Micarforum 1st Gear April 12, 2013 Share April 12, 2013 Hi guys, I am quite the impatient sort, and I have set up a routine to press the Start Engine button and immediately switch the gear to Drive (from Park), then pull seat belt and drive off, all within a few seconds. The problem is... Recently, i was doing this routine more and more quickly, until 1 time when I switched the Gear to Drive (from Park), the car/gearbox keeps vibrating, then I quickly switched back to Park and off the Engine, then I restart Engine and after a while then switch to Drive. Did I do any damage to my car's engine or gearbox? ↡ Advertisement Link to post Share on other sites More sharing options...
Hamburger Hypersonic April 12, 2013 Share April 12, 2013 no....car are not guniang so easily spoilt. Link to post Share on other sites More sharing options...
Ezfaun 3rd Gear April 12, 2013 Share April 12, 2013 Could be the AT valves in the valve assembly got stuck thus making the brake bands work against the epicyclic gears in a way that it's not supposed to and in turn caused vibrations? What car you driving btw? If dsg then stop doing liao. If normal car, I think the valve would be stuck because the AT fluid haven't circulate the valve assembly properly. Esp when cold. If CVT I dunno. But anyway you should be more cautious with your gearbox. My gear shifter linkage popped off once.. And it was raining... Link to post Share on other sites More sharing options...
Batlim 1st Gear April 12, 2013 Share April 12, 2013 When was the last time you changed your Transmission oil ?? Link to post Share on other sites More sharing options...
Micarforum 1st Gear April 13, 2013 Author Share April 13, 2013 volvo s60, turbo. Link to post Share on other sites More sharing options...
Wormvirus 1st Gear April 13, 2013 Share April 13, 2013 auto box inside mainly is oil, think dont matter if u tornado up the oil, thats why auto box better than manual Link to post Share on other sites More sharing options...
Rustyz 5th Gear April 13, 2013 Share April 13, 2013 Hi guys, I am quite the impatient sort, and I have set up a routine to press the Start Engine button and immediately switch the gear to Drive (from Park), then pull seat belt and drive off, all within a few seconds. The problem is... Recently, i was doing this routine more and more quickly, until 1 time when I switched the Gear to Drive (from Park), the car/gearbox keeps vibrating, then I quickly switched back to Park and off the Engine, then I restart Engine and after a while then switch to Drive. Did I do any damage to my car's engine or gearbox? Engine mounting U may like to have it check. Link to post Share on other sites More sharing options...
Micarforum 1st Gear April 13, 2013 Author Share April 13, 2013 what's engine mounting? Link to post Share on other sites More sharing options...
Hamburger Hypersonic April 13, 2013 Share April 13, 2013 The bridge between engine and the chassis. ... Link to post Share on other sites More sharing options...
Pisces69 6th Gear April 14, 2013 Share April 14, 2013 what's engine mounting? Yr "problem " is actually very easy to solve. Just b a bit more patient lah. I wil open door n start engine. Then put bag in back seat. Then sit in car n wear seatbelt. Put gear in D then on fan then slowly move off. After abt 4-5 mins of driving slowly..... i wil on ac. Like that car so far no problem n my car >7 yrs old. Btw i change my atf every 20-30k km to keep it fresh. Yr wowo autobox spoil wil b damm ex to repair. Take good care of it. Oh n never change fm D to R or P when car is still moving. Wait till car completely stop n wait 1 second b4 change. This preserves yr autobox. Link to post Share on other sites More sharing options...
Micarforum 1st Gear April 14, 2013 Author Share April 14, 2013 wah.... i see, now scared liao, will heed your advice. But for now, after this incident, do u think got any damage done? Link to post Share on other sites More sharing options...
Raymondism Twincharged April 14, 2013 Share April 14, 2013 wah.... i see, now scared liao, will heed your advice. But for now, after this incident, do u think got any damage done? better change to new car Link to post Share on other sites More sharing options...
Raymondism Twincharged April 14, 2013 Share April 14, 2013 Yr "problem " is actually very easy to solve. Just b a bit more patient lah. I wil open door n start engine. Then put bag in back seat. Then sit in car n wear seatbelt. Put gear in D then on fan then slowly move off. After abt 4-5 mins of driving slowly..... i wil on ac. Like that car so far no problem n my car >7 yrs old. Btw i change my atf every 20-30k km to keep it fresh. Yr wowo autobox spoil wil b damm ex to repair. Take good care of it. Oh n never change fm D to R or P when car is still moving. Wait till car completely stop n wait 1 second b4 change. This preserves yr autobox. it starts by slowing down the way a driver off engine n leave the car I will reverse into lot until the tyre touches the kerb then move a few inches in front then put into P then pull handbrake fold the side mirror off aircon off radio then step out morning open car door start engine open back seat door put bag or whateva close back sit in car on radio wind down window unfold mirror put gear into D drive to nearby hawker wo aircon Link to post Share on other sites More sharing options...
Pisces69 6th Gear April 14, 2013 Share April 14, 2013 wah.... i see, now scared liao, will heed your advice. But for now, after this incident, do u think got any damage done? Its hard to say if there was already some damage in yr autobox in e 1st place to cause e shuddering? I guess if u never changed yr atf b4......u sud consider doing it every 10k km till it comes out nice n red cherry colour. Then u can do it every 20-30k km on a regular basis to keep yr autobox happy. Link to post Share on other sites More sharing options...
Pisces69 6th Gear April 14, 2013 Share April 14, 2013 it starts by slowing down the way a driver off engine n leave the car I will reverse into lot until the tyre touches the kerb then move a few inches in front then put into P then pull handbrake fold the side mirror off aircon off radio then step out morning open car door start engine open back seat door put bag or whateva close back sit in car on radio wind down window unfold mirror put gear into D drive to nearby hawker wo aircon U forgot to add..... Once on eway....rev to redline n smoke every mutherfarker on e road. Hahaha. Link to post Share on other sites More sharing options...
Raymondism Twincharged April 14, 2013 Share April 14, 2013 U forgot to add..... Once on eway....rev to redline n smoke every mutherfarker on e road. Hahaha. Cannot la... Altis can only smell pple smoke... Link to post Share on other sites More sharing options...
Pisces69 6th Gear April 14, 2013 Share April 14, 2013 Cannot la... Altis can only smell pple smoke... I always say: Its e driver not e car bro. Its e driver. Link to post Share on other sites More sharing options...
Raymondism Twincharged April 14, 2013 Share April 14, 2013 I always say: Its e driver not e car bro. Its e driver. Can la.. if race in crowded geylang... wont lose la lol But its true i m not a slow driver.. neither do i crave for speed I just prefer to get away from slow coaches or hoggers... I notice some buggers love to crowd together in packs... Anyway like i say its a mirror of how one leave the car the night before... ↡ Advertisement Link to post Share on other sites More sharing options...
Cars We Don't Get to Drive in Singapore
Driving in Europe
Driving in Europe
Spam calls starting from 31290xxx
COVID-19: Retrenchments
Marriage registration fees in Singapore to increase
