Kangadrool Supersonic June 9, 2013 Share June 9, 2013 (edited) Looking at many of the obese cars around, you put 2 rolls royce trent 1000 engines also not powerful enough. A typical car weighs 1,200 kgs and can only carry a load of 500 kgs max. This is not even 50% of the vehicle's weight. Gross inefficiency! Edited June 9, 2013 by Kangadrool ↡ Advertisement Link to post Share on other sites More sharing options...
D3badge 6th Gear June 9, 2013 Share June 9, 2013 Depends on which part of the rev range the power and torque is made. Big torque at low rpm makes for the most relaxing drive on our roads. It's not really a big deal when you consider all the people out day riding 1000cc and above sportbikes on a daily basis, and those things outperform almost anything below the hyper exotics. The average modern 1000cc sportbike is putting out around 160 whp in a package that weighs around 200kg. That's around 800 whp/ton, excluding rider. If those people can do it on a daily basis, what's a 500whp car? yeah what u mention is abt Diavel sportbikes performance 119kW (165hp) / 205kg (dry Weight) a more sexier/powerful spec superbike for those unfamiliar with superbikes http://www.ducati.com/bikes/superbike/1199..._r/tech_spec.do ducati 1199 143kW (195hp)/ 165kg (dry weight) Link to post Share on other sites More sharing options...
D3badge 6th Gear June 9, 2013 Share June 9, 2013 This has to agree with u Control over power For me Sg road 150-300 bhp is enuff till enuff Cfm can ever outrun a no control driver with a 500 bhp car Haha then again, a stock car that can produce 500bhp normally are very easily control with all the technology in it compare with other "normal stock car" 1 Link to post Share on other sites More sharing options...
Renegade777 5th Gear June 9, 2013 Share June 9, 2013 (edited) Sorry cannot answer you on this. Enough for me is when I step the accelerator it goes smoothly effortlessly. Slam on the accelerator, it must "chiong" and not retard for a moment or a long moment. If not, if a 450hp car "jio" me on the lights, I feel I need 550hp and on and on. Anyway, normal cars it should range around 100hp to 200hp depending on its size. For sports car, minimum have to be 500hp and above. Edited June 9, 2013 by Renegade777 Link to post Share on other sites More sharing options...
1fast1 Supersonic June 9, 2013 Share June 9, 2013 Ps ps whats whp ?? whp = wheel horsepower. The "real world" power generated by the wheels against the ground. Generally much lower than the brake horsepower (see next), because of parasitic losses in the entire drivetrain. The losses are lowest for FWD - front wheel drive, higher for RWD and really quite significant (25% or more) for AWD. bhp = brake horsepower. The "actual" power generated at the engine crankshaft. Purely a function of the thermodynamic efficiency of the engine. This is what car manufacturers always quote, but you can almost never measure this yourself. The usual dynamometer studies only measure whp then extrapolate (through various inexact (and frankly, rubbish) conversions) the bhp. I don't know if you realised it but when you wrote "ps", that's also a power related term. ps is the unit of "metric horsepower" in that it's very close (but just slightly smaller) than (imperial) hp. kW = kilowatt is the actual metric unit for power, and it's a much larger unit than hp or ps. Link to post Share on other sites More sharing options...
1fast1 Supersonic June 9, 2013 Share June 9, 2013 So even though the power is "wasted" also doesnt matter? Of course it matters, which is what my post was all about. If a car has enough usable torque for street situations, then the more power the better. In this case, there's no downside. Link to post Share on other sites More sharing options...
Throttle2 Supersonic June 9, 2013 Share June 9, 2013 (edited) Avg income more than 10k per mth, at least 250hp than enough. More than 100k per mth, at least 500hp than enough. Abg joe, less than 2k wll say 100hp will do. Nvr ending la. hw to compare? No wonder Porker's / turboflat's / hubwee's car so powerful. Thanks for enlightening Edited June 9, 2013 by Throttle2 Link to post Share on other sites More sharing options...
