Stratovarius Turbocharged September 4, 2013 Share September 4, 2013 Hello. Recently my ride is making some weird noises. Mostly in the morning during start-up. 1 - I need to clutch in during cranking, when release the pedal, I can feel a knocking sound. Other times during driving, no such issue. 2 - After cranking, when driving off, can hear a high pitch screeching sound. Think is from the wheels. The sound can only be heard for a short distance like moving out from a lot, after that, no such sound. Any bros encounter such things before? ↡ Advertisement Link to post Share on other sites More sharing options...
Ckchong8 1st Gear September 4, 2013 Share September 4, 2013 Hello. Recently my ride is making some weird noises. Mostly in the morning during start-up. 1 - I need to clutch in during cranking, when release the pedal, I can feel a knocking sound. Other times during driving, no such issue. 2 - After cranking, when driving off, can hear a high pitch screeching sound. Think is from the wheels. The sound can only be heard for a short distance like moving out from a lot, after that, no such sound. Any bros encounter such things before? Possible from your pulley belt. If used some time alr get it change. Link to post Share on other sites More sharing options...
BlueOldMan 1st Gear September 4, 2013 Share September 4, 2013 Possible from your pulley belt. If used some time alr get it change. If it's those fan belts etc jus go tighten it lor Link to post Share on other sites More sharing options...
RadX Moderator September 4, 2013 Share September 4, 2013 If it's those fan belts etc jus go tighten it lor for u, chk passenger seat, may be the wife <_< Link to post Share on other sites More sharing options...
TVT Supercharged September 4, 2013 Share September 4, 2013 2 - After cranking, when driving off, can hear a high pitch screeching sound. Think is from the wheels. The sound can only be heard for a short distance like moving out from a lot, after that, no such sound. I kena this sound before. It sound comes when moving off, and also when stopping. The culprit is the rear brake pump (aka brake cylinder). Link to post Share on other sites More sharing options...
Stratovarius Turbocharged September 4, 2013 Author Share September 4, 2013 Possible from your pulley belt. If used some time alr get it change. Pulley Belt? You mean for the screeching sound? The sound is only generated when the car is moving. If it is the pulley, then it should be heard once I cranked the engine. Link to post Share on other sites More sharing options...
BlueOldMan 1st Gear September 4, 2013 Share September 4, 2013 for u, chk passenger seat, may be the wife <_< More likely the mistress la deh Link to post Share on other sites More sharing options...
BlueOldMan 1st Gear September 4, 2013 Share September 4, 2013 I kena this sound before. It sound comes when moving off, and also when stopping. The culprit is the rear brake pump (aka brake cylinder). You kana one is milf la Link to post Share on other sites More sharing options...
BlueOldMan 1st Gear September 4, 2013 Share September 4, 2013 Pulley Belt? You mean for the screeching sound? The sound is only generated when the car is moving. If it is the pulley, then it should be heard once I cranked the engine. But while you heard the sound, you got check is the mat area wet ?? As in engine oil or whatever liquid?? Link to post Share on other sites More sharing options...
Stratovarius Turbocharged September 4, 2013 Author Share September 4, 2013 I kena this sound before. It sound comes when moving off, and also when stopping. The culprit is the rear brake pump (aka brake cylinder). During braking, there is a screeching noise too. I thought is something wrong with the pads. For me, the sound is only audible when I move off from the carpark lot after a cold start, during normal driving, I cannot hear the noise. So is it still the brake cylinder? Link to post Share on other sites More sharing options...
Stratovarius Turbocharged September 4, 2013 Author Share September 4, 2013 But while you heard the sound, you got check is the mat area wet ?? As in engine oil or whatever liquid?? No ppl, no fluid.... But it is the 7th month.... maybe I monitor till the month is over and see got any changes anot. Link to post Share on other sites More sharing options...
BlueOldMan 1st Gear September 4, 2013 Share September 4, 2013 During braking, there is a screeching noise too. I thought is something wrong with the pads. For me, the sound is only audible when I move off from the carpark lot after a cold start, during normal driving, I cannot hear the noise. So is it still the brake cylinder? Braking is PAD got issue, screeching is BRA got problem Oops sorry should be Belt got issue Link to post Share on other sites More sharing options...
BlueOldMan 1st Gear September 4, 2013 Share September 4, 2013 No ppl, no fluid.... But it is the 7th month.... maybe I monitor till the month is over and see got any changes anot. Of cse no pple there wun be fluid la But sometimes got pple oso may not have fluid Link to post Share on other sites More sharing options...
TVT Supercharged September 4, 2013 Share September 4, 2013 During braking, there is a screeching noise too. I thought is something wrong with the pads. For me, the sound is only audible when I move off from the carpark lot after a cold start, during normal driving, I cannot hear the noise. So is it still the brake cylinder? Yup, during move off / braking / stopping - all have screeching noise. It can be quite loud sometimes, even if I am inside the cabin with windows all up! Yup. During driving and car is moving, no noise at all. Faulty brake cylinder was the culprit in my case. But for you, could be also brake cylinder or pads or others. Only an experienced WS mech can determine what is wrong with it. Link to post Share on other sites More sharing options...
TVT Supercharged September 4, 2013 Share September 4, 2013 You kana one is milf la Laggi best, MILF is my type!!! Link to post Share on other sites More sharing options...
Yhn 4th Gear September 4, 2013 Share September 4, 2013 During braking, there is a screeching noise too. I thought is something wrong with the pads. For me, the sound is only audible when I move off from the carpark lot after a cold start, during normal driving, I cannot hear the noise. So is it still the brake cylinder? Two issues come at same time la Brake and Belt For belt, if not loose, you can solve it with a bar of soap Link to post Share on other sites More sharing options...
BlueOldMan 1st Gear September 4, 2013 Share September 4, 2013 Laggi best, MILF is my type!!! Pple talking belt fault leh Link to post Share on other sites More sharing options...
TVT Supercharged September 4, 2013 Share September 4, 2013 Pple talking belt fault leh Yes, correct! The bra strap is something like the belt too.... ↡ Advertisement Link to post Share on other sites More sharing options...
More MRT Lines Announced
Whole car sound proof
Sound Proofing the car
Right side speakers no sound
Metal grinding sound on civic
More NS defaulters in 2011 than in 2010
