Forte3737 5th Gear October 3, 2013 Share October 3, 2013 STA grade B = C0ndition not that good. looks like you have to get your facts right. ↡ Advertisement Link to post Share on other sites More sharing options...
Surfer Neutral Newbie July 23, 2014 Share July 23, 2014 Hi All, I have just placed a deposit for a 2nd hand car and the dealer had sent the car to Vicom for inspection. there are 2 items with red words which require attention, there are; 1.Transmission box: gearbox housing oil seepage 2. Steering: swerving to one side Although the dealer had promise to rectify all but i am still concern about item 1. Appreciate advice from the bro here. Thanks, Link to post Share on other sites More sharing options...
TVT Supercharged July 23, 2014 Share July 23, 2014 Hi All, I have just placed a deposit for a 2nd hand car and the dealer had sent the car to Vicom for inspection. there are 2 items with red words which require attention, there are; 1.Transmission box: gearbox housing oil seepage 2. Steering: swerving to one side Although the dealer had promise to rectify all but i am still concern about item 1. Appreciate advice from the bro here. Thanks, Is it a manual or auto car ? Anyway point 2 is not so serious as point 1 but still need to rectify properly for safety sake. Link to post Share on other sites More sharing options...
Surfer Neutral Newbie July 23, 2014 Share July 23, 2014 Hi TVT, Thanks for your reply. It is a 6 yr old auto car. Does it cost alot to rectify it and I thinking of calling Vicom tomorrow to check on the seriousness of it. Thanks, Link to post Share on other sites More sharing options...
Furrynadz 5th Gear July 23, 2014 Share July 23, 2014 (edited) Hi All, I have just placed a deposit for a 2nd hand car and the dealer had sent the car to Vicom for inspection. there are 2 items with red words which require attention, there are; 1.Transmission box: gearbox housing oil seepage 2. Steering: swerving to one side Although the dealer had promise to rectify all but i am still concern about item 1. Appreciate advice from the bro here. Thanks, small issue change gasket, u going to do the atf / filter / gasket once u get anyway alignment out, change tie rod/tie rod end , do alignment, might as well factor in 1k or so and do full suspension change with lower arm ball joint and barlinks as well these are small issue, as long as u dont see stuff like failed turbo inside (i hope u not buying a french car btw) Edited July 23, 2014 by Furrynadz Link to post Share on other sites More sharing options...
Pisces69 6th Gear July 23, 2014 Share July 23, 2014 Is it a manual or auto car ? Anyway point 2 is not so serious as point 1 but still need to rectify properly for safety sake. Point 2 cud also mean car had a bad accident n chassis is bent n sud b avoided. If Point 1 is just need a gasket change than OK. If the sump is cracked/warped, then better avoid the car. Both points cud b serious n not serious. Link to post Share on other sites More sharing options...
TVT Supercharged July 24, 2014 Share July 24, 2014 Hi TVT, Thanks for your reply. It is a 6 yr old auto car. Does it cost alot to rectify it and I thinking of calling Vicom tomorrow to check on the seriousness of it. Thanks, Yup, good idea. Call Vicom n ask, and if possible bring the report to a mechanic (you trust) and ask for a 2nd opinion. Link to post Share on other sites More sharing options...
lizhimmm Neutral Newbie September 30, 2014 Share September 30, 2014 For my STA report, it says Transmission Housing sign of oil stain. is it a great concern? what should i do about it. Also for the STA report shown to me by the dealer, all the itemized details only shows Pass/Fail/NA. I see some previous STA report samples have A/B/C/D grading for each item. Is Pass/Fail/NA the new format or there are some sections of the report that the dealer has not passed to me yet ? 1 Link to post Share on other sites More sharing options...
Ashc Neutral Newbie October 11, 2017 Share October 11, 2017 Hi All, I am a newbie here and intend to purchase a used car which was sent for STA evaluation. The overall grading was B, made with following remarks: 1. VEHICLE TRANSMISSION HOUSING SIGN OF STAINS 2. VEHICLE DRIVESHAFT GREASE SIGN OF STAINS 3. VEHICLE REAR BRAKE DISCS SIGN OF WORN 4. VEHICLE FRONT PANEL SIGN OF TOUCH UP 5. VEHICLE FRONT WINDSCREEN 70% 6. VEHICLE FRONT WINDOW 73% 7. VEHICLE REAR WINDSCREEN 49% 8. VEHICLE REAR WINDOW 57% Should I be worried about the above comments? Any help would be greatly appreciated. 1 Link to post Share on other sites More sharing options...
currypuff 5th Gear October 11, 2017 Share October 11, 2017 (edited) Hi All, I am a newbie here and intend to purchase a used car which was sent for STA evaluation. The overall grading was B, made with following remarks: 1. VEHICLE TRANSMISSION HOUSING SIGN OF STAINS 2. VEHICLE DRIVESHAFT GREASE SIGN OF STAINS 3. VEHICLE REAR BRAKE DISCS SIGN OF WORN 4. VEHICLE FRONT PANEL SIGN OF TOUCH UP 5. VEHICLE FRONT WINDSCREEN 70% 6. VEHICLE FRONT WINDOW 73% 7. VEHICLE REAR WINDSCREEN 49% 8. VEHICLE REAR WINDOW 57% Should I be worried about the above comments? Any help would be greatly appreciated. My advice : dont buy Edited October 11, 2017 by currypuff 2 Link to post Share on other sites More sharing options...
Terrylmt Supercharged October 13, 2017 Share October 13, 2017 Hi All, I am a newbie here and intend to purchase a used car which was sent for STA evaluation. The overall grading was B, made with following remarks: 1. VEHICLE TRANSMISSION HOUSING SIGN OF STAINS 2. VEHICLE DRIVESHAFT GREASE SIGN OF STAINS 3. VEHICLE REAR BRAKE DISCS SIGN OF WORN 4. VEHICLE FRONT PANEL SIGN OF TOUCH UP 5. VEHICLE FRONT WINDSCREEN 70% 6. VEHICLE FRONT WINDOW 73% 7. VEHICLE REAR WINDSCREEN 49% 8. VEHICLE REAR WINDOW 57% Should I be worried about the above comments? Any help would be greatly appreciated. I would be concerned. However, seeing as how the grading is B - which is the magic threshold that all car dealers will hold you ransom to, you should try to negotiate for them to help remedy/rectify some of these issues. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
All about smoking
All about smoking
Help with STA report remarks
Questions about Gearbox overhaul
Mother of all Avian Influenza * (H*N*)
All about springs and shocks(dampers)
SCHNELL Engine Oil 5W40
P2096 Check engine light