Myxilplix Turbocharged June 9, 2013 Share June 9, 2013 (edited) yeah what u mention is abt Diavel sportbikes performance 119kW (165hp) / 205kg (dry Weight) a more sexier/powerful spec superbike for those unfamiliar with superbikes http://www.ducati.com/bikes/superbike/1199..._r/tech_spec.do ducati 1199 143kW (195hp)/ 165kg (dry weight) Yes, but i was quoting wet weight which averages around 200kg for the superbikes. Wet weight of the diavel is closer to 240kg. Dry weight is nonsense figures because manufacturers have all kinds of funny tricks to bring this figure down (no engine oil/coolant/brake fluid/clutch fluid/fork oil/etc, no/empty battery). Also the power figures kW/hp are at the crank, i was talking whp. Wet weight/kerb weight = indicate total bike weight with all operating consumable liquids and a fuel tank filled to 90% of capacity (as per EC standard 93/93). ps. The diavel is a cruiser. For a cruiser it handles pretty damn good and is pretty damn quick, but it's no sportbike. Edited June 9, 2013 by Myxilplix Link to post Share on other sites More sharing options...
Macrosszero Turbocharged June 9, 2013 Share June 9, 2013 Its more accurate to talk power to weight ratio. To me, any car that can do 5 to 7 seconds 0-100 will be the limit of streetability, both for cost of running, wear and tear, and reliability. At this power bracket, four driven wheels is preferred, or at least RWD. Cars that suit this criteria of mine generally have about 150-200hp per tonne, and at least 2.5 litres capacity. Link to post Share on other sites More sharing options...
Poper 2nd Gear June 9, 2013 Share June 9, 2013 Any amount of horse power in the wrong hands can kill... So, picanto and QQ are both dangerous to me. Link to post Share on other sites More sharing options...
Kiadaw 6th Gear June 9, 2013 Share June 9, 2013 Any amount of horse power in the wrong hands can kill... So, picanto and QQ are both dangerous to me. But more powerful car encourage people to break the speed limit & law more, & drive harder, & faster. This is especially true when one are younger, when you are green, & you have the delusion that if you drive faster, you are a better driver. Personal experience. When you get older, you will (hopefully) be more responsible, even behind a huge vehicles like trucks, or fast car. Link to post Share on other sites More sharing options...
inlinesix Supersonic June 9, 2013 Share June 9, 2013 I m driving mid engine rear wheel drive with 140hp. Weight of the car is less than 1k kg. It is fun to drive in SG. Link to post Share on other sites More sharing options...
Yuan 6th Gear June 9, 2013 Share June 9, 2013 For turbo cars if ur running wif big turbos wif massive turbo lag vs a stock turbo i rather choose the stock one for its responsiveness. Given ur car got 800whp but only starts to spool at 5k rpm oso no use. Those small turbos will be at the next light waiting for u already. Lol I agree on this one. Link to post Share on other sites More sharing options...
Yuan 6th Gear June 9, 2013 Share June 9, 2013 In my opinion, I see no purpose in this poll...power without control is nothing....as long the driver can control it with absolute confidence and have a sense of social responsibility by not creating a hazard situation on the road.....one can even drive a bat mobile....is about the driver... not the car... I concur with you on this. Link to post Share on other sites More sharing options...
BlueOldMan 1st Gear June 9, 2013 Share June 9, 2013 Oh I see I only know paper Hp, And on wheel Hp Oh whp is the term Tks ya bro, Learn a new thing tdy Link to post Share on other sites More sharing options...
Kiadaw 6th Gear June 9, 2013 Share June 9, 2013 I m driving mid engine rear wheel drive with 140hp. Weight of the car is less than 1k kg. It is fun to drive in SG. What car is that. Copen? Link to post Share on other sites More sharing options...
BlueOldMan 1st Gear June 9, 2013 Share June 9, 2013 Oh I meant paisay Hahaha Link to post Share on other sites More sharing options...
Kiadaw 6th Gear June 9, 2013 Share June 9, 2013 Anyway, here's a good video posted todays at Autoblog ↡ Advertisement Link to post Share on other sites More sharing options...
Makan in Thailand
Makan in Thailand
Eating too much protein?
Home power back up
Home power back up
Honda Stream 2009 No Power and High fuel Consumption
Alcades power optimizer
