Apple-Tree 6th Gear August 26, 2016 Share August 26, 2016 Cost is rising !!! Try to DIY as much as possible. No harm learning a bit of Car diagmostics, OBD is easy these days with a smartphone. Just a try, it really save money. Change brake pads starting from $25 !!! ↡ Advertisement Link to post Share on other sites More sharing options...
Fuelsaver Supercharged August 27, 2016 Share August 27, 2016 Cost is rising !!! Try to DIY as much as possible. No harm learning a bit of Car diagmostics, OBD is easy these days with a smartphone. Just a try, it really save money. Change brake pads starting from $25 !!! bro u conduct adhoc workshop i come support by buying minum.. if take too long i baojia oso.. Link to post Share on other sites More sharing options...
Mcf777 Turbocharged August 27, 2016 Share August 27, 2016 (edited) st.Bro, if alternator spoilt will it affect the car radio system? When my alternator show sign of dying, I drove home with Aircon n radio off. Next day, tow to ws. Changed new alternator. After collected the car,i noticed my LCD player (LCD Screen) cannot press any button. WS act blur , say not their problem. and LL I changed the LCD panel for about s$700 Edited August 27, 2016 by Mcf777 Link to post Share on other sites More sharing options...
Kb27 Supersonic August 27, 2016 Share August 27, 2016 Bro, if alternator spoilt will it affect the car radio system? When my alternator show sign of dying, I drove home with Aircon n radio off. Next day, tow to ws. Changed new alternator. After collected the car,i noticed my LCD player (LCD Screen) cannot press any button. WS act blur , say not their problem. and LL I changed the LCD panel for about s$700 Depends on what the alternator is doing. Normally, the voltage regulator inside the alternator controls and regulate the output voltage to a nominal 14Vdc, regardless whether you are revving the engine or at idle. If that regulator fails, the alternator might put out excessive voltage well above 18Vdc. This is extremely dangerous, as it might caused damage to battery due to overcharging and overheating. Headlights will be extra bright and burn out in a short time. It might fry ECU, ICE and other electronic devices designed to work around 14Vdc. However, if the alternator simply dies and stop putting out any voltage, then the only risk is a flat battery. It is unlikely to damage anything else. As for your LCD, it's hard to say. If it's a busy w/s, I don't think the mechs have the time to play with your LCD. It really depends on how the w/s boss and management treats customer cars and/or enforced discipline. If it's lax, then the mechs can do whatever they want. If the boss is strict, then the mechs are unlikely to treat customer cars as their plaything. Once a car is left with the w/s, it is their responsiblity, to a certain extent. 1 Link to post Share on other sites More sharing options...
Kippei 3rd Gear August 27, 2016 Share August 27, 2016 Alternator is a very hardy item. Usually how it failed is the carbon brush ran out or the rectifier board fail. All the item can be replaced at a function of a alternator replacement. Cost me $60 to change bearing and carbon brushes. Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear August 27, 2016 Share August 27, 2016 R U sure they have carbon brushes ?? Alternator is a very hardy item.Usually how it failed is the carbon brush ran out or the rectifier board fail. All the item can be replaced at a function of a alternator replacement.Cost me $60 to change bearing and carbon brushes. Link to post Share on other sites More sharing options...
Kippei 3rd Gear August 28, 2016 Share August 28, 2016 R U sure they have carbon brushes ??You just google and will know the answer Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear August 28, 2016 Share August 28, 2016 Ooops ............. You just google and will know the answer Link to post Share on other sites More sharing options...
Jumpmanz 5th Gear August 30, 2016 Share August 30, 2016 Alternator is a very hardy item. Usually how it failed is the carbon brush ran out or the rectifier board fail. All the item can be replaced at a function of a alternator replacement. Cost me $60 to change bearing and carbon brushes. yup, did mine the same way at a specialize alternator workshop in bukit batok. workshops normally ask cars to change the whole alternator Link to post Share on other sites More sharing options...
Alphas 2nd Gear September 8, 2016 Share September 8, 2016 yup, did mine the same way at a specialize alternator workshop in bukit batok. workshops normally ask cars to change the whole alternator What shop and address, I think this important. Once alternator fail, the car has to be towed. Link to post Share on other sites More sharing options...
