygen sensor. clean and see if it helps anot. not necessary is catalytic converter issue. Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged June 7, 2013 Share June 7, 2013 I also having this issue now. My CEL is on and i bring to KOMOCO to check. The mechanic told me is due to catalytic converter spoiled and need to be replace. The cost is about 3K - 4K.. I bring the car to check in workshop nearby my area, the mechanic said may be i pump petrol in JB that causing this. He just clear to code for me. But after 2 days the CEL on again. Don't listen to the b-------t about pumping JB petrol. My ex-Avante was on JB petrol since the second tank of petrol and I have not encountered such problems until I sold it at about 90+K km. On the Avante, I started off with Petronas RON97 and thereafter Esso RON97. Link to post Share on other sites More sharing options...
Windchoco 1st Gear June 7, 2013 Share June 7, 2013 I also having this issue now. My CEL is on and i bring to KOMOCO to check. The mechanic told me is due to catalytic converter spoiled and need to be replace. The cost is about 3K - 4K.. I bring the car to check in workshop nearby my area, the mechanic said may be i pump petrol in JB that causing this. He just clear to code for me. But after 2 days the CEL on again. seek 2nd opinion. have a high mileage avante in the family and never heard of this issue. Link to post Share on other sites More sharing options...
Kenlee79 Neutral Newbie June 20, 2013 Share June 20, 2013 think my problem resolve without change the catalytic converter. hopefully the CEL light will not come back cause it already off for few days. a friend of mine share his experience with me where he face have this problem before and how the problem resolve.. try to finish your existing feul to the max until the petrol light is up.. pump in full RON98. after 2-3 round of full tank RON98, it may solve the problem and CEL light will off. My CEL light just off without reset after the 3rd round of RON98.. and now i start to pump back RON95. i dont know why, may be is the sensor dirty issue or RON98 do the cleaning?? haha.. ↡ Advertisement Link to post Share on other sites More sharing options...
2016 Hyundai Elantra / Avante
Iceland : Has anybody driven in Iceland before?
Kia Cerato Variant 2 persistent overheating issue
