Simonsoh 2nd Gear November 5, 2013 Share November 5, 2013 early early morning had a scare... fuel needle rapidly going down and i thought tank leak. reach petrol kiosk and top up full until see petrol floating in tank, on engine still show almost zero.... bad start to morning.... any bros experience this before? is repair very urgent as can barely afford any downtime this week.... wat could be the cause and damage? driving a 4yr old forte.... thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Lowrider 2nd Gear November 5, 2013 Share November 5, 2013 Seems like your fuel sender unit is faulty. Repair is not urgent as long as you know you won't run out of gasoline :) Link to post Share on other sites More sharing options...
Jman888 Moderator November 5, 2013 Share November 5, 2013 see if it resume after a while or this afternoon, if not then you may have to send it to the service centre. Meanwhile just monitor and refuel every 350km to be safe Link to post Share on other sites More sharing options...
Vhtfhwlego Supercharged November 5, 2013 Share November 5, 2013 Dont know whether it is possible but you can try:- Drive until almost empty (by the average mileage you clocked & you will know right) and top up again. If that the tank sensor is struck, it may lift itself back up and all will be normal again. Even you try to repair now with a full tank, which WS wanna accept the risk of transfering 50litres of gas around? Link to post Share on other sites More sharing options...
Simonsoh 2nd Gear November 5, 2013 Author Share November 5, 2013 at jurong eat, it was left one bar, which i already found v strange. then upon reaching BB shell, it reached almost empty n never lifted again... Link to post Share on other sites More sharing options...
Carmour 4th Gear November 5, 2013 Share November 5, 2013 (edited) No biggie. Repairs are not urgent unless you are the kind of driver that needs to compulsively check your fuel gauge. Going by the below, you can go 738km on a full tank. But I'll keep to 500km to be safe. Specifications Kia Cerato Forte 1.6 EX (A) Engine Engine capacity 1,591 cc Engine type 4-cylinders in-line Compression ratio 10.5 Bore x Stroke (77.0 x 85.4) mm Performance Power 128 bhp Torque 156 Nm Acceleration 12s (0-100 km/h) Top speed 182 km/h Fuel consumption 14.2 km/L CO2 emission unknown Misc technical data Transmission 4-speed (A) Drive type FWD Measurements Vehicle type Sedan Dimensions (L x W x H) (4530 x 1775 x 1460) mm Wheelbase 2,650 mm Min turning radius unknown Kerb weight 1,326 kg Fuel tank capacity 52 L Brakes Brakes (Front) Ventilated disc Brakes (Rear) Disc Suspension Suspension (Front) MacPherson struts Suspension (Rear) Coupled torsion beam axle Specifications may vary from actual vehicle. Edited November 5, 2013 by Carmour Link to post Share on other sites More sharing options...
Mkl22 Twincharged November 5, 2013 Share November 5, 2013 just use mileage to gauge how far you need to travel to make the tank 1/4 full then bring it for repairs. going to repair with a full or sometimes half tank can result in lots of fuel spillage and your car interior will reek of petrol for some days. Link to post Share on other sites More sharing options...
Rustyz 5th Gear November 5, 2013 Share November 5, 2013 You just can't go malaysia that all. You could use mileage to gauge when to refill If it is me I will repair, ur ride only 4 yr old and do away the guessing game. Link to post Share on other sites More sharing options...
Simonsoh 2nd Gear November 5, 2013 Author Share November 5, 2013 (edited) ok. workshop confirmed "float faulty". He tested by bypassng the float and the needle showed full tank. float not sold seperately and comes in a set (part of a bigger component) and damage is $300+... wow... so never repair leh.. source for better quote... meanwhile will pump every 400km... after driving off, needle goes down to half and now stuck there all the way... instead of stuck at empty. long term wise any problem? cuz the fuel info connected to other info rite? eg, consumption rate etc... my noob understanding is nowadays cars all run on computer chips.. juz scared will screw up some electronic stuffs... Edited November 5, 2013 by Simonsoh Link to post Share on other sites More sharing options...
