Darthrevan Supercharged July 4, 2013 Share July 4, 2013 currently every 3 months..tires on nitrogen..pressures did not drop much ↡ Advertisement Link to post Share on other sites More sharing options...
Octopus 3rd Gear July 4, 2013 Share July 4, 2013 Ok. Just remembered, I only pump once a month for the other car which I don't drive often. Is it recommended to pump as regularly as I do? Tyre will overstretch boh? I don't think tyre will have any problem. I'm more worried the air-valve (moving part) would wear out quicker and small leak occur. Hopefully the valve caps can minimise such leaks..... Link to post Share on other sites More sharing options...
Loki Supersonic July 4, 2013 Share July 4, 2013 currently every 3 months..tires on nitrogen..pressures did not drop much Me too. Once a quarter cuz on nitrogen. Went back once after 2 months, pressure did not drop at all. So now I stretch it to 3 months. Link to post Share on other sites More sharing options...
Celicar Turbocharged July 4, 2013 Share July 4, 2013 If I see the air pump free, I usually try to pump every month. Every time pump will sort of reset the monthly practice. Link to post Share on other sites More sharing options...
Nzy Twincharged July 4, 2013 Share July 4, 2013 Tried to pump once every 2 months but noticed that the pressure never drop at all so now trying once every 3 months. If I change to nitrogen I guess can pump once every 6 months? Link to post Share on other sites More sharing options...
Cheesepiekia 5th Gear July 4, 2013 Share July 4, 2013 I pump air everytime after i pump petrol so about 10 days. Link to post Share on other sites More sharing options...
Kansatish 1st Gear July 4, 2013 Share July 4, 2013 Every alternate petrol filling...so that makes it roughly 2 weeks... Link to post Share on other sites More sharing options...
SPT27AAA Neutral Newbie July 4, 2013 Share July 4, 2013 Lesser frequency compared to pumping holes Back track, eg pumped 230, next trip u pluck in air hose notice initial reading Eg first tyre shows 190 then gng up to 230 If out of the 4, all show 190 but got one reading is 115 eg This tyre cfm got leak Liao Link to post Share on other sites More sharing options...
Cluboxed 1st Gear July 4, 2013 Share July 4, 2013 am with TPMS, so it depends.. Link to post Share on other sites More sharing options...
Kweechang 1st Gear July 4, 2013 Share July 4, 2013 Never pump at all. Service my car every 6 months. presume they will check air pressure for me. Initially, I check my air pressure every month, then increase to 2 months, 3 months, later never check. Note: I still do visual check regularly. My experience on my previous car also the same. With good tyres and rims, do not to need pump at all. I use normal air. Link to post Share on other sites More sharing options...
Atlantis80 1st Gear July 7, 2013 Share July 7, 2013 I pump once every 2 months. Hate the "dirty fingers" psychological feeling after wiping them with wet tissue. Link to post Share on other sites More sharing options...
Timex1441 1st Gear July 8, 2013 Share July 8, 2013 Never pump at all. Service my car every 6 months. presume they will check air pressure for me. Initially, I check my air pressure every month, then increase to 2 months, 3 months, later never check. Note: I still do visual check regularly. My experience on my previous car also the same. With good tyres and rims, do not to need pump at all. I use normal air. visual check is not reliable....i got a fren who didnt check at all n did wat u did, i.e. rely on the servicing ppl to pump....guess wat, one fine day, 1 of the tyres juz went flat....no nail or anything tat pierce the tyre....it juz went flat becos the air pressure wasnt enough to support the total weight.... i think minimum is to pump air every 3 months (assuming normal air, not nitrogen)....anything longer than 3 months, u r pushing ur luck Link to post Share on other sites More sharing options...
Speak_listen Neutral Newbie July 8, 2013 Share July 8, 2013 everytime want go to m'sia btw can share which petrol station have good facility to pump air? some of them is out of order. some of them is faulty like, never beep/ ring after few second pump air. Link to post Share on other sites More sharing options...
Vid Hypersonic July 8, 2013 Share July 8, 2013 Anyone using run flat tyres? How often to pump those then? Link to post Share on other sites More sharing options...
Subutai 3rd Gear July 8, 2013 Share July 8, 2013 I try to pump every other 2 tanks refill at kiosks... maybe i kiasu... Link to post Share on other sites More sharing options...
Thedream 3rd Gear July 8, 2013 Share July 8, 2013 I think this really depends on the car, the tyres, and whether you pump nitrogen, so the frequency can really vary... To avoid wasting time, I guess the best option would be to install a TPMS. But some (myself included), don't like additional electronics if they can be avoided. So I guess it would be good to know how fast your tyres typically lose air. Mine loses less than 5% over 5 weeks, and that's the interval I choose to top up air. I got my own foot pump (from michelin) so I can pump my tyres at my own time and don't have to worry about queueing at the petrol station... Link to post Share on other sites More sharing options...
Robo 2nd Gear July 8, 2013 Share July 8, 2013 metal valve and on nitrogen. pump once a month now. drops from 240 to 230. at times if no fetch ppl den no drop at all Link to post Share on other sites More sharing options...
Lala81 Hypersonic July 8, 2013 Share July 8, 2013 actually tyre pressure low can feel one mah. I know when mine are below 200. I try to pump every 1.5mths. lol driver side usually lose faster ↡ Advertisement Link to post Share on other sites More sharing options...
Purchase and submit a Dunlop SP Sport Maxx 060+ tyres review now!