Ix0107 2nd Gear September 8, 2016 Share September 8, 2016 What shop and address, I think this important. Once alternator fail, the car has to be towed. You might also wanna to consider this shop located at Bukit Merah..... They quite good dealing with alternator. Lion City Electric Pte Ltd Address: 1001 Bukit Merah Lane 3, Singapore 159718 Phone: +65 6270 2713 Link to post Share on other sites More sharing options...
weilun9241 Clutched September 8, 2016 Share September 8, 2016 You might also wanna to consider this shop located at Bukit Merah..... They quite good dealing with alternator. Lion City Electric Pte Ltd Address: 1001 Bukit Merah Lane 3, Singapore 159718 Phone: +65 6270 2713 Thumbs up for lion city! they fixed my alternator for me too at reasonable price... unlike Caprice which is located at 1008 Bukit Merah Lane 3, Singapore 159722 who told me its my starter and battery which is causing the battery light to appear on dash. Link to post Share on other sites More sharing options...
Tcx607 4th Gear September 8, 2016 Author Share September 8, 2016 (edited) Motor starter and alternator is 2 different part. Starter crank your engine to start while alternator generate electricity for the car after engine power up and supply electricity to all the equipment such as radio, amplifier, lighting, electronic parts etc If alternator fails, you still can drive your car but don't turn on aircon or radio system cos all electricity taken from battery. Very soon battery also goes flat. Motor starter has carbon brush and can be replaced. Never experience alternator replace carbon brush???? Edited September 8, 2016 by Tcx607 Link to post Share on other sites More sharing options...
Simpleonly 5th Gear September 8, 2016 Share September 8, 2016 yup, did mine the same way at a specialize alternator workshop in bukit batok. workshops normally ask cars to change the whole alternator Bro which shop is that in that page?Able to share? Thanks in advance! Link to post Share on other sites More sharing options...
Kb27 Supersonic September 8, 2016 Share September 8, 2016 Motor starter and alternator is 2 different part. Starter crank your engine to start while alternator generate electricity for the car after engine power up and supply electricity to all the equipment such as radio, amplifier, lighting, electronic parts etc If alternator fails, you still can drive your car but don't turn on aircon or radio system cos all electricity taken from battery. Very soon battery also goes flat. Motor starter has carbon brush and can be replaced. Never experience alternator replace carbon brush???? I studied DC machines over 20 yrs ago. I vaguely remembers they use carbon brushes. Only AC machines don't use carbon brush. So in a car, the starter motor and alternator are DC (12V) machines and they both use carbon brushes. Check out here how to replace alternator carbon brush. http://www.howacarworks.com/electrical-systems/renewing-alternator-brushes Having said that, new technology now has DC machines which are totally brushless, such as DC cordless and brushless impact driver and drills. Link to post Share on other sites More sharing options...
Gnahp Supercharged September 9, 2016 Share September 9, 2016 I studied DC machines over 20 yrs ago. I vaguely remembers they use carbon brushes. Only AC machines don't use carbon brush. So in a car, the starter motor and alternator are DC (12V) machines and they both use carbon brushes. Check out here how to replace alternator carbon brush. http://www.howacarworks.com/electrical-systems/renewing-alternator-brushes Having said that, new technology now has DC machines which are totally brushless, such as DC cordless and brushless impact driver and drills. car alternators are AC there is a rectifier in the alternator converting it to DC Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear September 10, 2016 Share September 10, 2016 There is a Youtube from Christ Fix on How to test Alternator. You can go to Toyogo to get a cheap multimeter. 2 Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear September 27, 2016 Share September 27, 2016 (edited) Was just talking about it here and my friend reported that his Renault Van kenna. Here is the ODO reading when failed. Cost him $120 - Change brush. Total Damage is actually $300 lor ..... the knife is sure sharp .... Edited September 27, 2016 by Apple-Tree ↡ Advertisement Link to post Share on other sites More sharing options...
What did I do wrong when parking?
Child seat major FAIL
Najib Fail
Najib Fail
Singapore to Fail without PAP?
'Drive' brand car battery in my car total sudden failure.
Security Guard takes down "MMA fighter" in condo (Malaysia)
Power Steering sensor fail light