Vulcann 6th Gear November 5, 2013 Share November 5, 2013 ok. workshop confirmed "float faulty". He tested by bypassng the float and the needle showed full tank. float not sold seperately and comes in a set (part of a bigger component) and damage is $300+... wow... so never repair leh.. source for better quote... meanwhile will pump every 400km... after driving off, needle goes down to half and now stuck there all the way... instead of stuck at empty. long term wise any problem? cuz the fuel info connected to other info rite? eg, consumption rate etc... my noob understanding is nowadays cars all run on computer chips.. juz scared will screw up some electronic stuffs... Unless you don't travel across the border up north should be ok. Else you better be prepared to explain to the fellas should they suay suay spot check your fuel gauge... Link to post Share on other sites More sharing options...
Jman888 Moderator November 5, 2013 Share November 5, 2013 ok. workshop confirmed "float faulty". He tested by bypassng the float and the needle showed full tank. float not sold seperately and comes in a set (part of a bigger component) and damage is $300+... wow... so never repair leh.. source for better quote... meanwhile will pump every 400km... after driving off, needle goes down to half and now stuck there all the way... instead of stuck at empty. long term wise any problem? cuz the fuel info connected to other info rite? eg, consumption rate etc... my noob understanding is nowadays cars all run on computer chips.. juz scared will screw up some electronic stuffs... could be sensor problem and some time they siao siao one, give it a few day see if it 'recover' Link to post Share on other sites More sharing options...
Simonsoh 2nd Gear November 5, 2013 Author Share November 5, 2013 (edited) could be sensor problem and some time they siao siao one, give it a few day see if it 'recover' ya.. i wait and see... asking around for better quotes also.. anyway got petrol kiosk near home and workplace. just discipline to pump every 400km. but the mechanic very confident. he bypass and needle go full tank. connect back it dip to zero again... repeat a few times and he say 100% "float" spoil... listen to your good word lah... hope can recover by itself, really cant bear to part with $300+ for fuel needle... Edited November 5, 2013 by Simonsoh Link to post Share on other sites More sharing options...
ChickenMob 6th Gear November 5, 2013 Share November 5, 2013 I tot KIA giving 5 years warranty the other time? yours still on warranty? Link to post Share on other sites More sharing options...
Lowrider 2nd Gear November 5, 2013 Share November 5, 2013 I tot KIA giving 5 years warranty the other time? yours still on warranty? Thought 5-year warranty only applies on 2010 batch onwards. CMIIW... Link to post Share on other sites More sharing options...
Simonsoh 2nd Gear November 5, 2013 Author Share November 5, 2013 (edited) Thought 5-year warranty only applies on 2010 batch onwards. CMIIW... ya lah... i sway batch man... before i buy, give so many goodies... during i buy time, reduce goodies.... after i buy, KIA-wide 5 yr unlimited-mileage warranty.... zzzzzzzZZZZZ...... Edited November 5, 2013 by Simonsoh Link to post Share on other sites More sharing options...
Nicholas 5th Gear November 5, 2013 Share November 5, 2013 ya lah... i sway batch man... before i buy, give so many goodies... during i buy time, reduce goodies.... after i buy, KIA-wide 5 yr unlimited-mileage warranty.... zzzzzzzZZZZZ...... This means that you bought the car at a good time. Probably low COE. Link to post Share on other sites More sharing options...
Jman888 Moderator November 5, 2013 Share November 5, 2013 ya.. i wait and see... asking around for better quotes also.. anyway got petrol kiosk near home and workplace. just discipline to pump every 400km. but the mechanic very confident. he bypass and needle go full tank. connect back it dip to zero again... repeat a few times and he say 100% "float" spoil... listen to your good word lah... hope can recover by itself, really cant bear to part with $300+ for fuel needle... give the fuel tank a kick if necessary Link to post Share on other sites More sharing options...
Nzy Twincharged November 5, 2013 Share November 5, 2013 Mine had a similar problem to yours. But mine was always stuck at full tank. Didn't repair it and drove the car for the next 4+ years. No problem. Only got one benefit that everytime I drive to JB its always full tank and whenever they search for any tampering they cannot find it cuz the problem was with the float. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Is It Really Cheaper To own An EV Versus A Gas Car?
Car Show 2024
Car Show 2024
Fuel Plus Meet Up
Fuel Plus Meet Up
Calciphylaxis: An almost fatal disease.
Heart Attack Slide Show
