Low pressure warning
Twincharged
In Jan this year, my low oil pressure indicator came on. I sent my car for servicing, everything was back to normal.
Today, 5000 plus km later, the low oil pressure indicator came on again. I am sure there is nothing wrong with the oil pressure. What could be the cause? The indicator flickers on and off sometimes, not frequently
Could it be the sensor of the oil press spoil? Common problem, my fren just replace his sensor total damage cost about 300+. He's using defi..
Twincharged
300 dollars????
To be 100% positive that you lub pump is in order get yr mech to do a oil pressure test - simple as ABC
Low pressure can cause serious damage to the engines moving and rotating components.
Edited by Yeobh
That's defi.. But if u are using others lower end brand of cause it will be cheaper..
As defi is one of the top notch gauges..
I think TS is talking about the OEM oil pressure sensor.
1st Gear
dun jump to conclusion first.this one could be big on $$ or only small simple solution.
Oil level normal
If oil level is ok sometimes yr oil too thin. Either u using too thin oil or it thins too much till cannot reach required oil pressure.
If u using a thin oil like 20-30weight oil....try using 40-50 weight n see how.
Also use good quality oil not some new or unknown brands. Some lousy oil thins very fast.
Guest
